Old Jul 08, 2013, 07:30 PM
aircontrol is offline
Find More Posts by aircontrol
Keep it simple, Keep it light!
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
West Michigan Park Flyers Tuff Cub
The Tuff Cub is a 3 channel, EPP foam beginner - trainer plane. The wing is a KFm2 airfoil with dihedral tips.
The Tuff Cub came about after having a need for a indoor trainer plane. It had to be easy to fly and very durable! What I didn't expect was how well it would fly outside, even in a 10 to 15 mph wind.
Specifications:
- Wing span – 32”
- Length – 25”
- Wing area 256 sq in
- Weight - (without battery) 5 oz (with battery) 6 to 7 oz
- Center of gravity is 2 1/2” from front edge of wing.
- Motor: c2403 – 2100 KV
- Prop: 8x4DD or 7x3.5DD
- Battery: 460 mah to 800 mah 7.4 V
- Speed Control: 6 Amp
- 5 gram servos, 2 total
Kits are available at
http://www.wmparkflyers.com/tuff-p-8...7b76b62f6419c1
Detailed PDF construction guide is at the bottom of post #2.
Scratch build plans are posted further down by WMParkFlyer.
Tuff-Cub, indoors (3 min 51 sec)
Tuff-Cub, outdoors (2 min 50 sec)
aircontrol is offline Find More Posts by aircontrol
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
Tuff Cub build info.
Detailed construction guide is at the bottom of this post.
Here are some build videos, and pictures. I prefer the White Gorilla Glue to laminate the wing halves together, because it expands and fills gaps. but Foam Tac will also work. Allow the Gorilla Glue to cure at least half an hour before continuing build.
TUFF CUB WING BUILD (9 min 0 sec)
TUFF CUB BUILD (7 min 49 sec)
Old Jul 08, 2013, 07:31 PM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
Ailerons can be added for fun but are not needed, here are the dimensions I made mine to.
Old Jul 08, 2013, 07:33 PM
WMParkFlyer is offline
Find More Posts by WMParkFlyer
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
Plans are available in letter tile format as well as full scale
WMParkFlyer is offline Find More Posts by WMParkFlyer
Jenison
Joined Nov 2009
KITS INCLUDING EVERYTHING EXCEPT THE ELECTRONICS ARE AVAILABLE FROM WMPARKFLYERS.COM
http://www.wmparkflyers.com/tuff-p-82.html
Old Jul 09, 2013, 06:15 AM
jclassic1 is offline
Find More Posts by jclassic1
jclassic1
New Houghton, Derbyshire, UK
Joined May 2006
Great,you can never have too many cubs.This one seems to work very well.
I might build one in depron with a flat wing and ailerons,may even make a narrow full fuse to hide the electrics.It flies very well outdoors considering the light weight.
My one will probably end up around 10-12ozs.
I will post pictures once I start the build.
John
jclassic1 is offline Find More Posts by jclassic1
Old Jul 09, 2013, 05:44 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Looks like another great plane from WMPF!!!
May be perfect for my daughter.
rcrich is offline Find More Posts by rcrich
Old Jul 15, 2013, 03:47 PM
Crash Hancock is offline
Find More Posts by Crash Hancock
Caster Of Pods
Crash Hancock's Avatar
Waco, Texas USA
Joined Feb 2005
I got the first production kit!
I'm going to make a very light night flyer with mine.
Crash Hancock is offline Find More Posts by Crash Hancock
Latest blog entry: TheCrashCast.com - Episode 339
Old Jul 15, 2013, 08:35 PM
TMAC4123 is offline
Find More Posts by TMAC4123
God is Good
TMAC4123's Avatar
United States, MI, Grand Rapids
Joined Jan 2011
Probably the best plane ever to kick back and fly!!!!!!!!!
TMAC4123 is offline Find More Posts by TMAC4123
Old Jul 16, 2013, 05:02 AM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
Good Idea! Hope you can post some pictures or a video.
Old Jul 20, 2013, 11:13 PM
Caster Of Pods
Waco, Texas USA
Joined Feb 2005
All done! If you take away the time I spent waiting for glue (Foam-Tac) and paint to dry, I've only got about 4 hours in this build. Not too bad! The plane comes out at 6.7 ounces with a 2s450 battery - again, not too bad. I'm planning to toss it in the air tomorrow after church!
I expect the reason for the extra weight on mine is because I am using a different motor than the one suggested on the WMP site. I opted for a hot little wind that weighs about 21 grams - so hot, in fact, that I will be starting with a 7035 prop instead of an 8040.
Old Jul 21, 2013, 06:39 AM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
Awesome build and paint scheme!
John.
Old Jul 21, 2013, 04:25 PM
Caster Of Pods
Waco, Texas USA
Joined Feb 2005
The plain has been successfully maidened! It flies just as I thought it would and NO TRIMS were required. I really think that this is a plane I can recommend to newbs as a decent starting point. With the rates dialed down to something more manageable (yep, I had WAY too much throw set up for the first flight. LoL), I think I could hand this off to just about anyone. Being that it's an EPP plane, you know it will handle the type of abuse that a novice can dish out, too.
I'll be talking a bit about this project on tonight's podcast that we also LIVE STREAM, so feel free to drop in! Podcast site is http://www.TheCrashCast.com LIVE STREAM Site is http://www.talkshoe.com/tc/126280 - We start around 8pm CDST on Sundays.
Thanks for a great design and another great WMP kit!!
Old Jul 21, 2013, 04:43 PM
Hornetnz is online now
Find More Posts by Hornetnz
United States, NC, Raleigh
Joined Jun 2005
I'll try and make it for the live stream!
Dont forget to fill out a review on the site!
Hornetnz is online now Find More Posts by Hornetnz
Latest blog entry: 93" AJ Laser 230z
Old Jul 21, 2013, 06:23 PM
Caster Of Pods
Waco, Texas USA
Joined Feb 2005
Will do! I am also going to write up something for my web page, too.
New Product West Michigan Park Flyers MX2 XL WMParkFlyer 3D Foamies 10 Nov 30, 2015 04:08 PM
New Product West Michigan Park Flyers Mcfoamy XL WMParkFlyer 3D Foamies 9 Nov 28, 2013 11:09 AM
For Sale West Michigan Park Flyers Mako BNF TMAC4123 Aircraft - Electric - Airplanes (FS/W) 4 Oct 29, 2013 12:48 AM
Sold LPU - NEW West Michigan Park Flyers McFoamy w/ motor and batts mt_100 Aircraft - Electric - Airplanes (FS/W) 3 Jun 15, 2013 10:26 PM
