Old Jun 22, 2013, 10:59 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Hey Mark
That is a pretty damn good result for a first try. Thumbs up!
Originally Posted by flitelab View Post
Here was my first test with the VectorDD with stock setup.
Settings are included in the video as well:
http://www.youtube.com/watch?v=sQmvN4qbD7Q
Have a bit of vibration but not bad for first try.
The gimbal is nicely made and the wires route well to not add any resistance. I was able to tilt down 90 degrees and had good stabilization. Bit of jello at some points but I think that is light reflection off the props.
JussiH is offline Find More Posts by JussiH
Old Jun 22, 2013, 11:15 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Ya not bad. I think the isolation mounts might be a bit too firm for this frame perhaps. The camera may also be in the prop wash a bit as the gimbal is mounted center of the frame but it extends forward more than back a bit.
I may try another isolation mount just to compare.
It is a fine line between too solid and too soft with the mounts on brushless gimbals I have found.
So far those the VectorDD was the best "out of the box" test to date.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jun 22, 2013, 11:21 AM
Zlui is offline
Find More Posts by Zlui
Joined Aug 2012
Originally Posted by beamen View Post
Use the VectorDD_Silent profile (on the first page). I am using it - I haven't done any changes to it. Work's great for me.
How do I do that? I downloaded and unzipped the file, but it doesn't have an extension. When I try to load it as a profile, the file is not being shown. If I add .profile as file extension, it is shown, but I get an error loading it ...
Zlui is offline Find More Posts by Zlui
Old Jun 22, 2013, 11:32 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
You'll need to use the 2.0 b3 firmware, b4 gives an error on it.
I'm basically using that profile in my video but removed the silent setting as it can be more precise.
Site Sponsor
Old Jun 22, 2013, 01:40 PM
Askyvision is offline
Find More Posts by Askyvision
Albuquerque USA
United States, NM, Albuquerque
Joined Dec 2012
here all you have to do is add the .profile on the end. i went ahead and did that for you and for anyone have no idea what it is. unzip and you have it
Askyvision is offline Find More Posts by Askyvision
Old Jun 22, 2013, 01:44 PM
Zlui is offline
Joined Aug 2012
All right, thanks.
Old Jun 22, 2013, 03:15 PM
Merko is offline
Find More Posts by Merko
F550 Pilot
Merko's Avatar
Joined Feb 2012
Do you need any drivers to connect to the gimbal? Viacopter.eu doesnt provide any info about software\driver or anything..
Downloaded SimpleBGC GUI v2.0 b3, but i can't connect.
I don't get anything from the "Dropdown" menu where i can choose COMPORT etc..
Any idea?
Merko is offline Find More Posts by Merko
Old Jun 22, 2013, 03:41 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
Originally Posted by Merko View Post
Do you need any drivers to connect to the gimbal? Viacopter.eu doesnt provide any info about software or anything..
Any idea?
Sry, I will update the product page with that info.
The drivers for the onboard USB/serial converter can be found here:
http://www.silabs.com/products/mcu/p...cpdrivers.aspx
Old Jun 22, 2013, 04:05 PM
Merko is offline
F550 Pilot
Merko's Avatar
Joined Feb 2012
Thanks.
Installed those drivers, now i did atleast get a "COM" port in the dropdown, but i can't connect still.. :/
I tried both on my Desktop Win8 PC and Macbook Windows 7 with same result.
When i plug in the USB cable, the board makes a loud thin sound, and the red LED is on while green LED is flashing.. after 30 seconds or so, the green LED stops flashing and will just stay on, same with the red LED. is this normal behaviour?
Could it be i got a broken board or something?.. Really weird.
Edit: I got it working. I downloaded "AvrdudeR.zip" and " SimpleBGC_2_0b3.enc.hex" from www.simplebgc.com and flashed the board. now it works!
Edit2: How do you remove the sound from the board? so annoying!
Old Jun 22, 2013, 05:58 PM
beamen is offline
Find More Posts by beamen
Joined Sep 2011
Jussi, sorry for asking again, but I'm really looking forward to the 3 axis Is it weeks away, 1-2 months away or 3+ months away?
beamen is offline Find More Posts by beamen
Old Jun 22, 2013, 06:04 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Advanced Tab
Timings - PWM Frequency - Change to High.
However it is less precise and draws more power.
Site Sponsor
Old Jun 22, 2013, 07:14 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
I really cant say, but I expect to know a date soon. We are probably talking weeks - but I have said that before...so its not a promise
We have spent considerable time and effort into optimizing the 3rd axis driver, so that has meant delays. A final design decision was made recently, and I expect it to go to production soon.
Old Jun 22, 2013, 07:18 PM
beamen is offline
Joined Sep 2011
Epic. Thanks for the info
Old Jun 23, 2013, 04:49 AM
Zlui is offline
Joined Aug 2012
Guys, I got mine working yesterday. I must say that, with the relevant information scattered all over the place, it took me half a day to figure out how everything comes together. I found this site to be most helpful, apart from this thread and the original Alexmos controller thread:
http://aerialpixels.com/support/alex...-tuning-guide/
However, finally it worked out and I am more than happy with the results. See for yourselves:
130623 1st Test Flight w/ VectorDD Gimbal, Alexmos Controller, HD Hero3 BE (1 min 20 sec)
130623 2nd Test Flight w/ VectorDD Gimbal, Alexmos Controller, HD Hero3 BE (1 min 51 sec)
Old Jun 23, 2013, 04:57 AM
Merko is offline
F550 Pilot
Merko's Avatar
Joined Feb 2012
Advanced Tab
Hm thanks.
Tried that but it didnt work..
I change the value and hit "Write", but it looks like the board doesnt update with the new configuration.. Is there no confirmation that the board succesfully wrote the new config? Hm
Edit Looks like it was because my board had the b4 firmware, and i tried to update with b3 GUI software.. it did work now that im using the B4 software
Help! E-sky Lama v4 balance and setup of metal swashplate deanprince23 Beginner Training Area (Heli-Electric) 16 Apr 14, 2013 10:24 PM
Discussion 3x 1S balanced charging lead: How to setup correctly? nr1 Batteries and Chargers 3 Jan 15, 2013 01:55 PM
Discussion advice on a good quad setup for Hero3 w/gimbal TheFlyingCamera Multirotor Talk 0 Jan 11, 2013 01:16 AM
Discussion Naza gimbal setup problems crdodd Multirotor Talk 3 Jan 07, 2013 12:16 PM
Mini-HowTo Optimizing Gimbal Setup for Filming - CineStar Gimbal tabbytabb Multirotor Talk 2 Nov 29, 2011 01:00 PM
