Heat Can Kill Your Multirotor!
Be careful when you go to fly your rig, make sure it is acclimated to the ambient temperature!
Acclimate your rig before you fly! Heat Can Kill Your Multirotor!
This is a warning! This past weekend while covering the 2013 XFC for Flyinggiants.com, I took two of my multirotors with me to get some aerial shots of the event. I had both my large XY8 and my smaller quad in the back seat of my car. I got to the flight line at 7:45 am and proceeded to shoot pics and videos all day. The multis sat in the car the entire time. At around 5 pm, I grabbed "El Guapo," the smaller patched-together quad I use to get still shots with my GoPro. This quad has been tuned to perfection and I have around 250+ flights on it. So I know what to expect with this rig. I pulled El Guapo out of the 115 degrees car. I popped on a battery, turned on the GoPro and took off.
Usually when I take off I'll ascend steadily and then fly El Guapo in a nice controlled sideways trajectory, getting shots of my subject the entire time. But this time, El Guapo was unresponsive, and suddenly started to jet right, so I corrected and it jetted left, then it spun around on it's yaw axis. I have to be honest, I was shocked, as El Guapo has been flawless and is always predictable. I fought to get El Guapo down, and at about fifteen feet, it jetted to the right, flipped and took a small dirt nap. I ran over to it and was pretty surprised at how little damage it had. I had broken a prop and popped the plastic bolts that held the FC on the rig.
Yesterday I got caught up with some of my work from being at the XFC and had a chance to fix El Guapo. I reattached the FC, fitted some new props on to the airframe and gave the rig a test. It was right back to being predictable and rock solid. And that is when it hit me. I never gave the rig a chance to acclimate to the ambient temperature before I took off. El Guapo was sitting in a 110 - 115 deg car and I pulled it out, fired it up in the 78 degrees ambient temperature and expected it to perform as it does usually. I think that the sensitive electronics in our rigs can be affected by drastic temperature changes, and I would advise letting your rig acclimate to the ambient temperature before taking off. Personally, I was very happy I did not fly my big rig, as crashing that would have been horrible.
This advice may not apply to all flight control systems, as perhaps some are not as sensitive to heat, but considering the delicate nature of electronics, and how simple it would be to take an extra few minutes to acclimate your rig, I do not see any harm in making this part of your pre-flight routine.
Old Jun 19, 2013, 05:22 PM
Roen is offline
Find More Posts by Roen
United States, VA, Norfolk
Joined Oct 2006
Pretty good information. I'm glad to hear that your rig did not suffer major damage. I think this should apply to any RC aircraft in general especially foamies considering how well insulated foamies are and how well they can trap heat for long periods.
Roen is offline Find More Posts by Roen
Old Jun 20, 2013, 12:20 AM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
My friend had a good sized quad with all goodies. Frame was some sort of plastic and his quad looked like a pretzel ! Quad was in car for several hours. Dealer of kit would not reply to his emails. Another local guy flew his T-Rex 500 heli and flight was fine. He got busy and never removed battery and let sit connected. Late that afternoon took heli out of trailor and battery burst and ozzed all over his new bird. $50.00 6 cell battery total loss and extensive mess all over his heli. Excess heat can do some harm.
dankar04 is offline Find More Posts by dankar04
Old Jun 20, 2013, 04:45 PM
MaydayMayday is offline
Find More Posts by MaydayMayday
MaydayMayday's Avatar
United States, CA, Fremont
Joined Jul 2011
To be honest I'm not sure how much I think your issue was a result of the heat. Not that it wasn't, but for electronic, anything under 120 or so shouldn't be affecting the systems. ALL of these individual components used in your system are used elsewhere that go through testing and have to handle stable for long periods of time. The components are designed that way, otherwise they won't sell.
I work with servers and 100 degrees isn't an unstable temp. Infact non of the components reach their limits until well after 150 degrees Fahrenheit.
Secondly, The temp was higher in your car than it was outside, then you had to walk to the area, setup and take off. Assuming the electronics were one for a minute or two before flight and however long in the air there is no reason there would be an issue.
