Old Jan 26, 2004, 03:12 AM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
My Bonito in for repair...(Fiberglass fuse reconstruction)
This is my first attempt at Fiberglass repair. My Bonito was lost due to a radio hit at DEAF. You can see me in the video walking across the field with its shattered remains. http://www.rcgroups.com/links/index.php?id=4271
I am posting this thread so others can learn from my mistakes, and to get the experts to give suggestions. If I screwed something up, oh well...I will look for a slow day at the field to maiden it again.
I debated about what to do and decided I had nothing to lose so here goes.
I am familar with the techniques used to glass boats, but there is a structural frame already there. In this case, the frame is weak and not straight so I used masking tape to get the fuse temporarily lined up...
Before...
kepople is offline Find More Posts by kepople
Old Jan 26, 2004, 03:16 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
Here are my supplies. I am useing 3/4 ounce glass.
The blue cardstock I am using as a speader to wet out the fiberglass, cheap and work pretty good, plus I can make any shape I need.
See the aligned bandaged carcass in the background.
Old Jan 26, 2004, 03:18 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
der glass
Old Jan 26, 2004, 03:23 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
I have taped the patient down to the bench and layered one thickness of glass in the bottem. I did it 3 stripes, 1) bottem 2) left side of fuse 3) right side of fuse.
I added some CF tape to reinforce it...then poured just enough epoxy to wet out the glass. If there was a puddle left over I removed it with a towel.
For the glass mixture, I used equal parts of each adn added 1/8 total mixture alchol to thin it. With the cold temp of the shop, I had about 1 hour of pot life.
Old Jan 26, 2004, 03:24 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
Using the epoxy in the fuse already I layed up another layer of glass over the tape to sandwich it in the fuse, then let it cure over night.
Old Jan 26, 2004, 03:25 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
next day, I rolled on its side and repeated the procedure. The glass goes to the rear bulkhead
Old Jan 26, 2004, 03:26 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
Next day samthing, but the other side.
Old Jan 26, 2004, 03:30 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
The next day the fuse is significantly stiffer than it was before. Yippee...
I beagn to work the outside cosmetics...
In a a couple places cloth was used to fill the hole, but the epoxy was mixed with microbaloons for filler and to make it sandable. You get a lifetime supply for $4. I am told you can also use baby power and it makes a pleasant smell...
Old Jan 26, 2004, 03:33 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
Not one to take my time if I have an alternative I get out the big dog with 180 grit thats been on there a while. I get a real nice rough sanding. After some very close examination with a flod light, I determine what needs to be filled more, and repeat the microballoons minus the glass...
Old Jan 26, 2004, 03:35 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
****Warning**** Graphic photos, parental discression is advised
Some of the damage after rough sanding...
Old Jan 26, 2004, 03:37 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
Both sides of the saddle are cracked.
Old Jan 26, 2004, 03:38 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
Where the fuse snapped in two...
Old Jan 26, 2004, 03:39 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
Time to get to it...
I ran 220, 320, 400, and 600 grit sand paper over the whole fuse to get a good surface to paint...
Old Jan 26, 2004, 03:41 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
The gaping wound, now is very smooth..
Looks like something from CSI.
Old Jan 26, 2004, 03:42 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
ready for primer....
Now the big question...what kind of primer should I use?
Kirby
AON 12mm in for repair. VBSuperMaxx Cermark 3 Oct 13, 2005 01:55 PM
Question broken Futaba receiver, worth send in for repair? ave Radios 1 Nov 12, 2004 09:20 PM
Help! Where to send my Flash 5X for repair? omega blood Hitec/Multiplex USA 2 Apr 21, 2004 02:36 AM
New JR receiver sent in for repair 12+ BD turnaround. sa-10 Fuel Plane Talk 6 Sep 29, 2002 02:38 PM
which tool for cutting a fiberglass fuse? p471701 Electric Ducted Fan Jet Talk 7 Jun 19, 2001 09:22 PM
