Old Jun 21, 2013, 07:44 AM
wololo7 is offline
Find More Posts by wololo7
Lithuania, Kaunas County, Kaunas
Joined Jun 2013
Budget FPV Quadrocopter
Hi everyone.
After 2 years of flying foamies I want to try something new. I'm ready to spend 400USD tops to build an FPV quadrocopter. I have the camera, the radio (Spektrum DX6i), the charger, the monitor for fpv. Basically all I need is the quadrocopter and fpv receiver and transmitter. What is the best bang for the buck setup? My priority is stability, not speed.
wololo7 is offline Find More Posts by wololo7
Old Jun 21, 2013, 08:44 AM
Bandsawbob is offline
Find More Posts by Bandsawbob
Bandsawbob's Avatar
United States, LA, Slidell
Joined Feb 2013
Well some might disagree but dji now sells a naza lite controller
That and the f450 flame wheel motor / esc kit is a straight forward set up
The naza is super stable and very easy to fly.
If you want to go cheaper there's always those
Kits on ebay with the kk board. But if your more interested in flying than crashing I would just spring for the naza .
Bandsawbob is offline Find More Posts by Bandsawbob
Old Jun 21, 2013, 12:39 PM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Originally Posted by wololo7 View Post
Hi everyone.
Bang for your buck, the multi-wii has every other flight controller beat.
Its not newb friendly, but once setup its nearly unbeatable.
If you want, i have a ARF quad for sale in your price range: http://www.rcgroups.com/forums/showthread.php?t=1916081
For $50 more I will throw in a 1280mhz video TX/RX combo, should get your FPV'n in a few hours
AcroFPV is offline Find More Posts by AcroFPV
Old Jun 21, 2013, 12:41 PM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
The F450 frame is not very FPV friendly. There is not alot of room for electronics. And for FPV, you want your vTX as far from the receiver as possible.
Also, crashing is most often pilot error and rarely flight control error. I have seen plenty of Naza's crash.
Old Jun 21, 2013, 12:59 PM
Bandsawbob's Avatar
Joined Feb 2013
See I knew that was coming lol
I would have bet 1000.00 bucks on it
Old Jun 21, 2013, 01:00 PM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
knew what was coming?
Old Jun 21, 2013, 02:08 PM
wololo7 is offline
Joined Jun 2013
Thanks for the offer subaru4wd, but I want to buy it new. I want a stable platform for learning and FPV. A 450mm is quite small. All the gear would not fit. Even if It would, It would be a huge mess of wires. And I live overseas, so customs taxes would be huge. I want it new. The FPV range hould be about 1km. My radio is a bottleneck here.
My planned setup:
Frame: http://www.hobbyking.com/hobbyking/s...ame_550mm.html
Flight controller: http://www.hobbyking.com/hobbyking/s...PS_Module.html
Motors:
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
ESCs:
http://www.hobbyking.com/hobbyking/s...ontroller.html + a programming card.
Props:
http://www.hobbyking.com/hobbyking/s...5SF_4_pc_.html
http://www.hobbyking.com/hobbyking/s...Rotation_.html
Bullet plugs 30 units http://www.hobbyking.com/hobbyking/s...IRS_20PC_.html
Some adapters:
http://www.hobbyking.com/hobbyking/s...er_1_set_.html
Still deciding on the Video transmitter/receiver part. And I need an OSD. I'll add a bluetooth module too.
Old Jun 21, 2013, 02:26 PM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
I wouldnt trust the quality control of HobbyKing when it comes to flight controllers. If you look, there's a thread here about that flight controller and some defects in manufacturing.
Also, for OSD, look into the MinimOSD. You can upload custom firmware that makes it compatible with MultiWii.
I would also advise against those props. Look into APC or some Carbon/Nylon props.
Also, that 550 frame has less room on it than a standard 450 frame. The FPV spider is probably the best setup for FPV, as you can put the vTX on one end, and the Receiver on the other.
Old Jun 21, 2013, 02:36 PM
wololo7 is offline
Joined Jun 2013
What flight controller should I use then? My budget is quite limited. The frame is this? http://www.goodluckbuy.com/fiber-gla...lticopter.html I'll take note about minimosd.
Old Jun 21, 2013, 02:43 PM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
I have that frame, and its worth the price. Expect to wait 2 weeks to receive it.
If you want quality at an unbeatable price, look here: http://witespyquad.gostorego.com/fli...ntrollers.html
Old Jun 21, 2013, 02:57 PM
Fotophanatic is offline
Find More Posts by Fotophanatic
Build, Fly, Crash, Repeat
Fotophanatic's Avatar
United States, OK, Blanchard
Joined Apr 2012
I have witespy's MultiWii PRO EZ3.0 and GPS. Got it for about $80 plus shipping. Super nice and Paul is awesome. My 2
Fotophanatic is offline Find More Posts by Fotophanatic
Old Jun 21, 2013, 03:39 PM
wololo7 is offline
Joined Jun 2013
What's the optimal prop for such setup? What vrx and vtx should I choose? Are flashed esc's worth it? Or I'll be good with Turnigy Plush'es?
Old Jun 21, 2013, 04:05 PM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
SimonK escs are worth it.
Props depend on what motors you run.
Old Jun 22, 2013, 01:10 AM
wololo7 is offline
Joined Jun 2013
So the ESCs should be these? http://www.hobbyking.com/hobbyking/s...C_3A_UBEC.html
The motors I'm planning to run are these, I don't know which props are good and cheap. I'll need a lot of them at first.
The VRX and VTX:
http://www.hobbyking.com/hobbyking/s...Tx_Rx_Set.html
I'll add 6dbi Wifi antenna's I have on both.
Discussion New Quadrocopter $350 Budget Build karan538 Multirotor Talk 5 Apr 10, 2013 02:36 PM
Sold FPV Quadrocopter Quadrixette 30, 9DOF MultiWII 2.2 FlyinGizm0 Aircraft - Electric - Multirotor (FS/W) 0 Mar 10, 2013 11:40 AM
Video EPIC HD FPV MOMENTS!!! X525 Quadrocopter Wind Turbine Fun. renekreher Electric Plane Talk 0 Feb 09, 2013 05:18 PM
Discussion Budget First-Time Quadrocopter Build NtiT Scratchbuilt Multirotors 25 Sep 08, 2012 04:20 PM
