Old Feb 02, 2004, 02:06 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
Lynxman,
AWG26 which is what I am using is about 0.4mm, so you would have to run 4 strands of 0.2mm in parallel to get the same resistance(resistance is inversly proportional to the square of the diameter). The length of the wire depends on how large your stator is and how many turns you are going to use. You could approximate it by measuring the length of one turn, adding some for the thickness of several layers of wire, then multiplying by the number of poles, and the number of turns.
Jeff
PS You can usually get more wire on by using multiple parallel strands of smaller wire, but it is harder to wind.
jeffs555 is offline Find More Posts by jeffs555
Old Feb 02, 2004, 10:19 PM
OmegaDot is offline
Find More Posts by OmegaDot
Upstate NY
Joined Nov 2003
I went ahead with 14 turns of 24 ga wire, Y connected. After looking closer at Jeff's picture, I see that he has a 120 tooth main gear. So his 11/120 gearing for stock blades isn't all that different from my 8/96.
Here it is after winding:
OmegaDot is offline Find More Posts by OmegaDot
Old Feb 02, 2004, 10:21 PM
OmegaDot is offline
Upstate NY
Joined Nov 2003
And ready for the bearings to be installed:
Old Feb 02, 2004, 10:27 PM
OmegaDot is offline
Upstate NY
Joined Nov 2003
Ready to mount up! Resistance checks on windings show no shorts or breaks. Now I just need to read up on the instructions for the CC Pheonix 10. Will test it with a current limited power supply and extra Rx (before making y cables etc...)
Should I spin it up slowly under no load at first, or will it "run away"?
Old Feb 02, 2004, 10:47 PM
Art Newland is offline
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
that is pur-dee! You can throttle up with no load if you want, you don't have to go full throttle but you see if it's going to run. I'm a little worried about your magnet ring, the dark colored ones don't usually fair very well. Best of luck! Let us know how it goes.
Art Newland is offline Find More Posts by Art Newland
Old Feb 02, 2004, 10:51 PM
CD-ROM Junkie
Joined Apr 2001
3mm brass tubing motor shaft
I made a shaft for my Piccolo motor today, silver soldered a 2mm shaft in the end for the pinion. Now I can use stock Piccolo pinions.
Old Feb 03, 2004, 09:12 AM
CD-ROM Junkie
Joined Apr 2001
Boy, after looking at Omegadot's motor then mine, kinda looks like the Beauty and the Beast! I'm going to try and remove the temporary mount and make a new mount and get it in the Piccolo tonight. BTW, that's FR4 copperclad circutboard material.
Old Feb 03, 2004, 11:27 AM
OmegaDot is offline
Upstate NY
Joined Nov 2003
Magnet appears darker in the pic than in real life. It's a hard brownish material with metallic specs dispersed in it. We shall see (tonight!).
On one of these 3 phase things, I gather you measure current draw on the supply side of the speed control? Where/how do you measure the voltage? I could put the speed control at 100% and vary input volts with my bench supply?
Old Feb 03, 2004, 02:04 PM
CD-ROM Junkie
Joined Apr 2001
Put your amp/watt meter in between the battery and speed control in series circut, voltage measured across the + and - battery terminals. The good stock magnets are usually medium grey color.
Old Feb 03, 2004, 09:08 PM
OmegaDot is offline
Upstate NY
Joined Nov 2003
It works!!
Ran the motor unloaded and it ran sweet. I even was lucky enough to get the rotation direction right on the first try : )
Mounted it up to the SkyLark and ran it under load. I still can't believe that little thing has as much "oomph" as it does. Looks like there is a big hole where the old motor used to be.
I couldn't figure out how to measure the motor volts with the speed control in place (stopped short of putting an Oscilloscope on it). I did measure the current draw at a bunch of throttle positions. Looks like the 14 turns - Y was a good choice (Thanks Jeff!). My hovering head speed is reached at 60-65% stick and ~4.5 amps when the power supply was set for 7.5 VDC. . These measurements are pretty rough though. Had ThetaDot holding a flashlight and note pad while I had the tach, heli, and Tx. All with the rest of the lights off. Still have 20 fingers left (between the two of us).
Now I need to make up the Y connections so that I can try it out in flight.
Old Feb 03, 2004, 09:20 PM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
OmegaDot,
That is great. Nice to know it runs as good as it looks. I know what you mean about the tach and the flashlight. I try to do most of my tach readings during the daytime. If I didn't I know there would be scars all over my hands.
Jeff
Old Feb 03, 2004, 09:36 PM
CD-ROM Junkie
Joined Apr 2001
That's great news Omegadot! I'd love to see a picture of it mounted in your heli. I finished up my Pocket Combat Wing motor tonight.
Old Feb 03, 2004, 09:37 PM
CD-ROM Junkie
Joined Apr 2001
another veiw
Old Feb 03, 2004, 09:38 PM
CD-ROM Junkie
Joined Apr 2001
Best prop seems to be a 3x3 GWS. 20k rpm @ 5 amps on 2S, and 27k rpm @ 8 amps on 3S.
Old Feb 03, 2004, 09:47 PM
CD-ROM Junkie
Joined Apr 2001
I'm going to abandon my first Piccolo motor and start a new one. I know now, more how I want to do it from info on this thread and others. Thanks to you all for your help. I am going to chronicle the entire build on my Piccolo flys thread. Going to start with this old Hitachi drive motor (same as my first one).
What can you do with a CD-ROM -motor... Petri Nygren Power Systems 0 Jan 23, 2003 05:50 AM
Wanted...Converted CD ROM motor BFLYER1151 Aircraft - Electric - Airplanes (FS/W) 1 Nov 01, 2002 10:42 AM
Help with number of winds for cd-rom motor. Frank B Power Systems 5 Oct 07, 2002 01:45 PM
Another pic of a CD-ROM motor. Jim McPherson Scratchbuilt Indoor and Micro Models 9 Sep 02, 2002 07:52 PM
compilation: rewinding CD-ROM motor threads/builders pages/pictures Ron van Sommeren Parkflyers 1 May 15, 2002 10:10 AM
