Old Jul 09, 2013, 12:55 PM
UFCSam is offline
Find More Posts by UFCSam
Joined Jul 2013
Help!
New Hoverthings Flip, n00b questions
I took my new flip out today for the first time, it seemed to fly well, but I have some (probably)dumb questions about it.
It has the EZ3.0 board with GPS, FYI
When I was setting up my dx6i, the instructions mentioned to set several travels to -130 to 130. It seems the dx6i only goes from -125 to 125, am I missing something? I didn't install the MW software on my PC yet, because I thought everything was setup out of the box.
Should I have to bind the transmitter each time? I've had to so far.
How (can I) set the auto-hover or position hold?
I also had the LVC installed, and as far as I know it's defaulted to 3-cell. What are the jumper settings to switch between 3 and 4 cell (I found the actual jumper location, I just don't know what to change). Also, reaaaaaally dumb question, will you actually hear the alarm? Does it come from the heli or the transmitter?
To any responders, I appreciate it in advance. This thing is a ton of fun so far, I just want to learn how to use all of the features. Thanks!
UFCSam is offline Find More Posts by UFCSam
Old Jul 10, 2013, 02:17 PM
UFCSam is offline
Joined Jul 2013
Can anyone head me in the right direction?
Old Jul 10, 2013, 02:55 PM
guyaneze is offline
Find More Posts by guyaneze
guyaneze's Avatar
gainesville FL
Joined Jan 2002
the dx 6i set on 125 instead of 130 should be fine....yes 125 is all you can get on a dx6i
you should not need to bind everytime...once should be enough....did you pull the bind plug?
to set position hold you might need to set up some multiwii configuration software on your pc...unless someone from readytofly can tell you which channels were assigned to these functions.
on a dx6i you only have gear and flap to play with....i think both are two position switches.
not familiar with the lvc you speak about...is it possibly a low voltage alarm? as far as I know the alarm in one of those is very loud and you will hear it from the alarm/heli
post some pics if you can...that may help us help u mo betta
guyaneze is offline Find More Posts by guyaneze
Old Jul 11, 2013, 10:51 AM
UFCSam is offline
Joined Jul 2013
Thank-you sir! I'll try to get a picture of the Low-voltage alarm tonight, and see if it makes any sense to anyone. About the bind issue, I may be an idiot (I didn't remove any bind plug). I've only used the dx6i with a Blade MCPx, and it didn't use a bind plug. I'll give that a shot.
I'll give the software a try either tonight or tomorrow, and see if I can tell what my aux switches are set to.
Discussion HoverThings Scratch & Dent sale "FLIP FPV" frame $85.00 thrillkiss Hot Online Deals 0 Mar 17, 2013 12:10 AM
Sold Hoverthings Flip frame BNF spektrum thefokker Aircraft - Electric - Multirotor (FS/W) 7 Mar 11, 2013 09:54 AM
Found Hoverthings FLIP FPV frame or ARF setup thrillkiss Aircraft - Electric - Multirotor (FS/W) 3 Mar 02, 2013 10:32 AM
Discussion Hoverthings Flip build -couple questions SPCustoms Multirotor Talk 6 Feb 24, 2013 02:11 PM
Discussion Hoverthings Flip quad. nforbesrc99 Multirotor Talk 3 Jan 11, 2013 08:28 PM
