Old Jul 04, 2013, 04:19 PM
scottc39 is offline
Find More Posts by scottc39
scottc39's Avatar
USA, MN, Shakopee
Joined Sep 2004
F-1 Rocket EVO ---by Great Planes
http://www.greatplanes.com/airplanes/gpma1030.html
any one have one there flying, cant find much info yet . let us know what it fly's like.
scottc39 is offline Find More Posts by scottc39
Old Jul 04, 2013, 04:25 PM
erie_flyer is offline
Find More Posts by erie_flyer
Life is a Hobby
Canada, ON, Delhi
Joined Aug 2012
I actually posted the Rocket June 17 but doesn`t matter. I ordered mine at a Toronto R/C shop and hope to have it next week.
When you see the instrucution manual online you know it is close.
Bill
erie_flyer is offline Find More Posts by erie_flyer
Old Aug 18, 2013, 11:22 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
There is one of these at my LHS and its apparently a really good price looking at what Tower is selling it for. If I got this I would want to try a 4 stroke engine. Any recommendations? Do they make Pitts style mufflers for fs engines?
seeingeyegod is offline Find More Posts by seeingeyegod
Old Aug 19, 2013, 02:25 AM
otherhalf2 is offline
Find More Posts by otherhalf2
New Zealand, Marlborough, Blenheim
Joined Jun 2012
just brought one myself from TH. Looks really good. Here is the thread with review http://www.rcgroups.com/forums/showthread.php?t=1954073
otherhalf2 is offline Find More Posts by otherhalf2
Old Sep 02, 2013, 08:24 PM
This seems to be a bit of a Unicorn still. Can't find a single flight video yet Maybe I'll be the first to upload when I finish my build in about 3 weeks, probably.
[EDIT] I take it back, found a video
Great Planes F1 Rocket Evo (4 min 13 sec)
Old Sep 30, 2013, 09:51 AM
imodel is offline
Find More Posts by imodel
USA, CT, Farmington
Joined Nov 2003
This is a pretty nice model! I finished mine a couple of weeks ago, and used the recommended e-power components (OS e-motor, 60A ESC, Evo 3300 6S, APC 14x10). I'm getting almost 800 watts and performance is very lively, I can get an easy 8 minutes of mixed throttle per flight. Setup as recommended, aerobatics are easy as are takeoffs and landings. There aren't any nose over tendicies with the gear installed as recommended and I fly from a thick grass runway. On a sunny day the colors really pop and I get a lot of positive comments every time I bring the model out. Overall, very happy with his one!
R
imodel is offline Find More Posts by imodel
Old Oct 23, 2013, 03:11 PM
Diesel6401 is offline
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
So shocked their isn't more information on this plane. Really curious about it.
Diesel6401 is offline Find More Posts by Diesel6401
Old Oct 23, 2013, 06:04 PM
tonyxwing is offline
Find More Posts by tonyxwing
tonyxwing's Avatar
USA, NM, Albuquerque
Joined Mar 2010
Here is the product video. Nice looking plane!
Great Planes F1 Rocket Evo Sport Scale ARF (2 min 9 sec)
tonyxwing is offline Find More Posts by tonyxwing
Old Oct 23, 2013, 08:20 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
http://youtu.be/80a0FQ5I0No
That's the video that sparked my interest.
I would look for a cheaper alternative motor though. I would like to do a 4s setup also. I have a few 4s 3000mah , 4000mah and 5300mah packs that I rather use (depending on w&b and room). I know that amp draw would be highera vs the 6s setup. I'm willing to sacrifice runtime for cost.
Maybe something like a HK G46 670kv, 60-80 esc range with a 12x10 or 13x8.
Old Oct 24, 2013, 07:07 AM
Life is a Hobby
Canada, ON, Delhi
Joined Aug 2012
I am using an EFlite P32, 3300 4S Lipo, 13x8 prop, 60 amp ESC in my Rocket. Tons of power.
