Old Jun 26, 2013, 06:34 AM
socommk23 is offline
Find More Posts by socommk23
always looking for clouds
socommk23's Avatar
Joined Aug 2010
thrust angle?
hey guys. just completed the tiger trainer brushless conversion.
massive motor and 15" prop.
the combination creates a massive torque reaction while on power.
the motor is set straight and I believe changing the thrust angle could help eliminate or at least reduce this. but in what direction?
from behind the prop, the prop rotates clockwise and the a/c turns to the left on power.
thanks for your help in advance.
this is the a/c in action.
tiger tug (4 min 3 sec)
it has been converted from tri gear to tail dragger now.
tiger tug maiden towing flights (3 min 59 sec)
socommk23 is offline Find More Posts by socommk23
Old Jun 26, 2013, 06:49 AM
ChillPhatCat is online now
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
Thrust angle won't help you with torque, right thrust is primarily to counteract the spiral slipstream which twists around the body and hits the side of the rudder, causing the plane to yaw. What you need is a smaller propeller or longer wings.
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Jun 26, 2013, 10:07 AM
socommk23's Avatar
Joined Aug 2010
cheers....longer wings may be a possibility. hmmm
would the thrust angle change help it stop climbing when powering up in flight?
Old Jun 26, 2013, 01:44 PM
robbthepilot is offline
Find More Posts by robbthepilot
Victoria B.C. Canada
Joined Aug 2007
typically you wnat 2 or 3 degrees of right and down angle on the motor. Yes down thrust will help control the climb on throttle up. Also some throttle to elevator mix will help also. good luck
robbthepilot is offline Find More Posts by robbthepilot
Old Jun 26, 2013, 02:31 PM
AMA 537620
Joined Oct 2008
Yeah, sounds like you're packing plenty of power, so 3 degrees of down probably would be a good idea.
Old Jun 26, 2013, 02:39 PM
xrx1113 is offline
Find More Posts by xrx1113
xrx1113's Avatar
United States, FL, Lehigh Acres
Joined Aug 2011
+1 on down thrust it should not climb under power that gets old real fast and it makes landing a PITA.
xrx1113 is offline Find More Posts by xrx1113
Old Jun 26, 2013, 03:40 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Gonna disgree with some of the previous posts.. Right thrust WILL help, that's why you find it on most RC planes. try about three degrees to start with and i guarantee it will redudce the tendancy to turn left under power.
For the avoidance of doubt right thrust is when if you look at the plane from above the motor is angled to the right (i.e. the thrust line projected forward is off to the right)
While it's true that right thrust does not directly counter torque it does counter spiral slipstream effect and it counters torque indirectly in the same way as the rudder on your plane produces roll. Bottom line.. right thrust works!
Also a little down thrust will help with the excessive climbing, though some climbing is perfectly normal.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Jun 26, 2013, 04:16 PM
AMA 537620
Joined Oct 2008
I'm not disagreeing that it won't help counteract adverse yaw, but using it to counteract roll caused by too big of a propeller won't do much... That is, if he's already experiencing a roll when he applies power, right thrust is not going to "fix" it. I do believe that he should have a little right thrust in general just for a proper setup regardless of having too big of a propeller.
Old Jun 26, 2013, 04:21 PM
builderdude is online now
Find More Posts by builderdude
builderdude's Avatar
United States, TX
Joined Jun 2011
Yes, put a few degrees of right thrust on the engine along with down thrust.
builderdude is online now Find More Posts by builderdude
Old Jun 26, 2013, 05:41 PM
socommk23's Avatar
Joined Aug 2010
thanks guys. I will be playing with the thrust line setup.
just been out and aerotowed my brothers radian and the torque steering shall we call it does make it a handful. so ill be looking to sort it somehow.
towing the line (3 min 28 sec)
Old Jun 26, 2013, 06:37 PM
United States, TX
Joined Jun 2011
You could also try not using full throttle on take-off. Rather, ease up on the throttle and use enough to ROG, but not so much that it wants to ground loop.
Old Jun 26, 2013, 10:00 PM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Few degrees RIGHT and DOWN thrust ..... yep - most have it .. it works
BUT
reading the OP - as another says - the torque is too much and really the model needs to have a smaller prop ....
Large diameter creates torque ... pitch creates thrust / speed.
So careful reduction of prop can improve throttle response, reduce torque, still give the speed / thrust ...
Matching prop / motor / model is not only about going UP in prop ... it's both ways ...
Trying to fly a mis-matched model can be a disaster looking for a place to happen ... match it up and then enjoy the flying.
Nigel
solentlife is online now Find More Posts by solentlife
Old Jun 27, 2013, 02:52 PM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Taking off at 3/4 throttle and letting model lift off with little or no up-elevator may help avoid torque/spiral airflow reaction . Model should be able to fly level at 1/2 throttle, gain altitude at 3/4 to full throttle and lose altitude at around 1/4 throttle as in landing. Right thrust, plus gentle jabs of right rudder help to control yaw to left during takeoffs. Some down thrust helps to control nose-up tendency when applying sudden full throttle.
E-Challenged is online now Find More Posts by E-Challenged
Old Jun 28, 2013, 12:02 AM
Aberdeen
Joined Mar 2006
Prop doesn't look over-size to me? I don't see anything odd about the model that couldnt be adequately sorted by a few degrees of thrust offset. Often if we are used to prop sizes from i.c power then electric props seem huge. In fact it's not so much the electric props being huge as the i.c. props being ridiculously small (as is required to suit high revving engines)
FWIW I've got a 15" prop and about 1000-1100W or power on my 51" span AJ Slick 3D model and prop effects are no problem. Just add right thrust until the 'torque steering' goes away.. it will be fine.
Old Jun 28, 2013, 12:18 AM
solentlife's Avatar
Joined Jan 2010
The OP himself says in first post that the motor is massive and prop is 15" .. they match each other but based on his saying massive - indicates too big for the model.
As we know - it's not a case really of matching prop to motor ... but the combo to the model. As motor is already fitted - then prop needs to be reduced ... get the torque down to manageable level.
Nigel
Discussion engine thrust angle or cg.. bradharvy 3D / Fun Fly Fuel Planes 5 Apr 20, 2013 07:23 AM
Question prop rotation/thrust angle question Se5me Beginner Training Area (Aircraft-Electric) 6 Apr 15, 2013 07:32 AM
Question ESM FW-190 engine thrust angle 600Bob Fuel Warbirds 2 Mar 22, 2013 03:28 PM
Help! thrust angle cfiguy4670 Sport Planes 2 Mar 14, 2013 10:45 AM
Discussion Blu Baby Thrust Angle Questions ideal_trucks Foamies (Scratchbuilt) 6 Feb 25, 2013 05:33 PM
