Old Apr 29, 2001, 12:52 AM
realdeal is offline
Find More Posts by realdeal
Festina Lente
realdeal's Avatar
USA, KY, Lexington
Joined Nov 1999
Ecalc is WAY off on amps, but right on everything else
I have been testing my Maxcim MaxNeo13 series motors with different props and gear ratios. I have found that Ecalc predicts a MUCH higher current than I find in practice. Here are my two prime examples:
MaxNeo13D - APC-E 12x10 prop, 10-cells Pansonic 2000NiMH, 2.73:1 gear ratio.
Ecalc predicts - 52.8 Amps, 7050 Prop RPM
I measure - 32-33 Amps, 7200 Prop RPM
2nd Example
MaxNeo13Y - APC-E 14x10 prop, 21-cells RC2000, 3.33:1 gear ratio
Ecalc predicts - 50.1 Amps, 7460 Prop RPM
I measure - 34-36 Amps, Prop RPM not measured
Am I missing something? Ecalc seems to be very close on any other motor I measure or read about. It just misses these Maxcim motors by a HUGE margin in amperage. I considered that my props may be stalling in this static test since they are both fairly square, but I have noticed this phenomenon with other less square props as well. I have also bumped up the trim on my throttle channel after going to full throttle just to make sure I was getting everything I could. It never made a difference. Perhaps my batteries aren't delivering the voltage that Ecalc predicts, but the prop RPM is very close when measured.
I'm not complaining as the performance always exceeds the prediction, but I would like to know why it happens.
Keith
realdeal is offline Find More Posts by realdeal
Old Apr 29, 2001, 08:58 AM
gwh is offline
gwh
Find More Posts by gwh
gwh
Fort Worth, Texas
Joined Dec 1996
Keith,
I have always found the same thing especially with the Maxcim. When I use Ecalc with a Maxcim and I want to fly at ~30 Amps I try combinations that show about 40 Amps in Ecalc. I normally assume Ecalc is about 10 amps high, although it appears you are finding it 15-20 amps high.
gwh is offline Find More Posts by gwh
Old Apr 29, 2001, 09:18 PM
Ben Diss is offline
Find More Posts by Ben Diss
Ben Diss's Avatar
USA, NY, Chestnut Ridge
Joined Jun 2000
Well it went the other way for me. I setup a Sp480 BB Race 7.2V with 5.5 x 4.3 prop on 8 800AR cells. eCalc said 23A, Whattmeter showed 30A.
-B
Ben Diss is offline Find More Posts by Ben Diss
Old Apr 29, 2001, 09:21 PM
realdeal is offline
Festina Lente
realdeal's Avatar
USA, KY, Lexington
Joined Nov 1999
I measured prop RPM on the second combo today and got 6900 RPM. Ecalc will match this prediction if I lower the cell voltage to 1.12 volts per cell. It still says I should be drawing 42.6 Amps versus the 35 Amps I am actually seeing. This is much closer to the error you experience.
I am still at a loss in the 10-cell system as it is nearly exact except for the amperage.
Keith
Old Apr 30, 2001, 12:23 AM
Brad Trent is offline
Find More Posts by Brad Trent
Brad Trent's Avatar
Canada, BC, Abbotsford
Joined Mar 1999
realdeal:
It might be the props that are throwing the #'s off. I find that all of the large APC-E props draw 10 to 15% less amps than anyone elses props, E- or not, and still give the same rpm as a similar prop. Ecalc simply may not have the right prop factor in the program.
Brad.
Brad Trent is offline Find More Posts by Brad Trent
Old Apr 30, 2001, 01:06 PM
Ralph Weaver is offline
Find More Posts by Ralph Weaver
Ralph Weaver's Avatar
Indianapolis, IN USA
Joined Nov 2000
With that much prop pitch, the prop may be stalled during static running. This will cause low current. When it gets moving and actually "bites" into the air, the current will go up.
Ecalc, like any simulator is only as good as the data put in.
Ralph Weaver is offline Find More Posts by Ralph Weaver
Discussion MUS keeps turning right on take off? Kevdawg Parkflyers 20 Sep 17, 2006 09:29 PM
Question Dragonfly tips to the right on take off Willard Micro Helis 14 Sep 06, 2004 02:18 AM
Sky Scooter Pro-Help (on everything) Speedbug88 Foamies (Kits) 10 Jul 03, 2001 06:37 AM
Bleriot III turns right on takeoff Red Baron 47 Electric Plane Talk 4 Jun 07, 2001 06:03 AM
