This thread is privately moderated by Cody f86saber, who may elect to delete unwanted replies.
Old Jul 03, 2013, 02:29 PM
Cody f86saber is offline
Find More Posts by Cody f86saber
Edge of the World
Cody f86saber's Avatar
Canada, NB
Joined Apr 2006
Data
Hitec Optic 6 conversion to FrSky ACCST 2.4GHz
I really like this transmitter. It is compact, functional, reliable and upgradable. FrSky is also manufacturing some versatile modules that are a direct plug-in upgrade, along with incredibly lightweight receivers using their ACCST technology. Thismode of operation uses a receiver that communicates with the transmitter module back and forth, and is able to switch channels 80 times per second to dodge dynamic interference if it is encountered. This conversion kit is easy to use and I explain how I mounted it for my own use. Also in this blog, I provide the binding, range test and failsafe instructions for anyone who is contemplating using an ACCST module in their own radio. Read more by clicking on the Comments...
Cody f86saber is offline Find More Posts by Cody f86saber
Old Jul 03, 2013, 02:32 PM
Edge of the World
Canada, NB
Joined Apr 2006
I encountered some interference while using a speed controller with a poorly filtered switch mode BEC. After reading that FrSky made a system specifically to fit the Hitec Optic 6, I decided to give it a try.
The price of the DFT module and receiver was only $37, and some receivers are as low as $8 each. On top of the good pricing, the heaviest of the receivers is a mere 14 grams and the V8 series use 30mA, while the telemetry D series use 100mA.
The DF Combo kit included all the components to get get a model up and flying in no time. The light-weight DFT module plugs into the rear of the Optic 6 transmitter without any modification to the radio, and operates on the supply voltage just as the stock Spectra 72MHz module does. The DFT can be powered by 6.0 to 13.0V DC and draws 50mA. Stock output power is stated at 60mW with the included standard SMA 2dB antenna. I purchased a 5dB antenna for my own peace of mind. You can purchase 9dB and 11dB antennas as well, and of course each one increases the load on the DFT's RF amplifier, respectively. A patch antenna can increase the output to about 14dB with no other modification, but is directional. If you are looking for building a long range system around the DFT, a shielded coax cable can run from the DFT to a 2.4GHz Wi-Fi amplifier. A 4-6dB SMA attenuator placed between the DFT and the amplifier input will prevent clipping the signal input or over-driving the Wi-Fi amplifier. These amplifiers can range from 1 to 10 Watts of Power.
Above, the Hitec Spectra Synth 72MHz module next to the FrSky DFT 2.4GHz module. The 2dB antenna comes standard with the FrSky but I purchased a 5db antenna for about $2.60. A 14dB directional patch antenna is about $15.
The receiver is very compact and the antennas are interchangeable with longer shielded plug-in replacements up to 60cm in length. Offering full range (1500m), 9 grams weight and 8 channels, this is an attractive package for aircraft where connectivity is required, but space and weight are at a premium.
Above, the FrUSB is connected to the DFT module for firmware updating. You do not have to do this, but updates and improvements comes up every now and then for free download.
Above: The 5dB antenna installed on the DFT module.
SMA jack was pointed downward from the factory. After removing two screws from the back and carefully opening the case, I relocated the output to the top.
Above: A slight oversight.
Above: The cover was then drilled to move the output jack.
This output mounting position offers the most versatility, until I have a conversion to fit the antenna in the position where the Hitec's 72Hz metal one used to be.
To Enter Bind Mode:
If you are binding to a D-series receiver and are using Telemetry, ensure that both little switches on the transmitter module are set to off.
With your transmitter already set to PPM mode, hold the F/S button on the DFT module while turning the transmitter power on. Continue to hold the button for several seconds, then release.
The RED light on the DFT module will continuously flicker at a fast pace, indicating that the module is ready for binding to the receiver.
Connect the battery to the receiver/your model aircraft while holding the F/S button on the receiver. It is a very small button and may require that you use the top of a pen or other object.
A light on the receiver will flash, indicating that binding is complete.
Unplug power to the receiver and turn off your transmitter.
Turn your transmitter on and connect power to your receiver like you normally would in your model aircraft.
The RED light on the DFT transmitter module will be steady on to indicate the RF amplifier is on and a dim GREEN light will continuously flicker to indicate it is transmitting.
A steady dim GREEN light on the receiver will indicate that it is bound and receiving commands from the transmitter.
Done.
