Old Jan 23, 2004, 07:20 AM
bowenm is offline
Find More Posts by bowenm
Solihull, UK
Joined Jan 2004
Charging 7 cell nicads with TX 9.6V charger
I am trying to keep the cost down when buying my first set of kit
Is there any way I could use a charger designed to charge a TX 9.6V pack (60 ma or 120 ma charging current) to charge a 270mah or 400mah 6 or 7 cell nicad flightpack?
Presumably I could do a timed charge but what happens if forget and leave it charging?
bowenm is offline Find More Posts by bowenm
Old Jan 23, 2004, 04:23 PM
jgmtens is offline
Find More Posts by jgmtens
but it's a nice obsession
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
Yes, you can do it but don't if you think you will forget.
Generally a charge rate of C/10 is safe to leave on, but you've got more than that.
Charge time is C/charge rate plus 40% for loss.
Always feel the batts once in a while to make sure they are not getting too hot!
Jon
jgmtens is offline Find More Posts by jgmtens
Old Jan 23, 2004, 04:54 PM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
And remember that you will get more than the normal current out of the charger because it's only has a lower voltage it needs to drive. Typically you'll get 15% more into 7 cells (68/135mA) and up to 25% more into 6 cells (75/150 ma) so reduce the charge time accordingly.
Steve
steve lewin is offline Find More Posts by steve lewin
charging 3 cell lipo with 12v? tomi Batteries and Chargers 6 Mar 26, 2004 02:18 PM
charging at c/10 with tx-charger Yeti Beginner Training Area (Aircraft-Electric) 3 May 15, 2003 03:17 PM
Can I run a 7 cell ESC with 8 NiMh dr.E Power Systems 2 Jul 20, 2001 11:10 PM
