Old Jun 17, 2013, 08:44 AM
beamen is offline
Find More Posts by beamen
Joined Sep 2011
Originally Posted by Buffythesaint View Post
What did you end up with your settings? I had really low settings to get it to work but the results were not the best. I had a power of 24 on the tilt. Anything higher and it would go crazy.
I just used the VectorDD_Silent profile that Jussi posted on the first page. I did no additional tuning.
beamen is offline Find More Posts by beamen
Old Jun 17, 2013, 10:58 AM
Buffythesaint is offline
Find More Posts by Buffythesaint
Joined Feb 2005
I just tried the profile and it was all over the place, just kept spinning and rolling real bad.
Buffythesaint is offline Find More Posts by Buffythesaint
Old Jun 17, 2013, 11:44 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Try and reset to defaults and then load the profile. Sometimes new boards can act like this - we are working on figuring out why.
As for balancing, Sebastian is writing a guide - due to total overload here, I had to ask him to do it. Since it is his design, he is also best qualified...
For the pitch axis, as some of you noted, you dont need to do a lot of balancing, since the load is relatively small even with the camera out of balance.
But to balance the cam tray, you just have to slightly loosen the 5 M2 screws, then the whole tray can slide forwards/backwards and up/down. Once the balance is correct, retighten the screws and you are done.
JussiH is offline Find More Posts by JussiH
Old Jun 17, 2013, 01:24 PM
Joined Feb 2005
That's what I thought so I set to defaults and now I have it working. I lowered the power some and a few minor changes. This was my first board from Flyduino and the rc pitch and roll worked great. One day both didn't work at all. I reflashed and have rc pitch working but no rc roll control at all. Any ideas or perhaps put a new signal wire to roll on my rx?
I also sent a couple of e-mails about my second board from viacopter. looks like a bad motor1 chip, really hot when bat plugged in, right away(no motor connected). No reply yet. I understand things are hectic ATM.
Old Jun 17, 2013, 01:35 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
Hey, pls resend the mail with "RMA" in the topic - I have been totally swamped down in emails and work lately. There is warranty, and I will replace the dogdy board of course.
Old Jun 19, 2013, 05:38 AM
thadroopsz is offline
Find More Posts by thadroopsz
Joined Apr 2013
Will this fit the dji phantom out of the box?
Is it possible to order a front for the gopro 1 and 3?
Is tilt availble out of the box?
thadroopsz is offline Find More Posts by thadroopsz
Old Jun 19, 2013, 06:05 AM
beamen is offline
Joined Sep 2011
No, you need to make an adapter plate. I am using Tppacks.com isolation mount, so I just drilled some holes for the gimbal in the bottom plate. Worked perfect.
To activate tilt you have to connect a servo wire from the Alexmos board to the Naza F2 port and activate camera gimbal in the Naza software and set gains to 0. Then go into the gimbal software and adjust the RC controls there. You will also need a lever kit, like the simensays lever kit.
Old Jun 19, 2013, 02:21 PM
teramax is offline
Find More Posts by teramax
sorry, my english is bad
teramax's Avatar
Austria, Wien, Vienna
Joined Apr 2011
so than, the first real video i made with the VectorDD.
Enjoy watching:
watergames updated version (3 min 28 sec)
teramax is offline Find More Posts by teramax
Old Jun 19, 2013, 03:27 PM
beamen is offline
Joined Sep 2011
I stole these from my computer case.. this made it really easy to balance the roll!
Old Jun 20, 2013, 08:10 AM
beamen is offline
Joined Sep 2011
Addon bracket for VideoTX on VectorDD?
Jussi,
Do you have any plans to release a VideoTx mounting bracket for the VectorDD?
I was thinking that it would be great with a small, light weight 90 degree bracket that could be mounted on the backside of the VectorDD, so that you can place your videoTx there. You need the VideoTx to be mounted close to the gimbal so can route the video cable from the videoTx to the GoPro.
Old Jun 21, 2013, 12:42 PM
BJM-Maxx is offline
Find More Posts by BJM-Maxx
BJM-Maxx's Avatar
Joined Sep 2007
I hate to ask such a simple question, I received my kit last night and I did not see anything obvious that lets me connect the electronics to a computer. How do I do that? I did not see anything in the thread for that.
BJM-Maxx is offline Find More Posts by BJM-Maxx
Old Jun 21, 2013, 12:46 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
There is a USB post on the controller board. Or do you mean the actual USB cable itself, as it is not provided.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jun 21, 2013, 01:12 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
Jussi,
No, we dont have any immediate plans for that, but I will pass the idea on to Sebastian...
I dont think it will be a good idea to mount the VTX and Antenna right next to the controller as it generates a lot of EMI that might screw with the video signal.
I route the video signal for my cams through a 35 cm twisted cable with no ill effects and it allows me to place the VTX in the most ideal location with a cloverleaf antenna protruding down from the bottom of the frame where it has the best LOS to the VRX on my groundstation regardless of copter orientation.
Old Jun 21, 2013, 04:40 PM
beamen is offline
Joined Sep 2011
Ok, thanks.Got any pictures of your setup? Also, when will the balancing video be online?
Old Jun 22, 2013, 10:30 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Here was my first test with the VectorDD with stock setup.
Settings are included in the video as well:
VectorDD Gimbal Test #1 (6 min 20 sec)
Have a bit of vibration but not bad for first try.
The gimbal is nicely made and the wires route well to not add any resistance. I was able to tilt down 90 degrees and had good stabilization. Bit of jello at some points but I think that is light reflection off the props.
Site Sponsor
Help! E-sky Lama v4 balance and setup of metal swashplate deanprince23 Beginner Training Area (Heli-Electric) 16 Apr 14, 2013 10:24 PM
Discussion 3x 1S balanced charging lead: How to setup correctly? nr1 Batteries and Chargers 3 Jan 15, 2013 01:55 PM
Discussion advice on a good quad setup for Hero3 w/gimbal TheFlyingCamera Multirotor Talk 0 Jan 11, 2013 01:16 AM
Discussion Naza gimbal setup problems crdodd Multirotor Talk 3 Jan 07, 2013 12:16 PM
Mini-HowTo Optimizing Gimbal Setup for Filming - CineStar Gimbal tabbytabb Multirotor Talk 2 Nov 29, 2011 01:00 PM
