Old Jun 18, 2013, 08:40 PM
snipeworm is offline
Find More Posts by snipeworm
Snipe the Skies!
snipeworm's Avatar
United States, CA, Roseville
Joined Feb 2012
FAQ
FRSKY Taranis "How to" Thread
Welcome to the Taranis "How to thread". This thread is merely a place to compile information about how to use and modify your FRSKY Taranis radio. I will do my best to have the front page updated with all useful information as I get it. If you feel something is not here and should be then please let me know so that I can add it.
The major Success of this radio is based on the incredible software that has been created for free by the OpenTx team. Their work has made this radio extremely flexible while maintaining a very modest price tag. If you feel inclined to show your appreciation and support to the development team please consider a donation here.
Reviews
RC Model Reviews Part 1
RC Model Reviews part 2
Where to buy
There are now multiple Re-sellers of this radio so search around.
Aloft Hobbies USA
Microtechnics Belgium
T9Hobbysports Europe
snipeworm is offline Find More Posts by snipeworm
Old Jun 18, 2013, 08:41 PM
Snipe the Skies!
snipeworm's Avatar
Joined Feb 2012
Firmware, Setup, Programming, and important links
Firmware
Updating your firmware (Manual)
How to update your firmware video (Scott Page)
Help with getting your computer to talk to your Taranis
Setup
How to add a FBVS-01 to an X6R (Luv3d)
SBUS Decoder Setup (Dooz)
Binding 2 X8R receivers to get 16 pwm channels (In the tube deep)
Battery Calibration (Scott Page) (4:16)
Stick and pot calibration (Scott Page) (3:17)
Binding to a Reciever (Scott Page) (10:06)
Binding and Failsafe setup (MarHar)
Changing mode 2 to mode 1 (Scott Page)
Receiver and Sensor descriptions (Romolo Manfredini)
Connecting FAS to Vario (Koffer)
SBUS description and Setup (Cleon)
Vario Setup (Rotozuk)
Programming
Scott Page has made many very helpful videos. Find them on his youtube page here
Basic stick and programming tutorial (Scott Page)
Create and upload models with calibration from your computer (Scott Page)
Companion 9x Configuration Wizard tutorial (Scott Page)
Mixing Tutorial (MarHar)
Eagle Tree setup
Important Links
FRSKY Home page
Open RC Forum
Companion 9x Download page
RCsettings page, Great template recource!
Manual
FRSKY Taranis manual and user guide
Eflight Wiki (Awesome info!)
Compilation of user preset models
Using Telemetry to find a lost model (RC Model Reviews)
Countdown Timer Fix (The Areonut)
Pattern Flying Call out (Scott Page)
Open Tx University
Old Jun 18, 2013, 08:43 PM
Snipe the Skies!
snipeworm's Avatar
Joined Feb 2012
Taranis mods and accessories.
Stick and switch ends
The Taranis uses Futaba style stick threads (M3) Be sure to order accordingly!
Battery alternatives
It has been reported that the middle pin of the battery port does not lead anywhere, therefore it is safe to use a 2 cell lipo by smiply plugging in the balance port. Just be sure to NOT charge it with the transmitter!
LiFe (Graham 65)
How to add a LiFe charging circuit to your Taranis (Punkindrublik)
Li-Ion mod (Oz)
Modules
The Taranis accepts JR style modules.
Binding with external module (MarHar)
Spektrum DSM2
Setting up your DM9 with the Taranis (Daedalus66)
Orange DSM2
Mods
Reducing audio buzzing (Julez)
Hardware Mods (Julez)
Speaker Mod / Sound Upgrade (Punkindrublic)
Custom Trays
Old Jun 18, 2013, 09:32 PM
scott page is offline
Find More Posts by scott page
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
United States, WA, Richland
Joined May 2009
Custom Taranis Transmitter Tray
Here are the plans and some photos of a transmitter tray designed specifically for the Taranis. What makes this tray innovative is the use of the polycarbonate spring at the bottom that pushes the transmitter up and locks the Tx handle into place in the back. Without the Tx in place the bottom Poly spring sits at an angle of about 20 degrees forward, and when the tx is pushed down against it far enough the handle goes through the slot for it and locks into place.
It's made of 1/4" x 12" x 24" plexiglas / acrylic and 5" x 5" piece of of 0.093 in. thick polycarbonate / lexan. Uses four 12mm long 3mm cap screws, two 8mm long 3mm cap screws, 6 3 mm T-nuts (blind nuts), and 6 tapered washers. Basically it can be made for under $20.
The most difficult part may be locating a laser cutter to cut the parts - but they are hiding in the most interesting places -- like high school shop programs, or custom engraving or trophy shops. Ya just need to look around.
To bend the plexiglass use two C-clamps to secure two pieces of hard wood across the bend. Heat the area to bend for about 6 minutes with a heat gun and wear a glove on one hand! Heat both sides evenly. I alternate (using a stop watch) 60 seconds on one side moving the heat side to side ... and then 60 seconds on the other side, moving up and down along the area to be bent. Keep the heat gun at least an inch from the plexi or you risk overheating an area and causing it to bubble.
