Feb 21, 2004, 11:53 PM
gainesville FL
Joined Jan 2002
i made that little system...(no connectors) for some other micro model i meant to make. the wiring lengths don't quite match this plane...I have some excess here and there...
is it worth it to chop off all your connectors....risk burning your rx by removing all pins...remove the bottoms of servos....i dunno...it only saves a few grams....not even sure if it was half an ounce....but i guess weight saved is weight saved....now i have enough extra capacity to carry a small camera.....yeah right.
it looks like if i don't want to use landing gear then i have to move that battery forward a bit...may have to move the mount too
oh..and my accident...
i launched....then realize the cg was a bit too far back...woops...nose kept raising..tail wanted to drop....i gave it full throttle....because i know when my 3d planes with extreme rear cg act like that they fly a bit better with some speed.
I think my edp 50 is dying....full throttle didn't help that much.
i managed turn around....then got confused....felt like a newbie...but the small plane confused me when i turned...suddenly couldn't tell wether i had turned it all the way or not...it came down slowly....while i was busy trying to reorient myself...sometimes i'd have it...sometimes not....it finally hit a bush then buried the nose in the ground as i cut the throttle.
the pics u see are after the crash....where's the damage? the only visible right now is a slight ding on the stab leading edge.
