Old Jun 18, 2013, 11:02 PM
DLGjunkyard is offline
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
Multiplex royal EVO DLG programming
Anybody got a direct link to Mark`s royal evo DLG program? I spent a long while searching for it with no luck. Found lots of full house info but need specific DLG mixes
DLGjunkyard is offline Find More Posts by DLGjunkyard
Old Jun 18, 2013, 11:53 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
I think I have it stashed someplace. Good place to start, but I'm running a setup that Charlie Morris walked me thru, and it's really nice.
I'd recommend it. Let me know if you want one or both.
Are you an experienced Evo Programmer, or just starting?
Gary
GaryO is offline Find More Posts by GaryO
Old Jun 19, 2013, 07:05 AM
Joined Apr 2010
Hi Gary. I guess you could call me a returning evo user. I never did get a full grasp on the programming but I managed to copy marks program into the radio in the past by mimicking his numbers in each menu.
Somewhere on the forum Mark had listed all his setting.
Ideally I would like Mark`s
Old Jun 19, 2013, 08:34 AM
GoFaster is online now
Find More Posts by GoFaster
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
I'd be interested in taking a look at Charlie's setup. Thanks.
GoFaster is online now Find More Posts by GoFaster
Old Jun 19, 2013, 12:49 PM
GaryO is offline
Joined Sep 2001
Okay, I'll have to look for Mark's, be a while, have no idea of where I might have stashed it.
Not quite certain how to do this, I'll start by describing the capabilities of what I'm using. While Charlie was good enough to sit down with me and work this out, it's somewhat different than his, because he flies a different mode. And for all I remember, I might have done some "creative" stuff a well. So hold me responsible, not Charlie.
Basic set up: I'll define what it does, and then get into how it does it.
Controls and Switches:
3 flap settings, Speed, Cruise, Thermal, off of a three position switch. Elevator mixing.
Additional flap setting, Launch, off the other three position switch. Overrides the normal settings. This setting controls launch trajectory after plane has rotated.
Momentary button controls launch rotation. Provides elevator and sometime flap control to rotate the plane. Mixing available on control surfaces
Momentary button control "push over" Can drop flaps and provide down elevator at top of climb (seldom used)
Landing flaps: Control is throttle stick, after being moved past the midpoint. Elevator compensation as flap goes down
Slider that can vary flap setting
Slider that can vary elevator setting
There are 4 flight phases, each has trim mixing available.
Dual rates are on a switch
Those are the basic capabilities, as I remember them.
Any questions? I'll see if I can take readable pictures of the screens, if that would be the best way to describe the set up.
Have you looked at Joedy's tutorial on the EVO? I seem to remember that Mark posted his set up as part of that.
Gary
Old Jun 19, 2013, 01:29 PM
Steve 0 is offline
Find More Posts by Steve 0
Slope-a-Dope
Steve 0's Avatar
United States, UT, Draper
Joined Dec 2012
does this help? it is from 2004 but Dr.D. posted it
http://www.rcgroups.com/forums/showthread.php?t=252845
Steve 0 is offline Find More Posts by Steve 0
Old Jun 19, 2013, 01:37 PM
Joined Apr 2010
Gary
That sounds awful familiar . I will scout around in that thread.
The points that interested me with Mark`s post was mainly the mix`s . I can always adjust/assign then to switches as such.
I used Drela`s program as more of a template. I been playing around with the 4-flap template but it gets confusing .
Old Jun 19, 2013, 01:38 PM
Joined Apr 2010
Thanks for the effort. Mark`s post is almost identical but for multiplex royal evo. Your post is for Airtronics.
Old Jun 19, 2013, 03:06 PM
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Gary, thanks for the info.
@DLGjunkyard, the following is Mark Drela's Evo definitions from the file section of the SALglider Yahoo group. It's really old, from 2006..
