Old Feb 01, 2004, 02:11 AM
ArcherAce is offline
Find More Posts by ArcherAce
GRAVITY... Just Say NO!
ArcherAce's Avatar
Toledo, OH
Joined Apr 2002
Why were your running a 3s pack? That's over 11 volts. I'm thinking that is a bit much for the little GWS fans.
ArcherAce is offline Find More Posts by ArcherAce
Old Feb 01, 2004, 02:15 AM
BGR is online now
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
Is it possible to put fuses on the batteries so that if the amp draw gets too great that it would blow the fuse? Maybe a slow blow fuse rated a bit higher than the full load amps.
I know that this would also result in a loss of control but its better than a meltdown.
BGR is online now Find More Posts by BGR
Old Feb 01, 2004, 02:18 AM
AussieParkflyer is offline
Find More Posts by AussieParkflyer
AussieParkflyer's Avatar
Port Stephens NSW Australia
Joined Dec 2001
Thanks again mate for all your good advice.........
I don't think I'll ever know for SURE what happened this morning but if I replace the ESC with one that will definitely handle the current, and also make sure all my wiring harnesses and adaptors are well made then hopefully the A10 will rise from the ashes.
regards and happy flying guys
Aussieparkflyer
AussieParkflyer is offline Find More Posts by AussieParkflyer
Old Feb 01, 2004, 02:20 AM
Joined Dec 2001
Well ArcherAce I have tried to fly the A10 on 7.4 volt lithiums but it was underpowered.
I have had advice from several ezone members that the A-10 flies well on the 11.1 v packs, I even have a video here of a memebers A-10 flying great.........even so, if this were the case the motors would have burnt out rather than the batteries.
BTW my EDF55's are fitted with GWS 300H motors which supposedly will handle higher voltages than the standard 300's.
Old Feb 01, 2004, 02:25 AM
Phreakish is offline
Find More Posts by Phreakish
Nickel what?
Phreakish's Avatar
Prescott, Arizona, United States
Joined Jan 2003
sounds like your Y harness may have had a prob and broke one of the wires to the pack thats still 'good' (although I dont think I'd fly that pack again, lol).
Phreakish is offline Find More Posts by Phreakish
Old Feb 01, 2004, 02:30 AM
Joined Dec 2001
Well Phreakish at the price I pay here in Australia for 3 cell lipolys ($85) I have to believe it is still ok.
I have charged it.........took about 250mah......seems ok so only time will tell.
I would love to be able to check individual cell voltages but I'm not keen to cut the pack open.
Old Feb 01, 2004, 03:42 AM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Can you not poke through the covering on the bottom of the pack and check each cell?
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Feb 01, 2004, 04:30 AM
DenverDave is offline
Find More Posts by DenverDave
Wheat Ridge,co
Joined Nov 2002
The cells should be matched for best performance. If one cell developed a higher cell resistance then the other packs that are in parallel with it would have to make up the current. Also the lithium packs need to be kept flat. If they are bent in a crash then their internal resistance will increase. This problem is hard to detect if the cells are in parallel. The only way to check for it is to put a load on the cell and measure the voltage.
But I suspect that your problem was the poor wiring job on the battery conector. It does't pay to skimp on the battery wiring when the batteries cost $85.
DenverDave is offline Find More Posts by DenverDave
Old Feb 01, 2004, 04:47 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
Re: Lipo fire..........cell imbalance?
Originally posted by AussieParkflyer
Havent had any response to this query in batteries forum so thought I would re-post in the largest forum here.
I'm afraid that's not how it works. Cross-posting is a no-no. I see as many replies to the batteries query as this one, anyway. I'm going to close this down.
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Feb 01, 2004, 09:39 AM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Cell balance problems have been detected on brand new packs, so it does not necessarily require heavy use to cause imbalance:
http://www.rcgroups.com/forums/showt...hreadid=184420
But imbalance problems usually show up during charging. The number of packs that have failed catastophically during flight is much smaller than those that have failed during charging or on the ground after being damaged in a crash.
When Kokam engineers analyzed a number of failed packs, they found that one of the leading causes was bad solder joints on the tabs. Here's a good message from Kokam's JJ Hong citing various causes they found for failed packs:
http://www.rcgroups.com/forums/showt...86#post1435386
Many possibilities, but the ESC sounds like a leading candidate in your case. Even if it was the ESC this time, it is important to check cell balance periodically.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Feb 01, 2004, 11:53 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
I have merged the two separate threads started on this subject.
Brian
leccyflyer is offline Find More Posts by leccyflyer
Old Feb 01, 2004, 02:08 PM
Tom Smith is online now
Find More Posts by Tom Smith
Rhinebeck CD-99,00,01,02
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
Aussie
If you are going to use 3 cell Lipo packs, you might want to use a speed controller that has a programmable LVC, low voltage cutoff, and set it to 9 volts for the 3 cell pack. Pulling too much juice out of those cells will kill them too.
Sorry to hear about the fire, but it could have been much worse. My buddies discharged pack shorted out on his way home, no crash or misuse either, and set his car on fire. He thinks it was faulty soldering in the pack, which he did himself.
Tom.
Tom Smith is online now Find More Posts by Tom Smith
Old Feb 01, 2004, 07:39 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
As long as he doesn't "poke" thru the Aluminun foil lipo skin....ooops
hoppy
hoppy is offline Find More Posts by hoppy
Old Feb 01, 2004, 09:00 PM
Majorii is offline
Find More Posts by Majorii
Joined Feb 2004
You could put a fuse between the esc and the motors to remove the load but still keep the radio powered.
Majorii is offline Find More Posts by Majorii
Question LiPo - extreme cell imbalance Jurgen Heilig Batteries and Chargers 41 Aug 08, 2004 09:44 AM
Question Why does lithium cell-imbalance cause fire? 2raj Batteries and Chargers 15 Jan 22, 2004 09:32 AM
Some data on LiPo cell imbalance Suzanne Batteries and Chargers 30 Jan 12, 2004 08:09 PM
LiPo cell imbalance: How Long, How much? HankF Batteries and Chargers 10 Jan 08, 2004 03:52 PM
LiPo cell imbalance causes what kind of problem ? sheerLuck Batteries and Chargers 2 Jan 02, 2004 08:54 PM