If the plexiglas is covered with paper it will need to be removed before making bends. If it's covered with plastic you can leave it until after the plexi is shaped. I HIGHLY RECOMMEND you use some scraps and practice making bends before you go for the main event.
If you look online -- or go to your local glass shop you can probably find all sorts of cool colors. If you go to home depot you'll find a choice of clear.
I included pictures below to give an idea of how to shape the materials. The zip files at the very bottom contain the plans.
EDIT: If you are looking for a comfortable strap check this out: http://www.bhphotovideo.com/c/produc..._Disgrace.html
UPDATE -- July 29 Updated Version12 ----> is the final version. This tray fits the Taranis perfectly.
scott page is offline Find More Posts by scott page
Old Jun 18, 2013, 10:39 PM
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
Joined May 2009
Icons for Taranis
I am maintaining an ongoing library of aircraft icons for the Taranis in openrcforums.com.
http://openrcforums.com/forum/viewtopic.php?f=92&t=3530
I'll be updating the first post in that forum to reflect the current state of the icons -- and posting when I make those updates in the thread. I'm attaching current icon library index below.
Old Jun 18, 2013, 11:35 PM
punkindrublik is online now
Find More Posts by punkindrublik
multirotormania.com
punkindrublik's Avatar
United States, CA, North Highlands
Joined Sep 2004
Subscribing...
EDIT: Sorry Snipe. I just realized you wanted to keep the first page clean. Go ahead and delete my posts if ya like. Sorry....
punkindrublik is online now Find More Posts by punkindrublik
Site Sponsor
Old Jun 18, 2013, 11:38 PM
multirotormania.com
Joined Sep 2004
Sweet! So can I get in on the pre-order??
Plans saved. Hopefully now I'll have some time to throw one together. Thanks Scott...
Site Sponsor
Old Jun 18, 2013, 11:45 PM
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
Joined May 2009
If somebody wanted to cut these and sell them flat they could probably make bank. If you look at buying a tray YIKES! Biggest problem with my design is it won't ship well because it's all one piece. That's not an accident. I avoid those with bolts.
The only thing that makes mine really novel is the method of holding the transmitter in place. It's a snap -- literally. Tx won't fall out, but is easy to remove.
Old Jun 18, 2013, 11:57 PM
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
Joined May 2009
Personalizing your Taranis
Short of custom painting your Taranis case, there are things you can do to dress it up a little. Just happens these things might also have some function as well.
I'm a big fan of stick ends. Whether you pinch or thumb your stick the right end can make a tremendous difference. Two sites to check out are: NOTE: When buying stick ends -- you want those that fit the Futaba sticks.
http://www.progressiverc.com/tools-a...ssories/rcstyx
and http://tinyurl.com/m59rtjh
Additionally you may find that the sticks are a bit soft for your preference. I've not made the change yet, but I'm pretty sure that http://www3.towerhobbies.com/cgi-bin...?&I=LXAEM7&P=7 will work great with the Taranis gimbals. I'll be doing that before this weekend and I'll report back.
Finally - no reason your sticks need to have all of the fun -- don't forget your switches.
Do a google search for "toggle switch extension" and have a ball looking at all of the extensions you can put on your toggles. I'm kinda partial to the 44 magnum shells myself.
Old Jun 19, 2013, 12:02 AM
multirotormania.com
Joined Sep 2004
You rock man. That was next on my list. I finger fly so I like the extra long sticks. I'd really like to find a nice pair with switches.
Thanks...
Site Sponsor
Old Jun 19, 2013, 12:22 AM
multirotormania.com
Joined Sep 2004
I'm gonna use carbon fiber lay up. I'm not gonna use your plans to the tee, but I'm definitely stealing some of your ideas!
Site Sponsor
Old Jun 19, 2013, 01:32 AM
--Oz-- is offline
Find More Posts by --Oz--
Quadaholic
--Oz--'s Avatar
United States, CA, Newport Beach
Joined Mar 2006
I have never flown a tray setup, but have many 5+ hour slope glider combat flights in a days flying (many weekends over 11 hours total flight (on a single battery) in a 2 day weekend) with neck strap's. Whats the real benefit to the large tray setup? (Blender, Margaritas, chips and salsa, pole dancers, )
--Oz-- is offline Find More Posts by --Oz--
Old Jun 19, 2013, 01:37 AM
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
Joined May 2009
Trays are an acquired taste, but like other acquired tastes you wonder how you ever got along without it (sort of like my smart phone).
And then add this sweetness and it's a slam dunk.
Old Jun 19, 2013, 01:47 AM
multirotormania.com
Joined Sep 2004
They're made for finger flyers (pinch grip). When you fly without actually gripping your transmitter, a tray can be very beneficial. It's certainly not necessary, but I really like the feel as I can completely relax the my hands while gently touching the sticks.
Site Sponsor
New Product FrSky Taranis - 16 Channels, Full Telemetry, RSSI Rotozuk Radios 48912 Today 03:59 PM
Discussion FrSky Taranis - Owners thread mud99 Radios 1976 Today 02:49 PM
Question FrSky Taranis - assimilating web info mcshaz Radios 10 Sep 10, 2015 02:34 PM
Discussion is the FrSky Taranis next step after Turnigy 9X 9Ch tormodnt Radios 3 Nov 30, 2014 06:58 PM
