Old Jul 16, 2013, 02:36 AM
mrqua is offline
Find More Posts by mrqua
Joined Jun 2013
Here, let me post another picture, sorry if it is low quality.
[URL=http://s452.photobucket.com/user/rickyaditya/media
I can't screw the carbon plate to the plastic motor mount because of the 3 motor wires.
Motor screwed to the three outer hole on the carbon plate, so it can't be reversed.
mrqua is offline Find More Posts by mrqua
Old Jul 16, 2013, 03:23 AM
Alekoy is offline
Find More Posts by Alekoy
Norway, Møre og Romsdal, Sula
Joined Dec 2009
I see no problem in cutting the plate like you have shown, but there is room enough to let the wires go through the oval opening and into the boom
Alekoy is offline Find More Posts by Alekoy
Old Jul 16, 2013, 03:54 AM
Askyvision is offline
Find More Posts by Askyvision
Albuquerque USA
United States, NM, Albuquerque
Joined Dec 2012
Originally Posted by mrqua View Post
Hi guys,
I'm currently building this frame using sunnysky X4108S 600KV.
Having trouble attach the motor to the mount cause the motor wire.
Can I do the modification on the carbon motor mounting like in the picture
So the wire can be put inside the carbon boom.
Thx for the suggestion.
I just check and it better to cut that part out so the cable can go through. You can force the cable without cutting the plate but that join motor wire will break sooner or later under vibration. So best is to cut that part off it doesn't affect anything that I can see
Askyvision is offline Find More Posts by Askyvision
Old Jul 16, 2013, 04:36 AM
mrqua is offline
Joined Jun 2013
Thanks for the reply
Let me post another pic (sorry if it is low quality) to show that I can't force the wire through the carbon plate opening
See the edge of the plate
Can not bend the wire to the bottom
Old Jul 16, 2013, 08:26 AM
synergy3050 is offline
Find More Posts by synergy3050
Joined Jun 2013
Who has stock of the 690? Checked a couple of the links from this thread but could not find stock at those sites. Thanks
synergy3050 is offline Find More Posts by synergy3050
Old Jul 16, 2013, 11:58 PM
Lorisdem is offline
Find More Posts by Lorisdem
undefined, Nicosia
Joined Jan 2012
www.beevrc.com
Lorisdem is offline Find More Posts by Lorisdem
Old Jul 17, 2013, 12:22 AM
Albuquerque USA
Joined Dec 2012
Originally Posted by Lorisdem View Post
I rather burn my money than do business with them
Old Jul 17, 2013, 01:01 PM
rahulvyas is offline
Find More Posts by rahulvyas
Joined Jul 2012
see the pics of the fy690S
rahulvyas is offline Find More Posts by rahulvyas
Old Jul 17, 2013, 02:48 PM
brifa is online now
Find More Posts by brifa
brifa's Avatar
ITALY
Joined Aug 2006
A good sunnysky motor configuration to use with 5000mah 3S lipo??
i am testing it with these motors
Sunnysky 2212-13 kv980
http://www.foxtechfpv.com/sunnysky-2...980-p-384.html
with graupner 10x5 props
naza
no fpv stuff
but only tarot gimbal
well
only 5 minutes and it sucks 70% battery charge... doing a little flight and a lot of hovering
i would like to have a 10 minutes flight with also fpv stuff
please let me know
brifa is online now Find More Posts by brifa
Old Jul 17, 2013, 02:54 PM
Albuquerque USA
Joined Dec 2012
naza
no fpv stuff
well
please let me know
it a waste to run any motor higher than 700 because it a big frame small props will have a hard time on the motor but putting bigger props on motor that wont able to swing it
the F550 yes you can going with the 9xx or 8xx kv but this thing is 680 or 690 so choose wisely guys
with the 690 you can easily swing 14" or maybe 15" i dont know about 15" but i know that 14" will do fine
Old Jul 18, 2013, 04:51 AM
Joined Jul 2012
You should use 2814 700kv motors.
they fit perfectly on this frame.
Old Jul 18, 2013, 06:54 AM
brifa is online now
brifa's Avatar
ITALY
Joined Aug 2006
Which prop for 3S lipo?
Old Jul 19, 2013, 06:45 AM
Joined Jul 2012
12" with 25A or 30A ESC
I use 4S with 11" and 25A plush!
Old Jul 20, 2013, 10:22 PM
mrqua is offline
Joined Jun 2013
Just maiden 690 with:
Naza v2, sunnysky x4108s, flyfun 30, and 4s 4000.
I made mistake putting the 13' prop, the copter wobble all over the place, then stripping 2 prop. Try again with 3s, it successfully hover. Maybe tomorrow / day after tomorrow, will put the 12' prop and use the 4s. And then set the gain, cruise test, RTH test etc.
I will put the BeHolder gimbal, iOSD, and vtx later
Old Jul 22, 2013, 12:33 PM
Lorisdem is offline
undefined, Nicosia
Joined Jan 2012
Description: Box
Question GLB 20mm Carbon Fiber Center Plate +16pcs Tube Fixtures for 700-1000mm Hexacopter/Oct tormodnt Multirotor Talk 5 Mar 09, 2014 01:18 AM
For Sale **New** Carbon Fiber Hexacopter 680 mm (Australia) LegendLength Aircraft - Electric - Multirotor (FS/W) 0 Apr 13, 2013 03:17 AM
Discussion ~800mm Carbon Fiber Hexacopter Frame serrated Multirotor Talk 5 Feb 16, 2013 12:59 AM
For Sale HEXA X800-V6 Carbon Fiber Hexacopter frame Kit Go4it Aircraft - Electric - Multirotor (FS/W) 0 Dec 05, 2012 03:59 AM
Discussion strenght of 6mm square carbon fiber tube for hexacopter abcd123 Multirotor Talk 0 Jan 27, 2012 04:01 PM
