Old Jan 24, 2004, 06:25 AM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
Question
Pull-Pull Cable Material
Just wondering what people find makes a good pull-pull cable, ie strong and no stretching. I'm going to use one on my DeHavilland Twin Otter. Rudder area is about 34 sq in., so I need something stronger than the really light stuff used by the micro flyer type airplanes. Thanks for any input!
Wolpertinger is offline Find More Posts by Wolpertinger
Old Jan 24, 2004, 06:33 AM
AndyU is offline
Find More Posts by AndyU
Joined Jan 2004
20# test dacron fishing line/flyline backing
AndyU is offline Find More Posts by AndyU
Old Jan 24, 2004, 06:48 AM
dalbert02 is offline
Find More Posts by dalbert02
K4UAV
dalbert02's Avatar
Miami, FL
Joined Jul 2003
or 20lb or even 30lb spectra fiber. I've used the PowerPro brand as that is what I spool all my fishing reels with. Berkley Fireline also works.
dalbert02 is offline Find More Posts by dalbert02
Old Jan 24, 2004, 06:49 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Kevlar thread works well, too..
..a
Old Jan 24, 2004, 07:43 AM
uglystick is offline
Find More Posts by uglystick
Arnold , Maryland, United States
Joined Nov 2002
Any of the superbraid fishing lines will work. Power-Pro, Fireline, but my choice is 10lb test Spiderwire Braid. Even though it says 10 lb test, you can hang a 15lb/17lb weight on it before it breaks.
It is very thin. The same diameter as 2lb monofilament. Has absolutely no stretch, and comes in a moss green color that seems to dissapear.
It's down side is that it's not very abraision resistant, is so thin that it can give you a paper cut, and so smooth that the knots can slip if you don't glue them.
About $13 per100 yards, at your friendly fishing store
uglystick is offline Find More Posts by uglystick
Old Jan 24, 2004, 06:54 PM
Robert Hoffman is offline
Find More Posts by Robert Hoffman
Over Engineered
Robert Hoffman's Avatar
Michigan
Joined Jul 2002
I have used the plastic coated leader material they sell at Gander Mountain. It is 20lb test steel cable, can be purchased in other strengths, that is covered in black plasic. It is very light and it has no stretch. Most of the fishing lines do stretch.
Robert Hoffman is offline Find More Posts by Robert Hoffman
Old Jan 24, 2004, 08:02 PM
TimOBrien is offline
Find More Posts by TimOBrien
Palm City, FL
Joined Dec 2000
30lb test Spiderwire (fishing line).
Good stuff.
TimOBrien is offline Find More Posts by TimOBrien
Old Jan 24, 2004, 08:39 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Careful with Kevlar it is not UV resistant.
I have used Berkley and other brands of 10lb stainless stainless from stores that sell saltwater fishing tackle.
I've also used 10 lb Firewire. Walmart sells it.
I've got some 25lb firewire but have not used it yet.
You can use crimp sleeves (or small brass or aluminum tube)
I pass the line through the sleeve, thru the horn, thru the sleeve, around and thru the sleeve again. I keep passing it thru the sleeve until I cannot get it thru anymore. Then crimp it and put on a drop of thin CA to lock it in.
feathermerchant is offline Find More Posts by feathermerchant
Old Jan 24, 2004, 10:57 PM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
Another Spiderwire vote.
Kevin Murray is offline Find More Posts by Kevin Murray
Old Jan 25, 2004, 07:25 AM
K4UAV
dalbert02's Avatar
Miami, FL
Joined Jul 2003
Ugly sticks,
You said Spider wire "... so smooth that the knots can slip if you don't glue them. " Don't you hate it when that happens when you have a 40lb bull dolphin on the other end?
Old Jan 25, 2004, 10:38 AM
Joined Nov 2002
Dal, Yeah, I think I'd hate that. But if I ever hooked one that big, I wouldn,t lose it because of a knot.
I use a mono leader with a 10x10, or albright knot to the braid. They don't slip. That wouldn't work in a airplane pull-pull system though. :-)
Old Jan 25, 2004, 12:39 PM
USA, NC, Greenville
Joined Dec 1999
You mean you caught Flipper ? Well I guess it's good that he got away then. Would hate to end that high paying film carrer early.
Old Jan 25, 2004, 02:33 PM
Dax is offline
Dax
Find More Posts by Dax
Dax
There is no spoon
Dax's Avatar
Vancouver BC Canada
Joined Aug 2002
two words
dental floss
Dax is offline Find More Posts by Dax
Old Jan 25, 2004, 02:52 PM
tekochip is offline
Find More Posts by tekochip
tekochip's Avatar
West Dundee, IL, USA
Joined Jul 2001
More Spiderwire
tekochip is offline Find More Posts by tekochip
Old Jan 25, 2004, 08:56 PM
K4UAV
dalbert02's Avatar
Miami, FL
Joined Jul 2003
dolphin as in Mahi-Mahi or dorado not dolphin as in bottle-nose porpoise. You need to spend some time on the water!
how to start the engine without pull start cable bluice79 Motorcycles 12 Sep 20, 2004 08:37 AM
Pull Pull Cable Linkage Setups? And Misc Kulbutin Build Questions? Z06kal Slope 7 Aug 02, 2004 09:56 PM
