Old Jan 21, 2004, 03:45 AM
ChrisP is offline
Find More Posts by ChrisP
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
Idea for an easy scratch built Grumman Hawkeye
I'll throw this idea out there in case anyone has a screaming need to do an easy stand-off scale Grumman Hawkeye. I just can't handle the additional project.
What you need is the fuselage from a Multiplex Twin Star and the wing from a Lanier U2.
Twin Star fuselage :
Vertical cut behind cockpit. Add a 5'' plug from blue foam. Sand to shape. Trough in the centre for the batteries. Let in/epoxy 3 pine stringers 3mm x 3mm (LH, RH and bottom) to tie it all in structurally.
Lanier U2 wing :
Re-cut root angle to skew TE slightly forwards. Reduce span to suit. The U2 wing nearly fits the fuselage anyway, but a tiny bit of sanding on the fuselage will be needed. Add foam on fuselage where there are any gaps and sand to shape.
Rework wing for ailerons. Add pine spar for strength, 10mm x 5mm.
Odds & ends :
Make engine nacelles as 4-sided balsa boxes. Aileron servos (1 per wing) in the rear end of the nacelles.
Make tail from flat foam and radome disc from blue foam. Turn disc with a highly geared miniature motor if you're adventurous. Otherwise attach disc with rubber bands to pylon 'just in case'....
Power : 2 geared 400's with Ramoser 4-bladed props.
There's a useful 3-view here :
http://members.fortunecity.com/inedesca/
Chris P
(That's what comes from watching 'The Final Countdown' last week on TV !)
ChrisP is offline Find More Posts by ChrisP
Old Jan 21, 2004, 09:18 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Sounds like you really need to do this.
And if you need any inspiration on the rotating radar scanner, this guy could help:
http://www.maxcim.com/customers/tu-4.html
Recall reading a recent US rag with details of how he modified a standard servo to turn the 'dome. Maybe at your size, just hold on with bands - but make sure it stays down, if it gets loose and starts flapping around, you ain't going to be happy
Great project - looking forwards to the photos!
D
Dereck is offline Find More Posts by Dereck
Slightly OT but i need help for a scratch built heli fuselage meatbomber Foamies (Kits) 4 Nov 04, 2004 10:53 AM
Power Advice for a scratch Built plane Ogre Power Systems 8 Oct 02, 2003 07:34 AM
Balsa Thickness for Scratch Built He-100 The Max-Q Electric Plane Talk 3 Aug 23, 2003 01:15 PM
Any online plans for scratch built helis? Acer Electric Heli Talk 2 Jan 25, 2002 03:30 AM
Anybody used firebird wings for scratch built slowflyer? kit basher Parkflyers 5 Jul 29, 2001 08:27 PM