You can check it out in my build log in this forum that I started over 3 months ago at
Bill
Old Oct 25, 2013, 09:13 AM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Bill
Just read your thread. Great info!!!!! Thanks!!!
Old Jan 28, 2014, 02:00 PM
rivanna is offline
Find More Posts by rivanna
Joined Sep 2001
OS Electric Motor-F1 Roket EVO
The OS Motor does not fit the electric motor box firewall!!!!! It would take extensive mods to make it work!! As the instruction book shows, Rimfire motor works and weighs less and
and fits! Rivanna
rivanna is offline Find More Posts by rivanna
Old Mar 05, 2015, 08:08 PM
Gamerjoe is offline
Find More Posts by Gamerjoe
Gamerjoe's Avatar
United States, CA, Diamond Bar
Joined Jul 2011
I just completed my maiden last weekend with an O.S. 46FX engine turning a 11x7 APC sport prop and this plane was very fast!
Everyone at the field was surprised at the speed, because as I was assembling the plane everyone kept telling me that I needed to use the O.S. 55AX if I wanted to see any performance.
Luckily I did not listen and I just used the 46FX that I already had in my tool box.
I will create a video this Saturday and post it up here in-case anyone is interested in seeing the results.
The Evo is a great flying plane, but the color scheme is a bit difficult to see when it gets far out from you. A predominantly yellow and white plane tends to blend in with the sky.
There are only two things about this plane that I wish to point out from my experience.
1 - For me, the landing gear was attached to a very weak plank of plywood that was not glued in very well. On my third flight I had a bumpy take-off when a gust of wind forced the plane to veer off to the edge of the paved runway where it is a little rougher with some minor dirt and grass.... and the landing gear plywood plank broke right out of the plane, taking the landing gear with it. It was a fairly easy fix by using some more wood bracing, generous amounts of epoxy, and re-covering the area with white Monokote.
2 - This plane lands fairly hot, so you need to be prepared to slow it down well before trying to land. It is definitely not as hot as my pylon racing plane, but I did need to cut the throttle completely long before making the turn for final approach and it still took up most of the runway. There are two things that are going against you during the landing process. The plane is built to fly fast and has a beautiful thin wing with very little resistance. The landing gear wheels are on a very clean smooth axle which allows them to spin with ease. Once on the ground the plane keeps rolling and rolling...
Gamerjoe is offline Find More Posts by Gamerjoe
Old Mar 08, 2015, 05:49 PM
Congrats, would love to see video. I've got a .70 four stroke in mine and it's plenty fast enough. Haven't had any problems with my landing gear plywood, but I did have problems with the original bolts that hold the gear on stripping in the blind nuts. I got some replacements that work fine though.
Old Jun 19, 2015, 05:42 PM
akabek is offline
Find More Posts by akabek
akabek's Avatar
Canada, ON, Toronto
Joined Jan 2013
After one year of use mine resulting in a total loss a couple days ago due to a dead stick. I am surprised there not more information on this plane as I really enjoyed flying it. My setup included a Rossi 45 with a tuned muffler and this plane was quick. Sometimes building it light helps. I have to clean up my engine but if it is OK i will probably buy another one.
akabek is offline Find More Posts by akabek
Sold Great Planes Proud Bird NIB arf EF-1 Plane radman615 Aircraft - Electric - Airplanes (FS/W) 1 Apr 03, 2013 12:19 PM
Sold Used good condition Great Planes micro F-86 Sabre TX-R w/ 3 batteries (1 used, 2 new) RcAirplaneNoob Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Feb 20, 2013 04:33 PM
Question great planes fling DLG vs alula evo. zebtqb Hand Launch 20 Feb 06, 2013 08:17 PM
Sold BNIB Great Planes F-86 Sabre Micro EDF Brushless Tx-R(Blowout Price $65) jeb6684 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 7 Jan 09, 2013 04:43 AM
Sold BNIB Great Planes F-86 Sabre Micro EDF Brushless Tx-R(Blowout Price $65) jeb6684 Aircraft - Electric - Jets (FS/W) 7 Jan 07, 2013 07:07 AM