To Enter Range Test Mode:
Remove your propeller and place the model at least two feet above non-metal contaminated ground. A wooden bench or picnic table will work great.
Keep the receiver's antennas apart.
Place the transmitter's antenna in an upright position.
Turn on your transmitter and then you receiver like you normally would.
Press and hold the F/S button on the transmitter DFT module for 4 seconds.
The RED light on the DFT will now be off, indicating that its range is now reduced to 1/30th the normal range.
Range test to 30 meters distance and continuously test the controls.
Press the F/S button for about 1 to 4 seconds and it will exit range check mode.
To Enter Failsafe Mode:
The receiver does not need to have failsafe activated to operate, it is a just a precaution.
After the bind process has previously been completed, move a control surface stick such as some up elevator to a position where you want it to stay if the signal is lost.
Briefly press the F/S button on the receiver.
The GREEN light on the receiver will flash twice to indicate that failsafe has been updated successfully.
If you wish to remove failsafe, simple rebind the DFT and receiver.
The DFT module works with several transmitters, a list currently consisting of the following:
Hitec's Optic 6, Eclipse 7, Prism 7
Futaba's 3PM, 3PK, 7U, 8U, 8J, 9C, 9Z, 10C, FN series, T10C, FC-18, FC-28
WFLY's WFT09, WFT08
This module works with the following V8 & D series receivers:
-Current V Series (Non Telemetry):
VD5M (300 meters short range pico receiver)
V8R4-II (1000 meters range)
V8R7-II (full range)
V8FR-II (full range)
V8R7-SP (extra function: CPPM, 1.5-2.5km full range)
-Current D Series (Telemetry):
D4R-II (Full range, one analog and one Digital Data Stream port, RSSI, CPPM, low voltage & reception alarm)
D6FR (one analog Telemetry port, RSSI, FS & HS modes, low voltage & reception alarm)
D8R-II Plus (two analog and one Digital Data Stream port, FS & HS modes, low voltage & reception alarm, battery voltage sensor function)
D8R-XP (two analog and one Digital Data Stream port, RSSI (PWM) and CPPM output, FS & HS modes, low voltage & reception alarm, battery voltage sensor function)
-Discontinued Models:
V8R7-HV (discontinued)
V8FR-HV (discontinued)
V8R4 (discontinued)
D4FR (discontinued)
D8R (discontinued)
D8R-II (discontinued)
D8R-2 (discontinued)
D8R-SP (discontinued)
Last edited by Cody f86saber; Feb 19, 2016 at 09:08 PM. Reason: Reloaded original images
Old Jul 04, 2013, 11:44 AM
Edge of the World
Canada, NB
Joined Apr 2006
Hitec's Spectra 72MHz module was a great innovation for 72MHz radios. Changes frequencies was as simple as unplugging the module and using a 2mm flat head screwdriver to turn the dials.
I began to get interference like symptoms after several years. There was never a case of loss of control, just ticking and twitching servos. As it turned out, I was not alone. The issue is caused by the connection between the transmitter and the Spectra, where the 5 pins plug into the module. If you have a problem with twitching servos with Hitec's Spectra or Futaba's Synth modules, check here first.
The 5-pin white connector, the source of your trouble, is relatively simple. The connector is the female 5-pin Molex Connector, Digikey offers a replacement previously listed as Part# is WM3103-ND.
Sold FrSky D4R-II 4ch 2.4Ghz ACCST Receiver (w/telemetry) PepsiCola Aircraft - General - Radio Equipment (FS/W) 1 Jun 18, 2013 05:44 PM
Sold FrSky D4R-II 4ch 2.4Ghz ACCST Receiver (w/telemetry) PepsiCola Aircraft - General - Radio Equipment (FS/W) 2 Jun 18, 2013 05:43 PM
For Sale hitec optic 6 sport 2.4ghz, red cats 2.4ghz 4ch and more old82cutlass Aircraft - General - Radio Equipment (FS/W) 5 Jun 17, 2013 05:26 PM
Sold Hitec Optic 6 Sport 2.4 transmitter+ Optima 6 receiver mnahmia Aircraft - General - Radio Equipment (FS/W) 2 Jan 17, 2013 12:03 PM
For Sale Hitec Optic 6 with 2.4Ghz TX module, 72Mhz module and Optima 7 2.4Ghz RX $160 ! Sky_Dancer Aircraft - General - Radio Equipment (FS/W) 2 Dec 18, 2010 09:51 AM
