New! Vertigo Heli Motor
Castleís new Vertigo series of outrunner motors are the power plant your heli has been searching for.
Make 'em dizzy!
Whether youíre a professional pilot or a weekend stick jockey, Castleís new Vertigo series of outrunner motors are the power plant your heli has been searching for.
By using only the highest quality components and manufacturing methods, Castle engineers have been able to achieve efficiency rates surpassing the 90% mark, allowing you to fly for longer periods of time, perform the most extreme maneuvers, and do it all with extreme confidence. In addition, our high current CC Bullet connectors are pre-soldered to the wires ensuring the least amount of resistance between your ESC and motor. The case and fan of the Vertigo has also been designed to optimize heat dissipation and maximize airflow over the stator regardless of your flying style.
With bolt patterns to fit most 450 to 800 size helis, and paired with the new Castle Talon and Edge series of ESCs for optimal performance, everyone is capable of feeling Vertigo.
Learn more here.
Old Jun 13, 2013, 09:55 AM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
Nice to see another choice in the 700 class. I bet it would be perfect for an AP heli.
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old Jun 13, 2013, 09:58 AM
Planekiller1 is offline
Find More Posts by Planekiller1
Flash Time
Planekiller1's Avatar
United States, TX, Katy
Joined Mar 2013
Nice looking motor
Planekiller1 is offline Find More Posts by Planekiller1
Old Jun 13, 2013, 03:50 PM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Castle made a few Vertigo motors a couple of years and I have one. I didn’t think it was a very good motor and don’t fly it any more. It was not nearly as good as Scorpion. I sure hope that they have improved the design.
For a 700 size helicopter the Scorpion Ultimate is going to be very hard to beat ( 2-Year warranty, 230 amps and 10,000 watts). http://www.scorpionsystem.com/catalo..._4525_520_ult/
What's the warranty on Vertigo motors?
RC Man is online now Find More Posts by RC Man
Old Jun 13, 2013, 03:58 PM
United States
Joined Feb 2001
I just looked at the weights and those Vertigo motors are real boat anchors. The 700 weighs in at a whopping 694g. http://www.castlecreations.com/products/vertigo.html
Old Jun 13, 2013, 08:31 PM
mccollister911 is offline
Find More Posts by mccollister911
Joined Aug 2012
compare these vertigo motors with the KDE Direct XF lineup. Almost exact specs . Wonder what the idea was behind that
mccollister911 is offline Find More Posts by mccollister911
Old Jun 13, 2013, 09:00 PM
kavic5150 is offline
Find More Posts by kavic5150
Unregistered night flyer
kavic5150's Avatar
Joined Jul 2009
2 problems with the 450 size motor. Its 20 grams too heavy and where is the 1300 to 1900kv option for 450 size birds on 6s?
Usually its 1600 to 1900kv for a 6s 450 except for the mini Protos.
And why does the 500 size motor have a 6mm pinion? That will limit your pinion choices for sure.
kavic5150 is offline Find More Posts by kavic5150
Old Jun 14, 2013, 05:04 AM
United States
Joined Feb 2001
Why did they make them so very heavy?
With helicopters weight is very important.
That 6mm shaft is definitely going to add some dead weight to a 500.
Old Jun 14, 2013, 05:37 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
There is no termination designation in their specifications. There is only one 10p.
A 10p yy would be a torque monster
ApexAero is offline Find More Posts by ApexAero
Old Jun 16, 2013, 09:38 PM
badbill is offline
Find More Posts by badbill
Habitual Freeloader
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
If that little weight makes any difference in your 450 ) OR 700 ( then you're doing something wrong. Looks to me like they are making them to LAST, rather than to leave sheared shafts. There is a penalty for more endurance, and for more resistance to POWER. It is called weight. The difference will be worth it.
Bill Davenport
AMA 28141
badbill is offline Find More Posts by badbill
Old Jun 16, 2013, 10:00 PM
TheKingPhisher is offline
Find More Posts by TheKingPhisher
Joined Dec 2012
How do these compare to Scorpion motors?
TheKingPhisher is offline Find More Posts by TheKingPhisher
Reply With Quote  (Disabled)
Old Jun 17, 2013, 05:04 AM
United States
Joined Feb 2001
Much heavier
Old Jun 17, 2013, 11:04 AM
zen@lanset.com is offline
Find More Posts by zen@lanset.com
unlicensed helicopter nut
zen@lanset.com's Avatar
Berkeley, California
Joined Jan 2007
I think this is the benchmark a lot of people are going to apply. I have had output shafts break on early Align (430L) motors, but not once on Scorpion II 2221-8's. The 500-size Scorpions are pretty much bulletproof with 5 mm output shafts.
It will be interesting to see who actually buys the Vertigo. Doubtlessly we will see some reviews here if they do,.
zen@lanset.com is offline Find More Posts by zen@lanset.com
Old Jun 17, 2013, 07:31 PM
Sabin is offline
Find More Posts by Sabin
Every pilot has his crash
Canada, BC, Sechelt
Joined May 2008
I'm looking at the 450-size vertigo in comparison to the scorpion 2221-8 motor and I'm going...
it's heavier?
it's larger?
it costs more?
No max amp/wattage draw?
Unless the vertigo motor has a much higher amp handling capability, I'm having a REAL hard time justifying it over the Scorpion motor as my next heli motor.
Sabin is offline Find More Posts by Sabin
Old Jun 17, 2013, 08:54 PM
Patrick del Castillo is offline
Find More Posts by Patrick del Castillo
Patrick del Castillo's Avatar
Olathe,KS,USA
Joined Oct 2000
it's heavier?
it's larger?
it costs more?
Larger: yes
Heavier: yes
More powerful: yes
Too much power for most pilots: yes
These were designed to output as much power as the heli could handle. They are not a compromise -- they are designed for all-out flying.
Patrick del Castillo is offline Find More Posts by Patrick del Castillo
Sold CC Vertigo 3424-1800 Motor for 500 size heli ptflyer Aircraft - Electric - Power Systems (FS/W) 1 Jul 11, 2011 06:39 PM
Sold NIB Castle Creations Vertigo 3424-1800 Motor for 500 size heli lazor 22 Aircraft - Electric - Power Systems (FS/W) 2 Mar 17, 2011 01:14 PM
Discussion Vertigo Motors RC Man Castle Creations 26 Jun 27, 2010 04:50 AM
Motor mount for Vertigo 125 rosco 3D Flying 1 Sep 01, 2005 06:34 AM
