Old Jan 29, 2004, 03:41 PM
mdttb is offline
Find More Posts by mdttb
mdttb's Avatar
United States, CA, Stanton
Joined Jan 2004
never mind popped right off
mdttb is offline Find More Posts by mdttb
Old Jan 29, 2004, 05:59 PM
Lynxman is online now
Find More Posts by Lynxman
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
What specific models of CD-ROMs are recommended for this? They are really cheap right now and I wouldn't mind buying a CD-ROM just for the purpose of ripping out the motor (although I won't exactly be doing the environment a favour).
I disassembled an old DVD-ROM I have but the motor is useless, the bushing is too small to be replaced with bearings and the housing/magnet has a large flywheel which also acts as the shaft-grip and would need to me machined down.
I have lots of 7x3mm ball bearings from computer-fans. Could these be used in such a demanding workplace?
Tor Arne
Norway
Lynxman is online now Find More Posts by Lynxman
Old Jan 29, 2004, 08:45 PM
Art Newland is online now
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
Hitachi Model CDR-7930
Lynxman
That is a very good question! I tore a big pile of drives apart, it's amazing how many different configurations are out there for a drive that all do the same thing! I just happenedd to stumble across the cdr-7930, You can check this old thread, where I sold a few of these. These make wonderful conversions, they already have ball bearings and the stock magnet ring is very useable. I have yet to replace the magnet ring but I will try some N45's in one just to see if it's worth the trouble.
http://www.rcgroups.com/forums/showt...+you+own+cdrom
There is alot of good info here as well;
http://www.rcgroups.com/forums/showt...ighlight=cdrom
Also go to the power systems forum and you can read almost endless threads about conversions. Art
Art Newland is online now Find More Posts by Art Newland
Old Jan 29, 2004, 09:46 PM
OmegaDot is offline
Find More Posts by OmegaDot
Upstate NY
Joined Nov 2003
Are you guys adding any features (shoulders, spacer tubes, washers, snap rings etc...) to axially locate your shaft in the bearings? Or are you counting on the magnetic forces to do that?
I'm hoping to get time to make a conversion this weekend with a couple of 48x motors that look promising, 1/8 x 1/4 flanged ball bearings, and HPI racing gears (2mm bore).
Would there be a preference for Y or delta winding for a 2 cell lipo fixed pitch application? Gearing will be 12:1 or 9.6:1 and rotor speed would be ~1050 RPM.
OmegaDot is offline Find More Posts by OmegaDot
Old Jan 29, 2004, 11:40 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
I use a short spacer made from aluminum tubing that slips over the motor shaft behind the pinion gear and presses against the center of the bottom bearing. When I tighten the set screw on the pinion, it locks the shaft in, but I can take the shaft and magnet cup out by removing the pinion.
Mine works fine with a 14 turn "Y" winding. The "Y" winding supposedly gives more torque at lower RPM which is what you would want for a heli. 1050 RPM sounds a little low for a rotor speed. When I first did my HB, with the stock blades, I found that twisting pitch out of the blades gave more flying time, and also made it much more controllable.
Jeff
jeffs555 is offline Find More Posts by jeffs555
Old Jan 30, 2004, 12:00 AM
CD-ROM Junkie
Joined Apr 2001
jeffs555,
That's how you are getting away with the low number of turns, Y configuration. Everything I've done so far (3 motors) has used Delta wiring.
Old Jan 30, 2004, 09:30 PM
CD-ROM Junkie
Joined Apr 2001
some prop tests
Old Jan 30, 2004, 09:31 PM
CD-ROM Junkie
Joined Apr 2001
thrust
Old Jan 30, 2004, 09:32 PM
CD-ROM Junkie
Joined Apr 2001
my new build, that's a nickel in the background
Old Jan 31, 2004, 08:33 AM
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
My biggest problem is the magnets. I have no idea how to get the deodymium magnets that replace the magnet ring. Is your motor using the stock magnet ring, Art?
Old Jan 31, 2004, 08:34 AM
OmegaDot is offline
Upstate NY
Joined Nov 2003
Thanks for the info Jeff! I'm off to the shop...
Old Jan 31, 2004, 09:29 AM
CD-ROM Junkie
Joined Apr 2001
Lynxman,
Yes, I'm using stock magnets. If you are lucky, stock magnets are good enough, but so far the hitachi cdrom motors are the only ones I've tried that produce good power and motor runs smoothly. I plan on trying replacement magnets however, I have some N45's that I purchased from here;
http://www.engconcepts.net/Magnets/P...x_Magnets.html
Old Jan 31, 2004, 02:10 PM
JJfromUK is offline
Find More Posts by JJfromUK
Spent too much already..
JJfromUK's Avatar
East Yorkshire, England
Joined May 2001
You fellows I have had a lot of success so far flying these things in my Pic (stock blade size) and Moth. They seem ideal for microhelis, good power to weight ratio.
The structure and bearings varies a lot between drives!
Some come with shaft size 2mm, some with 3mm which with a slight shim, will take an ECO-8 3.2mm pinion which is available down to 10 teeth.
I have found 15 turns Y winding to work well in the PIC on 8 nimh, and also the 1500rpm Moth on 3 x lipoly.
I use 12 of 5x5x1 neodym magnets so far, and Phoenix 10 controller works smoothly and well.
JJfromUK is offline Find More Posts by JJfromUK
Old Jan 31, 2004, 08:47 PM
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
Originally posted by Art Newland
Lynxman,
Thanks, great site! I contacted them.
Old Jan 31, 2004, 09:24 PM
OmegaDot is offline
Upstate NY
Joined Nov 2003
Today's Progress
My "collecting" has yielded two 48X motors and several lower speed variants. No two are the same. Today, I made up a mount/bearing housing, shaft, and spacer for my first try at brushless conversion.
Here are the parts...
What can you do with a CD-ROM -motor... Petri Nygren Power Systems 0 Jan 23, 2003 06:50 AM
Wanted...Converted CD ROM motor BFLYER1151 Aircraft - Electric - Airplanes (FS/W) 1 Nov 01, 2002 11:42 AM
Help with number of winds for cd-rom motor. Frank B Power Systems 5 Oct 07, 2002 02:45 PM
Another pic of a CD-ROM motor. Jim McPherson Scratchbuilt Indoor and Micro Models 9 Sep 02, 2002 08:52 PM
compilation: rewinding CD-ROM motor threads/builders pages/pictures Ron van Sommeren Parkflyers 1 May 15, 2002 11:10 AM
