Old Jan 27, 2004, 07:09 PM
mdttb is offline
Find More Posts by mdttb
mdttb's Avatar
United States, CA, Stanton
Joined Jan 2004
Cd-Rom Motor
Not sure if it was here or another forum but some one was going to modify a cd drive motor. Getting the link would be nice.
mdttb is offline Find More Posts by mdttb
Old Jan 27, 2004, 07:36 PM
Art Newland is offline
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
that might be me?
http://www.rcgroups.com/forums/showt...&pagenumber=15
Art Newland is offline Find More Posts by Art Newland
Old Jan 27, 2004, 07:52 PM
corey is offline
Find More Posts by corey
corey's Avatar
Canada, MB, Winnipeg
Joined Oct 2001
I have not looked through this yet but looks good.
http://homepages.enterprise.net/jayjay/cdrom_motors.htm
corey is offline Find More Posts by corey
Old Jan 27, 2004, 08:31 PM
mdttb is offline
mdttb's Avatar
Joined Jan 2004
Thanks guys
Art did you bench test it yet ?
Web page I was looking at guy had it mounted on his bench testing it.
Old Jan 27, 2004, 08:59 PM
CD-ROM Junkie
Joined Apr 2001
like this?
Old Jan 27, 2004, 09:00 PM
CD-ROM Junkie
Joined Apr 2001
and this?
Old Jan 27, 2004, 09:18 PM
mdttb is offline
mdttb's Avatar
Joined Jan 2004
Yup that was it. Have a old drive that took a dive the motor still works. Time to start tinkering. If you could help that'll be great Looking at the cd-rom motor wondering how I'm going to get the can off.
Thanks for the pictures.
Old Jan 27, 2004, 09:42 PM
CD-ROM Junkie
Joined Apr 2001
got a picture of your motor?
OmegaDot is offline
Find More Posts by OmegaDot
Upstate NY
Joined Nov 2003
Art,
Have you figured out a specific "test" prop that duplicates the load & speed of your Piccolo rotor & gearing?
OmegaDot is offline Find More Posts by OmegaDot
Old Jan 27, 2004, 10:03 PM
CD-ROM Junkie
Joined Apr 2001
OmegaDot,
No I haven't. The 5x3 is pulling about 5 amps and thats what my stock Piccolo is pulling at full throttle, so been running it there just to see how it holds up. I ran it a full throttle tonight for 10 minutes straight, it ran great, never missed a beat. Checked the temps, all were warm but not hot at all. I have some more props on the way, I want to see how it will handle 6-7 amps. Anyone know where I can find pinions with 3mm bore? I'd like to find an 8,9,10, and 11 tooth. i got a tach on it tonight, 14250 RPM hot off the charger on a 2S-1500 Kokam, dropping to 14000 after it leveled off.
Old Jan 27, 2004, 10:27 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
For mine, I originally used 1/8" 48 pitch robinson racing car pinions from the local hobby shop. They worked ok on the 3mm shaft, but the smallest they make is 12 teeth. I ended up turning the end of the shaft down to 2mm, and using Orion micro RS4 pinions also from the lhs. I don't have a lathe, but just chucked the shaft in a drill press and used a file to grind down to 2mm.
Jeff
jeffs555 is offline Find More Posts by jeffs555
Old Jan 27, 2004, 10:39 PM
CD-ROM Junkie
Joined Apr 2001
jeffs555
what are you using for a shaft? what battery, wire/winds?
Old Jan 27, 2004, 11:09 PM
mdttb is offline
mdttb's Avatar
Joined Jan 2004
grabbed the wrong one been a long day now my camera is dead
Old Jan 27, 2004, 11:22 PM
avance_x is offline
Find More Posts by avance_x
avance_x's Avatar
Hong Kong
Joined Jul 2003
The motor you have is from a hard disk drive I suppose. CD-rom motor is the one on Art's pics.
Here's mine
avance_x is offline Find More Posts by avance_x
Old Jan 27, 2004, 11:27 PM
CD-ROM Junkie
Joined Apr 2001
Man, you're on you own there! Is that out of a hard drive?
What can you do with a CD-ROM -motor... Petri Nygren Power Systems 0 Jan 23, 2003 05:50 AM
Wanted...Converted CD ROM motor BFLYER1151 Aircraft - Electric - Airplanes (FS/W) 1 Nov 01, 2002 10:42 AM
Help with number of winds for cd-rom motor. Frank B Power Systems 5 Oct 07, 2002 01:45 PM
Another pic of a CD-ROM motor. Jim McPherson Scratchbuilt Indoor and Micro Models 9 Sep 02, 2002 07:52 PM
compilation: rewinding CD-ROM motor threads/builders pages/pictures Ron van Sommeren Parkflyers 1 May 15, 2002 10:10 AM
