Old Jan 29, 2004, 09:58 AM
The Enemy is offline
Find More Posts by The Enemy
AllAloneInSpaceAndTime
The Enemy's Avatar
Canada, ON, Guelph
Joined Apr 2003
First Guillow's Conversion -- Spitfire!
Hi all. This will be my first Guillows conversion to electric and I may need some assistance.
I plan on using a GWS IPS with 3.5:1 gearing running on QC 830 batts. (Hoping to get Polys soon.) The stringers will be replaced with basswood(?). And I will be running an R/E setup. (I only have 3 channels, fourth is 3 position. I'm thinking retracts!)
I have just started building, and found a few trouble areas. The side keels seem to have quite a gap to fit into. Is this alright? Should I glue the keel on the bottom or top of the cutout? Also, the formers don't really have the angle cut into them to fit against the former on the opposite side. Will I need to reinforce this? What should I make the spar out of? The vinyl seems flexible and heavy.
Pics to follow.
Please chime in if you have ANY suggestions or forsee me running into any trouble spots.
Corey
The Enemy is offline Find More Posts by The Enemy
Old Jan 29, 2004, 10:41 AM
mu2freighter is offline
Find More Posts by mu2freighter
easily confused
mu2freighter's Avatar
Nashville Metro, Tennessee, United States
Joined Sep 2003
Hey, glad to see another person doing a Guillow's conversion!
First off, don't make the mistake I did with my first Dumas conversion. The Spit's got a pretty small rudder, and I think you'll save yourself a lot of grief if you install ailerons during the build...unless you're planning to add enough dihedral to make the plane look absolutely repulsive.
See my comments on my low wing Northrop Alpha here and see what you think.
I'm currently converting a Guillow's Stuka for 4 channel RC. I wrote my impressions of the kit here, if you're interested.
I'm not sure what you mean by 'vinyl.' You were discussing the spar...? I'm happy with the Northrop's balsa spar, but with bass 1/16" stringer/'spars' on the wings.
Glenn
mu2freighter is offline Find More Posts by mu2freighter
Old Jan 29, 2004, 12:21 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
More Power Scotty
Two QC 830's may not provide enough oomph, they barely fly my Dare Marionette on a DXA geardrive. Seven 150mah nicads might be better, 8 NiMh 300mah cells would work but shorten motor life. A more powerful geardrive like the twin IPS might be better too. Make provisions for fitting different battery packs/number of cells if possible.
E-Challenged is offline Find More Posts by E-Challenged
Old Jan 29, 2004, 12:43 PM
JIMA is offline
Find More Posts by JIMA
JIMA's Avatar
New Boston, Texas, United States
Joined Jan 2003
Definitly go to ailerons instead of rudder. Except for ground handling you dont need a rudder. Plus you will be capable of a lot more manuvers with ailerons. My $.02
Jim
JIMA is offline Find More Posts by JIMA
Old Jan 29, 2004, 12:56 PM
The Enemy's Avatar
Canada, ON, Guelph
Joined Apr 2003
Does anyone have a light and easy way to incorporate ailerons into this wing? I have never done this conversion before. Pics would be helpful.
Corey
BTW, My pics will have to come later. My brother has yet to send them to me.
Old Jan 29, 2004, 01:13 PM
The Enemy's Avatar
Canada, ON, Guelph
Joined Apr 2003
MU2,
Hey, lots of reading. Should be helpful. Thanks.
EC,
More power huh? Thanks for the "leave extra room" suggestion. I will have to do this... I might be going to a DD J250 w 4.5x2 prop when I get the Polys, but for now all I have are the QC cells. (I heard that the DD will be a very scale type power system for thrust. And cheap.)
I could go with a 300C-D gear. But that means another 2oz for batts.
Corey
Old Jan 29, 2004, 01:17 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Corey, substitute the vinyl parts to 1/16"ply. This was a cost cutter for Guillows.
I agree 100% w/ail/elev. When you build your wing, note the scale ail marls on the wing plan view. I would use 1/8" balsa for the hinge line. That means the ribs will have to be sliced 1/8" on either side of the hinge line on the plans. These are best marked on ribs before assembly. Use a brand new single edge razor blade. You will have to make two additional ribs for the ends of the ail. (4 all together) Sullivan .032 cable and plastic sheath make a good push rod from the servos.
Hinges that work good are Radio South Cy , cut into 1/8" strips.
St. Martin is offline Find More Posts by St. Martin
Old Jan 29, 2004, 05:13 PM
Huckebein is offline
Find More Posts by Huckebein
Huckebein's Avatar
Coquitlam BC
Joined Jan 2003
I am also doing a Guillow conversion. (Fokker Dr1) I have lightened the fuse but am unsure whether or not to lighten the wings. I want them to be strong enough to take the load of the airframe in flight with the added weight of the batteries,ect.
What do you guys think? Should I break out the drill? (The wings have bass spars and leading edges... and yes I am using ailerons)
Huckebein is offline Find More Posts by Huckebein
Old Jan 29, 2004, 05:15 PM
Huckebein's Avatar
Coquitlam BC
Joined Jan 2003
the lower wing ...of 3
Old Jan 29, 2004, 08:21 PM
KSU Flyer is offline
Find More Posts by KSU Flyer
KSU Flyer's Avatar
Manhattan, Kansas, United States
Joined Oct 2001
Corey,
Take a really good look the the following links to read about two of my conversion projects...Both will give you an idea of how to put ailerons on your Spitfire.
http://mrm1018.tripod.com/mikesparks...s/Bearcat.html
http://mrm1018.tripod.com/mikesparks...s/Corsair.html
Best of luck to you on your conversion!
