Old Jan 26, 2004, 08:33 PM
jeff262 is offline
Find More Posts by jeff262
farmington, mn
Joined Sep 2003
why does my manual tell me my wing has a different CG for different motors?
ok my slow stick manual tell me that a 300 size motor the CG on the wing is at 110mm but a 400 size motor my CG should be located at 95mm. why is this? i plan on using a brushless motor with 35 ounces of static thrust should i move the CG even more forward on the wing? i just don't understand how the CG point can change because of a motor
jeff262 is offline Find More Posts by jeff262
Old Jan 26, 2004, 08:41 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Re: why does my manual tell me my wing has a different CG for different motors?
CG can vary due to wing loading. Difference at extreme ends of the envelope. As the s400 option will be considerably faster a more nose heavy CG will yield a less pitch sensitive model, which is desireable. At very low speeds and very light wing loading you need to increase pitch so a rearward CG is required.
The fullsize F16 supersonic CG is around 45-50% MAC for instance.
Haldor is offline Find More Posts by Haldor
Old Jan 27, 2004, 07:29 AM
Jacques Flambeau is offline
Find More Posts by Jacques Flambeau
Restful User
Jacques Flambeau's Avatar
Backwoods Alabama
Joined May 2000
That makes good sense. The 400 CG is at 33% and the 300 is at 36%. Just off the top of my head it does not seem that 1 ounce of added motor weight would make that much difference, but it may. The 33-36% values are a reasonable range; what I would do is start with the forward CG and move it back til the elevator felt "twitchy" and then move it forward a bit.
This is an important issue since many SS's are used for AP, which adds several ounces to the design weight. Again, I'd start at 33% and tweak.
--Bill
Jacques Flambeau is offline Find More Posts by Jacques Flambeau
Why Does this happen when I use my Orbital-Pro 6.3 Lv2Fly Batteries and Chargers 2 Feb 05, 2005 12:52 PM
Why isn't Modeltek sending me my Cobra :( Silverstreak328 Micro Helis 16 Jul 18, 2004 07:41 AM
Why does my charger lie to me? HIGHFLYER99 Batteries and Chargers 14 Jul 07, 2004 08:14 PM
Lost my assembly manual for Devastator. Anyone here can tell me the suggested CG? ScYcS Foamies (Kits) 3 Feb 05, 2004 09:33 PM
My wing has been attacked! DuCKy! Slope 11 Oct 20, 2003 05:01 PM
