Old Jan 22, 2004, 02:01 PM
rpvpilot is offline
Find More Posts by rpvpilot
rpvpilot's Avatar
United States, AZ, Yuma
Joined Oct 2003
An idea for mounting your Hacker in a GWS gearbox...
This idea came to me after I bought a Hacker B-20/26 but already had a motor stick installed on my plane to mount the GWS gearbox.
1. Remove the shaft and bearings from the gearbox. (Unless you just buy the gearbox plain)
2. Shave the front flush where the front bearing was.
3. I used a Hitec servo wheel, the large one that comes with the HS-700. Drill the center out to the correct size and also drill the two holes next to it for the mounting screws. I used the template that came with the motor.
4. Drill the four holes in the servo wheel to match up with the outer holes in the GWS gearbox. I drilled them just big enough so that the screws I used slid right through.
Insert the four screws, I used standard servo mounting screws. They will just self-tap into the gearbox.
5. Mount the Hacker and you're done. From there it just mounts like any GWS motor does, just slap on the stick.
For all of you who are using zip ties to throw your motor on, try this, you'll never go back.
rpvpilot is offline Find More Posts by rpvpilot
Old Jan 22, 2004, 02:03 PM
rpvpilot is offline
rpvpilot's Avatar
Joined Oct 2003
side
Old Jan 22, 2004, 03:48 PM
raptor22 is offline
Find More Posts by raptor22
Striving to Rip the Bring
raptor22's Avatar
San Diego, socal, USA, North America, Earth, Solar System, the Orion arm, Milky way, Universe
Joined Apr 2003
hmmmm...interesting. Elimenates expensive fussy integrated frontplate hacker gearboxes, saves money and effort throught the elimination, and get rid of zip ties.
Cool.
--Alex
raptor22 is offline Find More Posts by raptor22
Fit an MP Jet 25/25-26 in a GWS gearbox? JREEVES Power Systems 7 Aug 13, 2004 06:22 PM
Question commercial swap out for cd rom motor in gws 300 gearbox, help needed danstrider Power Systems 11 Aug 13, 2004 03:08 PM
Hacker in GWS Gearbox roboracing Power Systems 2 Nov 17, 2003 10:04 AM
Mounting a Astro 10 in a GWS gearbox GW Power Systems 2 Oct 22, 2003 10:55 PM
Mounting APC prop on GWS gearbox mt_100 Parkflyers 18 Jun 06, 2001 03:07 PM