---8<---
SuperGee-II Royal Evo Program
Last revision May 06
Control summary
Standard Mode 2: aileron, elevator, rudder
Throttle stick drops flaperons for braking, enables extra Ail->Rud mix
M button is launch preset
J switch is 3-position camber control
E slider is elevator (speed) trim
I switch enables/disables dual rates
N switch enables/disables small amount of Ail->Rud mix
Setup Menu (button 1)
Mixer def. submenu
ELEVATR+
1 Elevator ---- asymm
2 Mixture ---- symm
3 Flap ---- asymm
4 Throttle ---- assym
5 Spoiler ---- asymm
AILERON+
1 Aileron ---- symm
2 Spoiler ---- asymm
3 Flap ---- asymm
4 Ele -Tr ---- asymm
5 Throttle ---- asymm
FLAP+
1 Flap ---- asymm
3 Aileron ---- asymm
RUDDER+
1 Rudder ---- symm
2 Ail -Tr ---- symm
3 Ail -Tr Mix1 symm
4 Ail -Tr Mix2 symm
5 Spoiler ---- symm
Assignment submenu
Controls sub-submenu
Throttle Lstick ^
Spoiler <M ^
Flap/RPM J> ^
Mixture E ^
Switches sub-submenu
DR-ai I> ^
DR-el I> ^
DR-ru I> ^
CombiSwitch <N v
Throttle-cut ---
Slot <L ^
Sum ---
Interval <O ^
Mix-1 Lstick v
Mix-2 <J ^
Mix-3 ---
Teacher ---
Main phase ---
Phases 1-3 ---
Control Menu (button 2)
Aileron submenu
D/R 80%
Trvl 100%
Expo -35%
Elevator submenu
D/R 80%
Trvl 100%
Expo -20%
Rudder submenu
D/R 85%
Trvl 100%
Expo -15%
Throttle submenu
Idle 10.0%
Slow 0.0s
Spoiler submenu
Run time 0.0s
Fixed value OFF
Flap submenu
Run time 0.0s
Fixed value OFF
Contr.switch submenu
Lstick v 0%
Mixer Menu (button 3)
CombiSwitch
CombiSwitch <N v
Ail > Rudder +30%
Ail.Diff.
Mode ON
Diff. 5%
ELEVATOR+
Elevator 80% 80%
Mixture ---- -3%
Flap -3% -3%
Throttle 10% 12%
Spoiler -6% OFF
AILERON+
Aileron ---- 45%
Spoiler OFF OFF
Flap 6% 7%
Ele -Tr 10% 10%
Throttle -48% -48%
RUDDER+
Rudder ---- 100%
Ail -Tr ---- 5%
Ail -Tr ---- 55% Lstick v
Ail -Tr ---- 15% J ^
Spoiler ---- 3%
Servo Menu (button 4)
Calibrate
Max-gain straight curve for each servo
Adjust Rev/Trm to set direction/trim
Aileron curves flatten beyond full brake position (no additional down movement)
Assignment (arbitrary, except for LR ordering of ailerons)
1 ELEVATR+
2 AILERON+ (left)
3 AILERON+ (right)
4 RUDDER+
Old Jun 19, 2013, 09:54 PM
C Robinson is offline
Find More Posts by C Robinson
C Robinson's Avatar
Oregon, USA
Joined Nov 2006
Royal Evo DLG Program
Hi Jeff,
I had Mark's program in my Evo for a season or two and it worked well. The only problem I found was that trim settings were global in all flight phases. RCPC helped me with a program that utilizes true flight phases and provides individual trim settings in all phases.
I have this program on a spread sheet written in a logic similar to the Evo programming steps and would be happy to send it to you. Just send me a PM with your e-mail address and I can forward the attachment to you (I don't have a pdf copy or I would attach it here).
Very happy owner of two Evo 9 tx
Craig
C Robinson is offline Find More Posts by C Robinson
Old Jun 19, 2013, 10:58 PM
GaryO is offline
Joined Sep 2001
Craig,
I'd be interested in it as well.
I think I'm using more mixes and controls than Mark, but it's a really good starting spot.
Gary
Old Jun 20, 2013, 06:37 AM
Joined Apr 2010
Originally Posted by C Robinson View Post
Hi Jeff,
Craig
PM sent Craig and thanks again.
Thanks to everyone that has contributed to this thread. I been pulling my hair out but learning this amazing radio. I have patients to burn when it comes to building but I must admit there is nothing I enjoy about programming radios. Must be a age thing I guess.
Old Jun 20, 2013, 01:27 PM
GaryO is offline
Joined Sep 2001
I'm about ready to post my setup, in the same format as posted by GoFaster. Any problem with doing that?
Gary
Old Jun 20, 2013, 01:32 PM
GaryO is offline
Joined Sep 2001
I have a copy of Joedy's tutorial on the EVO. 65 pages. Anyone interested?
Gary
Old Jun 20, 2013, 01:33 PM
Joined Apr 2010
Go ahead Gary. If you noticed I changed the thread title for future EVO search references.
Sold Royal Evo 7 Pro, XPS Evo module iva Aircraft - General - Radio Equipment (FS/W) 5 Jan 31, 2013 01:58 PM
Help! problems with royal EVO 9 and DLG programming tony w Hand Launch 31 Mar 20, 2009 06:48 AM
RD 8000 Programming - Dr. Drela? Rain City Flyer Hand Launch 2 Jul 16, 2004 01:59 PM
Royal Evo 9...need programming Ideas CDignition Radios 1 Feb 01, 2004 11:56 AM
Royal Evo programming question HarryC Radios 12 Jan 26, 2003 05:16 PM
