Old Jun 13, 2013, 11:07 AM
beamen is offline
Find More Posts by beamen
Joined Sep 2011
Jussi,
I calibrated (basic). All seems good in the GUI, but when I connect the motors and power it on, it still does the full rotation on the pitch axis. This is driving me crazy!!
I tried reversing it too. Nothing. A friend said it is a IMU problem.
beamen is offline Find More Posts by beamen
Old Jun 13, 2013, 03:17 PM
teramax is offline
Find More Posts by teramax
sorry, my english is bad
teramax's Avatar
Austria, Wien, Vienna
Joined Apr 2011
Originally Posted by beamen View Post
Jussi,
Ive heared from some other users fixed this problem by pressing "use deffault" button, reboot and write back config.
Please try.
teramax is offline Find More Posts by teramax
Old Jun 13, 2013, 03:34 PM
beamen is offline
Joined Sep 2011
Please try.
THANK YOU!!!!! Worked!
Old Jun 13, 2013, 04:33 PM
Askyvision is offline
Find More Posts by Askyvision
Albuquerque USA
United States, NM, Albuquerque
Joined Dec 2012
can some one make a video of how they balance their please. It seem that this one is hard to balance the Roll i got the tilt balanced. It keep drop to both side. I have the rctimer gimbal and and balance fast. It look like the tilt also effect by the roll balance to dont it??
Askyvision is offline Find More Posts by Askyvision
Old Jun 13, 2013, 04:58 PM
teramax is offline
teramax's Avatar
Joined Apr 2011
If it seems to drop on both sides, try to set the GoPro just a little lower. Not much, just 1-2 mm
Old Jun 13, 2013, 07:02 PM
bcollydas is offline
Find More Posts by bcollydas
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
Jussi,
I can see the board been bad but not the IMU. All the pages I've read on the controller no one complaint about the IMU been bad. Is only one chip on it.
bcollydas is offline Find More Posts by bcollydas
Old Jun 13, 2013, 07:08 PM
beamen is offline
Joined Sep 2011
OK i see, but teramax saved my day. His solution worked. Thanks again man. Awesome results with this gimbal with the default quite file.
Old Jun 14, 2013, 02:22 AM
beamen is offline
Joined Sep 2011
My first real test. 100% stick inputs in all directions and some slow flying at the end
VectorDD on DJI Phantom Brushless Alexmos Gimbal (3 min 22 sec)
Old Jun 14, 2013, 11:13 AM
sprocketty is offline
Find More Posts by sprocketty
Joined May 2013
Please try.
OK, i am 100% sure a lot of users are facing this problem as well. IT WORKED FOR ME!
Would the thread starter PLEASE add this into the first post!
Thanks...
sprocketty is offline Find More Posts by sprocketty
Old Jun 14, 2013, 02:47 PM
Albuquerque USA
Joined Dec 2012
Thanks...
Please try.
Here Let me Help out
Old Jun 14, 2013, 02:55 PM
teramax is offline
teramax's Avatar
Joined Apr 2011
oh man i love when some misspelling from me is posted in such huge red letters
Thanks...
but hey, whats about all that fun when everything is in the "first post"
Old Jun 14, 2013, 04:18 PM
JookSing is offline
Find More Posts by JookSing
JookSing's Avatar
Zip 08857
Joined Jun 2005
Just wondering if this gimbal will accomodate other "box" shaped action cameras such as the CamOne Infinity http://www.adorama.com/ACCOIN01.html and Astak Action Pro http://www.amazon.com/camera-photo/dp/B0068LAAOQ
JookSing is offline Find More Posts by JookSing
Old Jun 16, 2013, 12:22 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
You can fit a CamOne in the tray, but you will need some extra foam to keep it in place.
JussiH is offline Find More Posts by JussiH
Old Jun 16, 2013, 12:33 AM
JussiH is offline
JussiH's Avatar
Joined May 2007
Jusshi how do we balance this? I got the tilt to balance but the roll keep drop on to either side left and right thanks I'm ready to put it in the air
If the cam is dropping left or right, you probably have the pitch axis a little top-heavy, as Marcus suggested.
Try and rotate the pitch axis 180 degrees and if its now bottom-heavy, then you will know to adjust the cam-tray a bit to account for this. Same thing for the other faces of the cam. The ideal is to balance the pitch, so that its neutrally balanced no matter which way its facing. I will post a video showing this - its a little hard to explain in words, but very straightforward to do.
For a GP3 black, the ideal position of the pitch axis is circa 2 mm up and 1-2mm back.
Old Jun 16, 2013, 07:44 AM
Efti is offline
Find More Posts by Efti
Efti's Avatar
Norge, Rogaland, Bryne
Joined Oct 2011
Here is my maiden in very windy condition. Not a good day for testing.
I think my hexa is not so good with the original DJ motors using rctimer carbon prop.
VectorDD Hexa F550 testing. Very windy. (4 min 11 sec)
Efti is offline Find More Posts by Efti
Help! E-sky Lama v4 balance and setup of metal swashplate deanprince23 Beginner Training Area (Heli-Electric) 16 Apr 14, 2013 10:24 PM
Discussion 3x 1S balanced charging lead: How to setup correctly? nr1 Batteries and Chargers 3 Jan 15, 2013 01:55 PM
Discussion advice on a good quad setup for Hero3 w/gimbal TheFlyingCamera Multirotor Talk 0 Jan 11, 2013 01:16 AM
Discussion Naza gimbal setup problems crdodd Multirotor Talk 3 Jan 07, 2013 12:16 PM
Mini-HowTo Optimizing Gimbal Setup for Filming - CineStar Gimbal tabbytabb Multirotor Talk 2 Nov 29, 2011 01:00 PM
