Espritmodel.com Heli Air
Old Jan 21, 2004, 07:36 PM
Joined Dec 2003
How to repair aerobird wing?
Hello All
I just almost logged another training flight on my Aerobird Challenger. This was my first flight since DIY repairs to the nose and the tail boom. The model flew absolutely perfectly for around 20 mins but all of the sudden the wings literally folded together on a tight turn and the model plummeted into the grond of a local winery.
After climbing over rows of vines I found the wings had folded along a crease that had been apparent for sometime but I had chosen to ignore. Is it possble to glue\repair the wing?. Other than the clean break the wing is in good condition. It seems to be made of compacted polystyrene covered with film. I have already ordered a new wing from one of the forums links but would like to have this second wing repaired as a backup. Any suggestions appreciated. Thanks.
magohn is offline Find More Posts by magohn
Old Jan 22, 2004, 12:42 PM
Now with more COWBELL!
U2Steve's Avatar
Lexington, KY, USA
Joined Mar 2001
Get some 15- or 30-minute epoxy (to give yourself some extra time), mix up a small amount, apply to the edges of the break, and join the pieces. Then put clear packing tape along the break on both sides (top and bottom), make sure everything's flat and straight, and let the glue cure.
To help prevent this on your new wing, apply strapping tape (the stuff with the glass fibers in it) to the underside of the wing, about 2" wide or so, from tip to tip. The fibers should run spanwise (from one wingtip to the other). This makes the wing resist bending under load- like in tight turns.
Good luck,
Steve
U2Steve is offline Find More Posts by U2Steve
Old Jan 22, 2004, 08:59 PM
Joined Dec 2003
Thanks Steve....took your suggestions and off to test a flight first thing in the AM
Old Jan 23, 2004, 02:00 PM
U2Steve's Avatar
Lexington, KY, USA
Joined Mar 2001
Hope it went well...Where are you? Here, it's about 15 F- indoor weather!!
Old Jan 23, 2004, 02:15 PM
Joined Dec 2003
Sunny CA.
Sonoma wine country. Balmy 60 deg, everyday is a flying day!
Discussion How to repair a carbon wing? Andrew McGregor Slope 2 Apr 06, 2007 06:25 PM
How to repair my wing Rburn99 Beginner Training Area (Aircraft-Electric) 6 Jul 28, 2004 02:10 PM
Help! How to repair carbon fiber wing? jhurault The Builders Workshop 1 Nov 12, 2003 12:20 PM
Aerobird wing...how much damage is too much damage... Away2Maine Parkflyers 3 Sep 04, 2003 03:25 PM
How to repair hollow molded wing??? TheTick Slope 16 Jul 09, 2003 12:51 AM
