Old Jun 30, 2013, 10:41 AM
copterstar is offline
Find More Posts by copterstar
Joined Apr 2013
Tarot FY690S Carbon Fiber Hexacopter Thread
Tarot FY690S Carbon Fiber Upgraded Motor Mount Hexacopter TL68C01
Highly improve the motor mount to suit big motor, the size increase a little bit to 690mm, very similar to FY680.
Real Stock in Copterstar
http://www.copterstar.com/index.php?...roduct_id=2472
copterstar is offline Find More Posts by copterstar
Old Jun 30, 2013, 11:44 AM
rahulvyas is offline
Find More Posts by rahulvyas
Joined Jul 2012
Compared to FY680, whats new?
rahulvyas is offline Find More Posts by rahulvyas
Old Jun 30, 2013, 11:55 AM
Askyvision is offline
Find More Posts by Askyvision
Albuquerque USA
United States, NM, Albuquerque
Joined Dec 2012
Just the motors mount.
Askyvision is offline Find More Posts by Askyvision
Old Jun 30, 2013, 08:21 PM
Soma is offline
Find More Posts by Soma
Australia, QLD, Brisbane
Joined Sep 2012
Is it possible to use these motor mounts for a Y6 format?
edit... found another picture of the mounts. Looks like the motor plate is only possible to mount on one side.
Soma is offline Find More Posts by Soma
Old Jun 30, 2013, 08:35 PM
SamurAchzar is offline
Find More Posts by SamurAchzar
Joined Jan 2009
Aren't the anodized aluminum braces in the center also new?
SamurAchzar is offline Find More Posts by SamurAchzar
Old Jun 30, 2013, 10:46 PM
daign is offline
Find More Posts by daign
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
just the motor mounts 'upgrade'.. the aluminum braces have always been there along with the silver ones for the side arms.
daign is offline Find More Posts by daign
Old Jul 01, 2013, 12:51 AM
Albuquerque USA
Joined Dec 2012
No it the same aluminum but while they took pictures the reflection of the black carbon make it look like it anodized.
Only the new motor mount since this new motor mount alow the motor sit at the end of the boom instead the top of the boom, it easy to mount then The old one and it make it longer so I think you can swing 14 inch props If need in hex config
I hop that copterframe can post a picture of the bottom of the new motor mount I want to see if I can mount it in Y6
Old Jul 01, 2013, 08:56 PM
oned is offline
Find More Posts by oned
Indonesia, East Java, Surabaya
Joined Feb 2006
The new motor mount is now plastic and only being held to the boom with single screw?
I am afraid this weaker and less stiff than the previous version.
What do you think?
oned is offline Find More Posts by oned
Old Jul 01, 2013, 09:51 PM
dfruehwald is offline
Find More Posts by dfruehwald
WZ9V, AMA 409852
United States, VA, Alexandria
Joined Jan 2007
Wish they had ditched the plastic clips for locking the arms with a scaled down T810/960 mechanism. I'm also not sure the new motor mounts are an improvement either. It looks like they tried to make smaller plastic versions of the T810/960 metal ones.
I do like that Tarot is trying new stuff though.
dfruehwald is offline Find More Posts by dfruehwald
Old Jul 02, 2013, 11:17 AM
Joined Apr 2013
Just take a look on the stock, the connection to the tube is really strong and it is not the soft plastic, also this mount structure seem can absorb some kind of vibration. it is really look like the FY680, please feel free on more question.
Old Jul 02, 2013, 11:24 AM
Joined Jul 2012
So is this better or the FY680.
Same price. confusing!
Old Jul 02, 2013, 11:34 AM
Joined Jul 2012
please post real pics of this frame.
I am interested in buying.
Old Jul 02, 2013, 12:19 PM
Joined Apr 2013
FY690S little bit bigger and newer, the motor mount is refer to the 810 and 900.
Indeed it is hard to make decision, I have both instock and FY680 cost little bit less.
Old Jul 02, 2013, 02:56 PM
Albuquerque USA
Joined Dec 2012
so my theory is right we can use this to mount in the Y6 config as the mount have a bottom plate for the esc remove that carbon piece replace with the motor mount and you can mount another motor on the bottom.
Copterstart if you can take a picture with a motor on it so we can see hows the clearance for the motor when it sit on it and also a picture just like the one you posted but turn the mount to 45degree i want to see the side please. If the plastic is good this is a better mount but i dont think 1 screw will make it any better as it will cause more vibration. if them make this mount like the T810 where it mount by 4 screws then it something good.
thanks for the picture
Old Jul 02, 2013, 04:43 PM
WZ9V, AMA 409852
Joined Jan 2007
The screw through a hole in the tube would make alignment easier for sure but the FY680 was not that hard. Just put the mounts on slightly loose and use a straight edge and tighten them when the straight edge is flat across all three.
Question GLB 20mm Carbon Fiber Center Plate +16pcs Tube Fixtures for 700-1000mm Hexacopter/Oct tormodnt Multirotor Talk 5 Mar 09, 2014 12:18 AM
For Sale **New** Carbon Fiber Hexacopter 680 mm (Australia) LegendLength Aircraft - Electric - Multirotor (FS/W) 0 Apr 13, 2013 02:17 AM
Discussion ~800mm Carbon Fiber Hexacopter Frame serrated Multirotor Talk 5 Feb 15, 2013 11:59 PM
For Sale HEXA X800-V6 Carbon Fiber Hexacopter frame Kit Go4it Aircraft - Electric - Multirotor (FS/W) 0 Dec 05, 2012 02:59 AM
Discussion strenght of 6mm square carbon fiber tube for hexacopter abcd123 Multirotor Talk 0 Jan 27, 2012 03:01 PM