-Mike
KSU Flyer is offline Find More Posts by KSU Flyer
Old Jan 29, 2004, 10:37 PM
easily confused
Joined Sep 2003
Hi, Huckebein-
Once your LE is sanded it'll take a bunch of weight off, so I'd imagine you'll be fine.
I'm using bass spars and bass trailing edge for my Stuka. What I am doing that's different is embedding about a 3/32" skein of carbon fiber strands into the balsa leading edge. On my Northrop I just CA'd some to the back of the LE, and it kept the wing intact through a nose first dive into the ground on the awful first flight that tore up the nose...makes it unbelievably strong and weighs about nothing!
You do need to take into account the taper as the ribs get smaller; I almost missed that on the Alpha and would've ended up trying to sand CA'd on carbon...yuck.
Easier way is to take your LE and make a mark at the center of the rib face for the root and tip ribs, then connect the dots with a ruler. Then just run a round file down the pencil mark to deepen it to take the CF. This way you don't have to notch each rib.
I wouldn't do this to your Dr I's wing since it's already built, and I'm sure it's plenty strong as is...but adding the CF to the balsa LE has gotten to be just as standard for me as using the bass stringers.
Good luck on the Tripe-from the burn marks I assume you're building the laser kit at 20" span. What equipment you gonna use?
BTW, St. Martin, what do you mean by 'substitute the vinyl parts to 1/16"ply. This was a cost cutter for Guillows?'
What vinyl?? Am I missing something? I'm working off a vintage Guillow's kit...
PS- OK, I have a CF reinforced LE, bass TE, and bass stringers...does anyone think I should add balsa shear webs between a pair of the top and bottom bass stringers? Seems like overkill at this point to me, but I'm open to suggestion!
Glenn
Old Jan 29, 2004, 11:08 PM
Huckebein's Avatar
Coquitlam BC
Joined Jan 2003
Glenn
Yep ...she's the laser cut one. I am using the following for gear:
gws dx IPS motor
gws pico receiver
3 Cirrus 4.4 g servos (man they are sooo tiny!!)
Castle Creations Pixie 7P ESC
Kokam 7.4V 2s 340 mAh lipos
Controls are to be A/E/R (pull-pull)
I am going to use sewn hinges
Old Jan 30, 2004, 12:56 AM
The Enemy's Avatar
Canada, ON, Guelph
Joined Apr 2003
Ok. I'm pretty new to balsa planes. So someone has to explain this whole hinge thing. Are they as important as battery or reciever selection? (Hope that doesn't sound too newbie...)
Mike,
Thank you. I believe they are perfect. Are you that Mr. Molt guy? If so its an honor to have you post here. You are doing a very good job of converting alot of foam guys to 'real' builds. (If you can call them that. Apparently they can build in your hands without a flat worktable? )
mu2,
The pics are great. Keep 'em coming. I'm really relieved that there is so much help on these Guillow kit conversions.
Corey
Old Jan 30, 2004, 05:20 AM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Glenn
Glenn, there was a time period when Guillows started replacing all plywood in the kit with PVC. I believe it was around the mid to late seventies. This was my above statement, you reversed it in understanding:
Quote St. Martin
This was in response to Corey's inquiry of:
Steve
Old Jan 30, 2004, 07:38 AM
easily confused
Joined Sep 2003
Steve-
Gotcha. When I asked if I was missing anything, that was as in, am I missing any info...and I was. Wow, substituting PVC for plywood...to paraphrase Ben Affleck, that's probably the worst mistake since having Greedo shoot first. One more thing to throw out with the crummy Guillow's wood!
Huckebein-
Cool setup, bet it comes out nice and light!
I gotta put my two cents in; I dislike sewn hinges as much as cloth ones...I've never seen sewn hinges that didn't detract from the looks of a nicely finished model. It's your call, but I'd use CA hinges cut down to maybe 1/16" strips, two per side on the elevator and 3 for the rudder. I used 1/8" hinges on my Alpha and they were still far stronger than needed. They attach well with wood glue (yellow aliphatic) for some working time (pic attached).
For the ailerons, I like using a strip of covering material, Solite is easiest obviously, but painted silkspan/airspan/litespan'd work great too. Just my opinion, of course
Glenn
F-16 Guillow's conversion Lance Nordby Electric Ducted Fan Jet Talk 125 Jan 09, 2012 10:13 AM
Help with Guillow's Spitfire.....TIA ramw5p Scale Kit/Scratch Built 10 Aug 30, 2003 01:11 AM
Guillow's SE-5a conversion knight of Ni Scratchbuilt Indoor and Micro Models 13 Mar 20, 2002 06:44 AM
Guillow's Zero conversion Joe Yap Scale Kit/Scratch Built 12 Mar 14, 2002 04:37 PM
Guillow's Spitfire as electric R/C Clipperkite Beginner Training Area (Aircraft-Electric) 23 Mar 11, 2002 10:39 AM
