Old Jan 25, 2004, 07:03 PM
malcolm.fisher
malcolm.fisher
Guest
n/a Posts
Bird of Time
Does anyone know how much movement there should be on the BOT's all moving
tailplane?
Malc
Old Jan 29, 2004, 04:00 AM
Dirtnap
Dirtnap
Guest
n/a Posts
Re: Bird of Time
Well, as far as their website tells it:
Both high rate and Low rate should be set to "N/A"
See the link:
http://www.dynaflite.com/techsupport/technotes.html
"malcolm.fisher" <malcolm.fisher@ntlworld.com> wrote in message
newsfOQb.3$kb4.0@newsfep1-gui.server.ntli.net...
> tailplane?
> Malc
Dirtnap
Dirtnap
Guest
n/a Posts
Re: Bird of Time
Also here:
http://www.dynaflite.com/manuals/dyfa0500-manual.pdf
"Dirtnap" <dirtnap@home.com> wrote in message
news:Ym_Rb.13860$M81.689@twister.rdc-kc.rr.com...
> See the link:
moving
> > tailplane?
> > Malc
Dirtnap
Dirtnap
Guest
n/a Posts
Re: Bird of Time
Page 13
Old Feb 03, 2004, 04:00 AM
burntkat IS AT comcast.net
Guest
n/a Posts
Re: Bird of Time
Dirt-
have you built the BoT? I have plans on teh way and will end up building one
someday.....
news:2t_Rb.13864$M81.9184@twister.rdc-kc.rr.com...
> Page 13
Old Feb 04, 2004, 04:03 AM
Dirtnap
Dirtnap
Guest
n/a Posts
Re: Bird of Time
Sorry, never built one, I did set up the radio in one for a friend,
He was a newbie and had an instructor for flight but not to build the plane
or set up the throws, ect.
I think his was built from a kit though.
BTW'
Where have you been, Man?
Haven't see you in the land group for some time.
John
"burntkat IS AT comcast.net" <burntkathatesspam@cast.net> wrote in message
news:bOudnWT7Iowgq4LdRVn-vA@comcast.com...
> Dirt-
one
> someday.....
> > Page 13
Old Feb 05, 2004, 04:00 AM
burntkat@hotmail.com
Guest
n/a Posts
Re: Bird of Time
The government has been keeping me busy. LEt's just say I've managed
to keep my hand in RC in the interim
"Dirtnap" <dirtnap@home.com> wrote in message news:<BJYTb.19816$2h.4675@twister.rdc-kc.rr.com>...
> BTW'
> John
> > Dirt-
> one
> > someday.....
> > > Page 13
Old Feb 07, 2004, 04:00 AM
Aileron37
Aileron37
Guest
n/a Posts
Re: Bird of Time
Malcolm, though it has been several years since I have had my Bird of Time, I
recall using an inch or better total throw, (on pitch) and set up expo to
soften the center. I also remember using a lot of rudder throw. The kit I built
was covered with light silkspan and dope and perhaps a bit heaver than a film
covered model. It flew very nice at a trimmed forward airspeed (not just
floating around), would thermal easily, however needed the "larger" throws at
slower speeds. Personally, I like all the throw (within reason) I can get on a
test flight and dial back with dual rates if necessary. rick markel
Old Sep 18, 2006, 11:11 PM
Vegasfan
Vegasfan
Guest
n/a Posts
Bird of Time
I am considering buying an A.R.F. version of the Bird of Time. Has
anyone flown one before and what is your opinion? I'm relatively new to
soaring. Is this a suitable trainer? Thanks, Clyde
Old Sep 19, 2006, 01:11 AM
Doug McLaren
Doug McLaren
Guest
n/a Posts
Re: Bird of Time
In article <c3IPg.4375$uj3.1963@trnddc08>,
| to soaring. Is this a suitable trainer? Thanks, Clyde
Looks like it would make a great trainer. My only complaint is that
it doesn't come with spoilers unless you add them yourself -- which
isn't too difficult, but if you buy an ARF, you sort of expect to not
have to do that.
I have one in the garage, crashed and then given to me. I've still
got to fix it, so I've never flown it, but the ones I've seen fly fly
very nicely -- nice and slow.
If you're flying off a high start, they're great. For a winch,
they're OK, but be gentle on them. For slope flying, they're probably
good in light lift, but in most cases you'll probably want something
more nimble.
Doug McLaren, dougmc@frenzied.us
"I tell them I don't need drugs to get high or be cool:
I can do it with alcohol, my anti-drug."
-- The Onion
Old Sep 24, 2006, 05:11 PM
Jarhead
Jarhead
Guest
n/a Posts
Re: Bird of Time
"Vegasfan" <cbusse1@verizon.net> wrote in message
news:c3IPg.4375$uj3.1963@trnddc08...
to
I bought one and added spoilers to it. The spar web was put in wrong.
I.E. the grain ran parallel to the spars instead of vertical. I
installed some more webbing with the grain vertical. (Since then I have
found that others have wrapped the spars with Kevlar and also put
graphite cap strips in order to winch launch it.)
I hand launched it and the trim was okay. I did a gentle hi-start launch
(25 paces into a 7 knot wind) and made a circuit of the field and
landed. Did this two more times increasing to 35 and then 50 paces.
After the 3rd landing I noticed the fuselage was kinked just ahead of
the tail. Examination showed that the Fiberglass was not saturated by
the resin.
I contacted Tower and eventually got a new fuselage. To strengthen it I
sprayed insulating foam in the fuselage after installing the controls
and an antenna tube. It adds a little weight but is worth it in my
opinion.
Would I buy another one? Maybe the kit that Tower offers, but not the
ARF.
One of our club members had the same problem while flying a RES contest
and installed the foam over night and flew it the next day in open
class.
I would recommend the Spirit ARF as a trainer over the BOT.
Jarhead
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old Sep 24, 2006, 11:11 PM
Vegasfan
Vegasfan
Guest
n/a Posts
Re: Bird of Time
Thank you both for the informative posts. I will take your
suggestions into consideration.
Clyde
> to
> the resin.
> opinion.
> ARF.
> class.
Old May 15, 2007, 11:30 AM
basils is offline
Find More Posts by basils
Joined Mar 2007
Basil White
to
the resin.
opinion.
ARF.
class.
Jarhead
I purchased an ARF BOT with fibre glass fuz and had the same problem, namely unsaturated glass fibre in virtually the whole fuz. Result fuz broken three times on normal landing. Have now reinforced with carbon tows and so far OK. Clearly the quality control at production is not good. Other problem was warp in fuz and had to correct with heat. Not good enough. Wings are really well made and show up poor production of fuz. Have modified with AXI motor. Cut off nose just behind weight and extended nose to accomodate motor with thin 1mm ply then glassed. Built in air scoop above motor to avoid landing damage. Here in Johannesburg (mean height above sea level 5000 feet) thermals great but definately needs spoilers for landing otherwise spend all day bringing bird in. Any suggestions for simple hinged spoilers without major surgery? searchsa@iafrica.com
basils is offline Find More Posts by basils
What's a Bird of Time worth? mescal1 Electric Plane Talk 2 Oct 26, 2001 01:23 AM
Building board for Bird of Time JCastle Electric Sailplanes 1 Oct 12, 2001 01:17 PM
Bird of Time: Optimal CG? GeorgeE Electric Sailplanes 11 Aug 03, 2001 09:35 PM
Bird of Time, can't find the threads, please help! procrastination inc Electric Plane Talk 2 Jul 31, 2001 11:02 PM
Add me to the growing list.......(E-Bird of Time) toneman Electric Sailplanes 5 May 11, 2001 09:01 AM
