Old Dec 04, 2001, 11:25 PM
barn buster 50 is offline
Find More Posts by barn buster 50
tyler, texas, united states
Joined Mar 2001
Dx (a,b,c,d,e,f)
well im looking for the most thrust with the least amp drainage.
the DX-F seems to put out the best thrust (158 grams) on 7.2 volts on an 14x7 prop with a drainage of 1.65
as compared to the stock Dxa supplied with the TM
DX-A's best thrust is 129 grams on 7.2 volts with a drainage of 1.67 amps
am I wrong but would it seem that that DX-F would seem to be a better choice for all arround thrust to amps ratio?
barn buster 50 is offline Find More Posts by barn buster 50
Old Dec 05, 2001, 12:16 AM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
As for the TM the best GWS motor for it is the one supplied with the kit. You can't just go by the calcs as each gear ratio is best suited for certain flight characteristics. Also to use that size prop on the Moth would require you to lengthen the landing gear a bunch and it would look really weird!
boomerace is offline Find More Posts by boomerace
Laser Cut Kits for Schweizer 1-26B/C, D, and E Variants mmartin55 Scale Sailplanes 4 Aug 03, 2004 06:33 PM
Question What is the difference in the GW/EPS-300C (2/1/A/B/C/D)? JMBRAD Beginner Training Area (Aircraft-Electric) 5 Feb 28, 2004 09:39 AM
Western NY C.H.I.E.F.S. 4th Annual R/C Electric Fun Fly Meet - June 15th Greg Covey Electric Flight Events 1 May 01, 2003 04:29 PM
gws gear size a, b, c, d, whats diff? wolfance Power Systems 9 May 01, 2003 01:31 PM
F/s Gws Dx 370 A,b,c,d Graphite1 Aircraft - Electric - Airplanes (FS/W) 0 Mar 01, 2003 11:08 AM
