Old Jun 22, 2013, 11:33 PM
skyzking is offline
Find More Posts by skyzking
smokin electrons...
skyzking's Avatar
Brisbane, Australia
Joined Jan 2007
High Performance 70mm fan units
Hi guys, I'm after specs on 70mm edf unit and motor combos to go as fast as possible on that size of jet. I can use up to 10S on this airframe. What are the proven combos people have been using?
skyzking is offline Find More Posts by skyzking
Old Jun 23, 2013, 12:35 AM
viperviper is online now
Find More Posts by viperviper
Antarctica
Joined Apr 2012
Try beating this speed...found this in youtube.
Phase 3 F-16 Speed Run, 177mph! (0 min 53 sec)
viperviper is online now Find More Posts by viperviper
Old Jun 23, 2013, 07:00 AM
Boogie_ is offline
Find More Posts by Boogie_
killed another thread
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Isn't that tailslide's Phase 3 F-16?
I've got two jets with HET 6904 fans, ARC 28-58-1 motors on 6s. Makes 2000W.
Clocked my F-105 at 136mph. My F-9 Cougar is a little slower but has a more draggy airframe.
My batteries are up to the task but definitely not in the hi-po class.
I imagine with some TP batts I would be pushing 150mph.
I've read that the Typhoon 1W-40 will give about the same power at slightly lower amps.
At the low end of the money spectrum you can't beat the WeMo or HET fans.
Boogie_ is offline Find More Posts by Boogie_
Old Jun 23, 2013, 09:10 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Yes it is tailslid5.0's red beast (rip) I think he did 5s on a arc 48-1 turn
My personal best was a combination of a lander shroud, a Cool 42 from gary@effluxrc and a wemo impeller on a Pulse 65c4200 5s, 60krpm 7+lbs @ 200amps on a CC180 and 5s 65c 4.5k batt. I put the set in an E-flite F-86 and made it 1/4 lap on maiden(smoked it) then glided around two laps to land, with stock gear hanging and taped on wings!(once upon a time)
edit, here's a graph from an ice 100 I cooked,
ApexAero is offline Find More Posts by ApexAero
Old Jun 23, 2013, 09:31 AM
ex-racr is online now
Find More Posts by ex-racr
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
If you want to put "stupid" power through a 70mm fan, IMHO, your best option is a Mach Alloy 70mm fan. Contact Gary at Efflux RC. He can help you.
Though the HET and Wemo are good and can stay together at crazy rpm's, there is the high probability of the rotor disintegrating. That is not nearly as likely with a single piece metal rotor.
No matter what over 2K watts is inherently dangerous. Safety has to come first.
Be safe in this pursuit,
Terry
-oh, also Tam at Tamjets can put together a 70mm power system to your exact specifications, but you will have to pony up the money to pay for it. What you'd get is a perfectly balanced fan in an edf housing guaranteed to stay together at a very high power level
ex-racr is online now Find More Posts by ex-racr
Old Jun 23, 2013, 12:46 PM
capt soap is online now
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
No warrentee on that cool 42????? should last at least 12 speed runs?
capt soap is online now Find More Posts by capt soap
Old Jun 23, 2013, 06:50 PM
skyzking is offline
smokin electrons...
skyzking's Avatar
Brisbane, Australia
Joined Jan 2007
So it seems i need to stay away from those 10-12 blade fans and go for something with 4-5 blades. The HET site recommends the 1w-40, 6904 on 6S. Crazy rpm's but i cant image it staying together for to long.
The alloy fans seem the way to go if you want something to stay intact at those rpm's.
Old Jun 23, 2013, 07:35 PM
MustangAce17 is online now
Find More Posts by MustangAce17
3d and EDF, some scale
MustangAce17's Avatar
United States, FL, Ocala
Joined Sep 2005
Not 70mm but my 60mm fan setup that smoked today after 50 or so flights read 66,721 rpm and 1924 watts, it is a mix of parts though. 6s 2200 50c lipos
MustangAce17 is online now Find More Posts by MustangAce17
Old Jun 23, 2013, 07:37 PM
airboss/oc is offline
Find More Posts by airboss/oc
California Style
airboss/oc's Avatar
United States, CA, El Mirage
Joined May 2007
has anyone tested with the new Hoffman 70mm ?
airboss/oc is offline Find More Posts by airboss/oc
Old Jun 23, 2013, 10:54 PM
Double E is offline
Find More Posts by Double E
Double E's Avatar
Atlanta, GA
Joined Mar 2009
Did he just say "New" Hoffman 70?
Double E is offline Find More Posts by Double E
Old Jun 23, 2013, 10:55 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Like Bob said...."nobody remember's the 2nd place guy". I do!! LOL
Here's my excuse......It was the second EDF I ever built.
This is was my entry at the online race that culminated in "live" in Las Vegas.
Tailslide, Air Sally, and myself were the only participants to show up for the live race.
173 mph Phase 3, F 16 (0 min 44 sec)
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Jun 23, 2013, 10:59 PM
Double E is offline
Double E's Avatar
Atlanta, GA
Joined Mar 2009
Fan Jets USA has the 70mm aluminum Tornado fans and ARC motors for a ballistic setup.
Old Jun 23, 2013, 11:03 PM
efflux RC's Avatar
Joined Aug 2009
This is my Mach 70 powered Phase 3, F-13 "demo" jet that sat on the shelf for two years, and just recently began flying after a crash back then.
It does 160 (flat and level, UW/DW avg'd) on 6s,
The motor in it now is 3180kv. The HET 1W-40 is 3300 kv. I hope to run this motor in something soon.
Your going to have to deal with huge amps on 6s in any fan if your looking for 2KW+.
For even more more speed go with something like the Mega 16-45-1 on 7-8s (8 would be experimental). One of our customers will be running the 16-45-1HSB on 7-8 in our Composite F-20 soon.
The are also lower kv and longer Megas motors available for higher cell counts.
Phase 3, F16 Demo jet (2 min 52 sec)
I've heard that even a well balanced HET rotor will not survive the 1W-40 on 6s, (I've never built that particular set up.)
So I really have no comment either way.
We don't know what the limits of the Mach rotor are. The fast I've spun one on the bench was 60250 rpm
Site Sponsor
Old Jun 23, 2013, 11:21 PM
efflux RC's Avatar
Joined Aug 2009
200A .
I've been waiting for you to come up with something real fast again, for some time now. whatcha waitin' for Tom?
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Jun 23, 2013, 11:46 PM
capt soap's Avatar
dallas tx
Joined Jun 2003
Gary, what lipo did you have in your f-16 at the time?
Sold 2 70mm fan units and ESCs Beancounter Aircraft - Electric - Jets (FS/W) 1 Apr 30, 2013 01:39 AM
For Sale Shulman 80mm High Performance alloy fan/6S motor houstonderk Aircraft - Electric - Power Systems (FS/W) 1 Mar 25, 2013 02:51 PM
Sold 70mm EDF Fan units. Two for $14 shipped! The Don Aircraft - Electric - Jets (FS/W) 19 Mar 19, 2013 09:39 PM
Sold 1 NEW and 1 like new Alfa Fan Units w/Motors and High Performance Rotors Kevin Greene Aircraft - Electric - Jets (FS/W) 2 Sep 24, 2010 11:52 AM
