Xuron Adjustable Wire Stripper - Model 505ST
Wire stripper and cutter that easily handles 12 to 26 awg (2.05mm - .405 mm) wire
Great new, high-quality combo tool from XURON!
A combination wire cutter and stripper for stranded wire featuring a thumb-adjustable dial cam for easily setting wire sizes from 12 to 26 AWG and storing the tool closed is being introduced by Xuron Corporation of Saco, Maine.
The Xuron Model 505ST Adjustable Stranded Wire Stripper-Cutter features a thumb-adjustable dial cam for changing wire sizes from 12 to 26 AWG (2.05 mm to 0.405 mm) that also acts as a closure, keeping the tool closed for storage. Designed for repeated cutting and stripping, this ergonomic hand tool has a Light-Touch return spring, non-slip Xuro-Rubber handle grips.
Made from alloyed steel, the Xuron Model 505ST Adjustable Stranded Wire Stripper-Cutter replaces the need for multiple tools and locks shut to easily fit into a tool kit or pocket. Ideally suited for assembly and field service use, this industrial-duty tool is comfortable to hold in small and large hands and is designed to provide optimum working leverage.
FOR MORE INFORMATION ON THE XURON WIRE STRIPPER AND OTHER XURON TOOLS, CLICK HERE!
There are no posts
Discussion servo horn to elevator piano wire adjustments mrdoodah Hand Launch 0 Jun 02, 2013 07:11 AM
Discussion Harlan rubber stripper and McLeod stripper FLYBOB54 Free Flight 4 May 31, 2013 02:49 PM
Mini-HowTo Adjustable width hot wire bow RWCLOUD Composites Fabrication 4 Mar 25, 2013 11:41 PM
Wanted Adjustable Xuron wire stripper arukum17 Aircraft - General - Miscellaneous (FS/W) 0 Feb 25, 2009 10:51 AM
Wire strippers Steve H. Aircraft - Electric - Airplanes (FS/W) 1 Oct 24, 2004 02:06 AM
