Old Jun 18, 2013, 09:17 AM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
New Product
Just Aircraft Highlander
Been working on the drawings for awhile now, and am finally at the point where I can build the Highlander. Being a STOL type, this one needs to stay light, which won't be a problem due to the minimal structure involved. It's a simple airplane, but looks like it's going to be a terrific flyer.
The model is a 60" span and will be powered by a Suppo 2217 Outrunner with 5 ch. control.
P. Tritle is offline Find More Posts by P. Tritle
Old Jun 18, 2013, 09:19 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Begining at the Back
The vertical and horizontal stabilizers are the standard flat plate type, so nothing fancy here. They will be double braced, so no problem with strength in this area.
Old Jun 18, 2013, 09:23 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
The Fuselage
The fuselage is the typical stick framed sides that are joined at the landing gear beams and a couple of formers at the top of the cabin. The wing attachment is a little out of the ordinary on this one, with the root ribs extended away from the fuselage side. The wing will plug in in the usual way, but will stand off a bit from the cabin side.
Old Jun 18, 2013, 09:28 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Continuing On
The firewall was too wide to cut in one piece, so it was split in the middle and braced with 1/8 sq. balsa top and bottom. The instrument panel is wide also, so was laminated from two 1/16 parts with the front section cut away to keep things stiff, but light.
Old Jun 18, 2013, 09:33 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Moving Toward the Rear
The tail post was glued together and then the remaining formers were added. From there, the cabin side formes and the stringers were added to prett well button up the basic frame. The landing gears was set up next, and since this is a rough field airplane, several gussets were added to the landing gear beams to keep it all in place. Since the model is intended to fly light, only a minimal amount of added strength will be needed.
Old Jun 18, 2013, 09:37 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Building the Cowl
Since the cowl is BIG, doing a plastic section is going to create all kinds of problems for shipping, so the main cowl section is built up Former and Stringer style. The nose bowl can be carved from soft balsa, or in this case, blue foam. The main section was trued up and glued together, then the stringers were added. The motor mount was assembled and glued in place. The cowl is aligned with 4, 1/8" dowl pins and will be held in place with magnets.
Old Jun 18, 2013, 09:41 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Adding the Boot Cowl
The boot cowl was made up from file folder paper and glued in place with canopy 560 glue. The cabain brace was done using Fondu Sticks.
At thias point the fuselage is about wrapped up, so it's off to the wings next.
PAT
Old Jun 18, 2013, 10:06 AM
baldguy is offline
Find More Posts by baldguy
I eat glue
Canada, NS, Yarmouth
Joined Jul 2006
I have a birthday coming up Pat.
baldguy is offline Find More Posts by baldguy
Old Jun 18, 2013, 01:23 PM
Robert R is offline
Find More Posts by Robert R
It's a fine fiddly business.
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
Troy Woodland, the founder of Just Aircraft is a very good guy. He gave me all kinds of patient help when he was working at Flying K and I was working on a Flying K Skyraider I. He is a real gentleman. No one on the model field flight line will ever say, "O, it's only another Just Aircraft Highlander. Yawn."
Eventually the Pat's J-3 Kitten short kit I bought will morph into a Skyraider I.
Nice choice of weird and wonderful Pat.
Robert
Robert R is offline Find More Posts by Robert R
Latest blog entry: Hidden Kit Built Projects
Old Jun 18, 2013, 01:27 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Nope, they'll look at it and say, "That's a Husky!"
portablevcb is offline Find More Posts by portablevcb
Old Jun 18, 2013, 03:08 PM
KnifeEdge51 is online now
Find More Posts by KnifeEdge51
central AZ
Joined May 2002
Haha, probably.
Looks great, Pat! Keep us posted!
KnifeEdge51 is online now Find More Posts by KnifeEdge51
Old Jun 18, 2013, 05:13 PM
bdshort is offline
Find More Posts by bdshort
United States, AK, Ketchikan
Joined Mar 2008
I'm watching, like I do with every new plane Pat builds!
bdshort is offline Find More Posts by bdshort
Old Jun 18, 2013, 05:53 PM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
Looking at this video, I suppose it's a natural for a model airplane flying field.
Highlander Does Demo (6 min 45 sec)
Wolpertinger is offline Find More Posts by Wolpertinger
Old Jun 18, 2013, 06:22 PM
Yankeeone is offline
Find More Posts by Yankeeone
Yankeeone's Avatar
Madisonville, Tn
Joined Nov 2007
OK Pat. There is a GOOD panel shot in the above video. Interior on this one too??? Just a thought............................
TTFN The Yank
Yankeeone is offline Find More Posts by Yankeeone
Old Jun 19, 2013, 01:23 AM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Great Project - I own the full size one ! Just bought it. I can help with pictures if you like. Here is my Highlander. AMAZING aircraft.
OzparkPilot is offline Find More Posts by OzparkPilot
Model Aircraft have just Landed at DX Sandy90 DealExtreme RC 0 Apr 06, 2013 10:48 PM
Sold FS: Mad Aircraft "Highlander" EPP Sailplane Kit 7th Angel Aircraft - Sailplanes (FS/W) 3 Dec 09, 2010 06:41 AM
Mad Aircraft "Highlander" EPP Sailplane Kit Ratriver36 Sailplane Talk 5 Aug 11, 2009 07:16 PM
Sold MAD Aircraft Highlander 2M foamie glider Hostage-46 Aircraft - Sailplanes (FS/W) 4 Nov 21, 2008 05:38 AM
For Sale Mad Aircraft Highlander SkyKing RC Aircraft - Sailplanes (FS/W) 3 Apr 08, 2006 08:25 PM
