Old Feb 18, 2004, 11:26 AM
mad mike is offline
Find More Posts by mad mike
I crash, therefore I FLY!
mad mike's Avatar
Spring Hill, FL
Joined Feb 2003
Thanks, Art!
Guess I don't need that in there. Maybe I'll just stick it on the fridge. . .
Mike S.
(aka "mad mike")
Spring Hill, FL
I crash, therefore, I FLY!
There is no one true way.
mad mike is offline Find More Posts by mad mike
Old Feb 18, 2004, 11:37 AM
Art Newland is online now
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
Mike, great way to display the kids' artwork!
Art Newland is online now Find More Posts by Art Newland
Old Feb 18, 2004, 05:26 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Guys, I am moving this to Power Systems. Where it should have been in the first place.
Yes, you can use this in a micro heli. But this thread is not specific to that.
FB
Fred Bronk is offline Find More Posts by Fred Bronk
Old Feb 20, 2004, 06:08 AM
shim is offline
Find More Posts by shim
Brunei Darussalam
Joined Mar 2003
Hi Art,
I followed your instruction to remove the shaft using the vise and it went like a breeze but the last 2 piece of stator broke off. I think the glue must have come loose. What glue can I use to glue it back before rewinding?
Thanks on the method and picture to remove the bronze bell. I will give it a try tomorrow.
Cheers.
-shim
shim is offline Find More Posts by shim
Old Feb 20, 2004, 06:11 AM
shim is offline
Brunei Darussalam
Joined Mar 2003
Art,
I still can't locate your link to your Piccolo CDROM build.
Will there be a link to your Hummingbird CD ROM build also?
What wire guage did you use and how many turns did you make for the Hummingbird motor?
Thanks.
-shim
Old Feb 20, 2004, 09:15 AM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Shim, you can use CA to glue the stator pieces back togther. The wire wraping will do a pretty good job of that once you get it on.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old Feb 20, 2004, 09:18 AM
CD-ROM Junkie
Joined Apr 2001
shim, start looking here; http://www.rcgroups.com/forums/showt...&pagenumber=21
Once you start rewinding the stator, that will be good enough to hold it all together.
Old Feb 20, 2004, 09:59 AM
CD-ROM Junkie
Joined Apr 2001
motor in it's new home.
Old Feb 20, 2004, 01:01 PM
OmegaDot is offline
Find More Posts by OmegaDot
Upstate NY
Joined Nov 2003
FB
I wish you wouldn't have done that : (
It seems to me that there is enough differentiation (mounts, pinions, wind combinations, between a "micro-heli" CD-Rom and a "general" Cd-Rom to warrant a thread in the micro-heli forum.
OmegaDot is offline Find More Posts by OmegaDot
Old Feb 21, 2004, 03:55 AM
shim is offline
Brunei Darussalam
Joined Mar 2003
Art,
Boy this is hard work or am I dumb. I clamp the brass flywheel into a vise and using a punch and hammer on the flywheel's centre broke the flywheel leaving the centre still intact on the bell. I think I also slightly distorted the bell when on the vise. I will try and post a pick of what happened so you can see where I went wrong.
Thanks.
-shim
Old Feb 21, 2004, 11:39 PM
CD-ROM Junkie
Joined Apr 2001
shim, make sure your punch is smaller than 3mm
Old Feb 22, 2004, 05:49 AM
ChilternFlyer is offline
Find More Posts by ChilternFlyer
Still flying a desk..
ChilternFlyer's Avatar
United Kingdom, High Wycombe
Joined Sep 2001
HELP!!! - mine sort of works!
Hi guys,
I have just made my first motor, it runs ok at low speed but doesn't respond to the throttle at all well. If you try to push it, the ESC shuts down at random. (I think it is having trouble staying in sync)..
The motor has 14 turns of .3mm wire in the coils and still has the original magnet assy in the bell.
I am using a Kontronic smile 40a ESC.
The other 'feature' is that it works on my Lab PSU OK but won't start if it is run on batteries (never gets in sync). I have tried 3s li-poly and 8cell 800AR Ni-Cads.
It pulls approx 1A on a gws 6x5 and 1.5 amps on a GWS 7x6.
The throttle responds up to 1/3 and then doesn't go any faster (but will shutdown after a while).
[edit by CF: forget the current readings - that was what the lab PSU measured with damping on - it's obviously al lot higher!]
I tried my best to get 14 turns on each winding, but I can't be 100% sure.
Is there something I have missed?
ChilternFlyer is offline Find More Posts by ChilternFlyer
Old Feb 22, 2004, 09:18 AM
Joined Aug 2000
It sounds like you need to replace the magnets in your bell. Use some 5x5x1mm magnets and that should help your sync.
-Jim
Old Feb 22, 2004, 11:13 AM
Joined Sep 2001
Jim,
Thanks for that.
I have since tried it with my new Pheonix 25. It runs better with this ESC although it seems to get a lot hotter.
I have also played around with the timing, but it didn't seem to make much difference.
This motor loves the 400 gunther prop. I got 10K RPM out of it on 2s li poly!
I suspect that I'm pulling to many amps though. The 700 li-po's are heating up (not had that happen with my IPS motors).
The only other curious thing that is happening at the moment is that I can't get either ESC over 50% throttle before the ESC's stop the motor.
I'll order some magnets from Nippon Dave. (I might even get a Phoenix 10 to go with them).
Mitch.
Old Feb 22, 2004, 11:27 AM
CD-ROM Junkie
Joined Apr 2001
ChilternFlyer
If your motor is wound in Delta, 14 turns will make a very hot wind. If you can change to "Y" configuration, it will more than likely run better (less amps).
What can you do with a CD-ROM -motor... Petri Nygren Power Systems 0 Jan 23, 2003 06:50 AM
Wanted...Converted CD ROM motor BFLYER1151 Aircraft - Electric - Airplanes (FS/W) 1 Nov 01, 2002 11:42 AM
Help with number of winds for cd-rom motor. Frank B Power Systems 5 Oct 07, 2002 02:45 PM
Another pic of a CD-ROM motor. Jim McPherson Scratchbuilt Indoor and Micro Models 9 Sep 02, 2002 08:52 PM
compilation: rewinding CD-ROM motor threads/builders pages/pictures Ron van Sommeren Parkflyers 1 May 15, 2002 11:10 AM