Electronics should need to aclimate to temp or pressure, unless there is a control set that reads this like a AGL hold barometer that didn't get the proper settings before take off for the GL and was attempting to hold altitude and you were fighting it. maybe the return to home went rapid. either way I still don't see where the normal Earth temp ranges would affect this.
MaydayMayday is offline Find More Posts by MaydayMayday
Old Jun 21, 2013, 12:59 AM
jan michael is offline
Find More Posts by jan michael
www.solarenergyglow.com
jan michael's Avatar
Joined Feb 2013
im flyng my quad in the desert with out any problem. the temp rise from 100F - 110F @ noon to 4pm, i usually fly around 3-3:30pm. it because office time here is different they work 8am-12nn and 4pm-7pm, so that why i can take my free time in the afternoon. all is ok except for the motor that rise 15% above normal temperature. now august is coming it's time for me to stop flying, temp rise 110F -120 max and i experience already door knob getting hot on our accommodation.
jan michael is offline Find More Posts by jan michael
Old Jun 21, 2013, 08:27 PM
barchiola is offline
Find More Posts by barchiola
Closed Account
Joined Jul 2006
from what I understand, it's the gyros that don't like being asked to fly while acclimating to temperature changes. It isn't uncommon at all with multi-rotor heli's to have instability when they've been pulled from one temp/humidity environment and put into another without having had enough time to adjust. usually ten minutes or so will do the trick.
barchiola is offline Find More Posts by barchiola
Old Jun 23, 2013, 05:26 PM
chris1seto is offline
Find More Posts by chris1seto
Dragon Link/Labs Engineer
chris1seto's Avatar
Chesterfield, MO
Joined Nov 2010
This is one of the big reasons I do not - or try to avoid- flying in the cold. Also, heat can possibly damage some of the composites on your aircraft, and will absolutely be detrimental to the life of your battery if installed.
chris1seto is offline Find More Posts by chris1seto
Old Jun 23, 2013, 10:02 PM
helifrek is online now
Find More Posts by helifrek
3D Printing Enthusiast
helifrek's Avatar
United States, TN, Clarksville
Joined Feb 2004
Heat tends to have an affect on gyros, or at least it used to. I think in the Futaba GY401 manual it states something to the regards of letting the helicopter sit outside for about 10min before trying to fly. Electronics have come a long ways but I still let whatever I am flying acclimate to the temp before attempting to fly. g'luck and be safe.
helifrek is online now Find More Posts by helifrek
Old Jun 27, 2013, 03:52 PM
Sleepyc is offline
Find More Posts by Sleepyc
Closed Account
Joined Aug 2006
Yes this is the point exactly. I think a constant heat is fine, but going from one temp to another without letting the rig acclimate is the issue.
Sleepyc is offline Find More Posts by Sleepyc
Old Jul 11, 2013, 06:41 PM
RanchScout1 is offline
Find More Posts by RanchScout1
United States, TX, Clifton
Joined Mar 2013
100F outside here, my esc and motors are running at 130F-135F ! Is that too hot?
RanchScout1 is offline Find More Posts by RanchScout1
Old Jul 16, 2013, 12:36 AM
Disp0sablehero is offline
Find More Posts by Disp0sablehero
United States, CA, Marine Corps Base Camp Pendleton
Joined Jan 2013
I concur I recently took mine with me when I had to do training in 29 palms and it was quite the glitchy flight seeing it was 113 degrees outside so god knows what temp it reached prior to
Disp0sablehero is offline Find More Posts by Disp0sablehero
Discussion Did summer heat kill my chargers? Ron Pogue FMA Direct 7 Jun 26, 2013 10:11 AM
Discussion In Texas, you can kill a prostitute legally DenverJayhawk Life, The Universe, and Politics 182 Jun 19, 2013 03:35 PM
Discussion Canopy + heat = bad... but can it be fixed? grosbeak Crash Discussion 6 Apr 16, 2013 08:55 AM
Discussion Top mistakes that can kill your batteries! Please list gassper Batteries and Chargers 29 Sep 12, 2006 09:50 PM
Discussion When incompetance kills...you can count on your Union LTChip Life, The Universe, and Politics 62 Apr 13, 2006 08:26 PM
