Old Dec 02, 2001, 10:20 AM
squelchF18 is offline
Find More Posts by squelchF18
www.dynamoelectrics.com
squelchF18's Avatar
United States, TN, Collierville
Joined Sep 2001
Battery cooling in ice water?
In order to cool my batteries faster, I thought about putting them in zip lock bags and droping them into an ice chest with ice.
Can this cause any damage to my packs, or is there any other reason why I should not do this?
squelchF18 is offline Find More Posts by squelchF18
Old Dec 02, 2001, 11:15 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
It may shock the cells and cause uneven cooling, maybe even warp the cases! That is awful thin metal for the cell case.
If you want to cool them faster, try using a cold cloth in front of the cooling fan. Just like a swamp cooler.
One of the best methods I heard to keep your cells good is to have 3 packs for the plane. 1 is flying, 1 is cooling, 1 is charging.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Dec 02, 2001, 12:16 PM
voyantus is offline
Find More Posts by voyantus
Denver Co
Joined Oct 2001
Along these same lines, I just installed a s500 in my T52 and it runs great. However, it REALLY heats up my RS 8 cell 1600 NiMH batts. How bad is this and what batt set up would be better if any? I get good duration, I just don't want to fry a battery.
Brian
voyantus is offline Find More Posts by voyantus
Old Dec 02, 2001, 02:38 PM
thin wing is offline
Find More Posts by thin wing
ireland
Joined Apr 2001
ni mh hates heat
S500 uses a lot of amps and on my pylon sports racer on a cut down 6*6 now 5*6 it uses 20 plus amps with my 8* 800ARS so flights are short and fast
1600 nimh good for 4 amps continious and 8 amps in bursts and exceeding 60 degrees celcius is sopposed to damage the nimh type so suggest change to
nicad sanyo 800 ars best below 20 amps
ni cad cp1300 33grams
nicad cp1700 44grams
nimh panasonic 2000 44 grams able to do 20 amps sort of
nimh panasonic 3000 60 grams able to do 30 amps
loads off threads on ezone for this but if you do amps suggest cp nicads as nimh reputed to give 600 charges and many of my nicads have probably evxceed 800 cycles and nicadf can take heat is cheaper land takes some severe crashes and mischarging from faulty chargers
FLY low and swat the fly s
David
thin wing is offline Find More Posts by thin wing
Old Dec 02, 2001, 04:49 PM
voyantus is offline
Denver Co
Joined Oct 2001
Thanks David. I like the duration the NiMH gives so I may try the Panasonics. I appreciate the input.
Brian
Battery Cooling in A4 jEPE mitc99kd Electric Ducted Fan Jet Talk 9 Feb 28, 2003 05:36 AM
Connecting battery packs in series BillM Power Systems 8 Jul 11, 2001 11:03 PM
Battery Source in Canada? engr Electric Plane Talk 1 Jul 02, 2001 08:45 PM
twinjet battery cooling damian Foamies (Kits) 15 May 17, 2001 02:41 AM
Good sources of battery packs in the UK? Cush Electric Plane Talk 5 May 10, 2001 04:56 PM
