Hitec X1-200 Touch Battery Charger
200-watt DC input, multi-chemistry touch screen charger
Just one more thing to add to the wish list!
Hitec is proud to announce the arrival of its high-performance, microprocessor controlled X1-200 Touch charger. With a 3.2-inch LCD touch screen, integrated cell balancer and automatic current adjustment, this 200-watt charge/discharge station has the ability to operate on a 12 volt automotive battery or 11 ~ 18 volt DC power supply. The X1-200 Touch package includes a universal balancing board with paired cable, two alligator clips and a 2-pin t-type charging cable. Easy-to-use and easy-to-setup, it is your convenient, proficient charging solution.
Key Features:
  • Charges NiMH, Ni-Cd, LiPo, LiFe, Li-Ion and Lead Acid Batteries
  • Adjustable Charge Current Rate of 0.1 12.0 Amps
  • Internal Balancing Circuit
  • 3.2-Inch High Resolution Touch Screen
  • Optimized Operating Software
SPECS
Model:X1-200 Touch
Number of Output Channels:1
AC Input Voltage:N/A
DC Input Voltage:11~18 VDC
DC Input Amperage:15 Amps
Charge Circuit Power Per Channel:200 Watts
Discharge Circuit Power Per Channel:5 Watts
Charge Circuit Range Per Channel:0.1~12.0 Amps
Discharge Circuit Range Per Channel:0.1~2.0 Amps
Balancing Current Drain Per Cell:200mAh
Dimensions (WxDxH):5.5x6.5x2.3 in. (140x165x58mm)
Weight:1.2 lbs. (544.3g)
Stock number:44209
Estimated Street Price:$119.99
Click here for more infor on the X1-200 charger and other Hitec products!
Old Jul 11, 2013, 10:44 PM
Jwmflying14 is offline
Find More Posts by Jwmflying14
United States, CA, Lompoc
Joined Nov 2010
Hitec charger? Hitec Charger with touch screen?
They must have for got a zero, it must be $1199.90
Jwmflying14 is offline Find More Posts by Jwmflying14
Old Jul 12, 2013, 09:09 AM
Paul Onorato is offline
Find More Posts by Paul Onorato
Paul Onorato's Avatar
United States, CT, Brookfield
Joined Jun 2013
Nope, that is correct.
Paul Onorato is offline Find More Posts by Paul Onorato
Old Jul 14, 2013, 02:23 PM
Rishelman is offline
Find More Posts by Rishelman
Knobbs
Friday Harbor, WA -San Juan Island
Joined Aug 2008
That seems like a pretty sweet charger for the price. Assuming it tests servos, esc's, and motors as well, given the ports on the sides. Very nice.
Rishelman
Rishelman is offline Find More Posts by Rishelman
Old Sep 08, 2013, 09:48 PM
JetLife is offline
Find More Posts by JetLife
JetLife's Avatar
Joined Mar 2013
Has anyone given this charger a shot?
JetLife is offline Find More Posts by JetLife
Old Sep 09, 2013, 09:27 AM
Joined Jun 2013
Not me, but I am dying to test one out. Looks pretty impressive at that price point.
Old Sep 09, 2013, 11:39 AM
JetLife is offline
JetLife's Avatar
Joined Mar 2013
I would love to test one as well.
Old Oct 06, 2013, 01:01 PM
xmech2k is offline
Find More Posts by xmech2k
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
Just picked one up yesterday. Unusually, I made this pretty big purchase without doing any research. I was eyeballing the chargers (Want to upgrade from my 80 watt ThunderPower I've had for years. Moving up to a plane with 6s 5000mAh.) under my favorite LHS counter when the owner happened by. He showed me a few, and I went for this one. So far I only used it to put a storage charge on 2 batteries I used earlier in the day so not much to report yet.
Also, I'm just an average user, so don't expect any highly technical data out of me! I'll just come back with my experiences with it once I use it some more, and if anyone has any questions I could try to answer. It appears this is a fairly recently released charger, so I'm a bit of a guinea pig? So far, I find it quite different than the 4 button diamond I'm used to on the old TP, but I like the more visual displays. The big test for me is how will it perform on those new 6s bricks I just got. A 1c charge on them should be no problem for it.
xmech2k is offline Find More Posts by xmech2k
Old Jun 23, 2014, 03:37 PM
WarCowboy is offline
Find More Posts by WarCowboy
WarCowboy's Avatar
United States, VA, Greenville
Joined Jan 2014
What is the difference from this X1 200 and the standard X1?
WarCowboy is offline Find More Posts by WarCowboy
Cool iMaxRC X200 Touch Screen Battery Balance Charger eranrc Batteries and Chargers 7 Feb 15, 2014 07:12 PM
New Product Hitec X1 Touch Multi-charger - in stock! ServoCity ServoCity.com 0 Jun 21, 2013 03:51 PM
Sold Hitec X1+ AC/DC Charger and CG-340 Warjet1950 Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 22, 2013 07:29 PM
Sold Hitec X1 Charger 45.00 Shipped CONUS campbellj Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 30, 2013 12:00 PM
New Product Hitec X1 MF Multi-Function Charger (44176) - $79.99 ServoCity ServoCity.com 0 Mar 15, 2013 09:23 AM
