Old Jun 12, 2013, 05:38 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Mini-HowTo
VectorDD gimbal - Assembly, setup and balancing
Preliminary: Setup thread for VectorDD gimbals from Viacopter.
I will post relevant manuals and setup information on this thread. Feel free to ask a question, but try and do a search on the thread first..
Kit kontents video:
VectorDD Brushless gimbal - What is in the box? (2 min 5 sec)
JussiH is offline Find More Posts by JussiH
JussiH is offline
JussiH's Avatar
Joined May 2007
Assembly:
Use some non-permanent threadlock on the screws. Assemble it losely to begin with, then it will be easy to move the roll and pitch axises for balancing. DO NOT tighten screws too hard.
VectorDD brushless GoPro Gimbal - Assembly (19 min 28 sec)
Note that the brass bearing spacer was mounted wrong in this video. It goes between the screw head and the bearing. Like this:
Old Jun 12, 2013, 05:39 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
Controller and wiring
I attached the wires with some small strips of Vinyl electrical tape - alternativel you could use cable ties.
Pitch motor wiring:
Roll motor wiring:
IMU placement:
IMU wiring:
Controller mounting:
Motor1: Roll
Motor2: Pitch
Old Jun 12, 2013, 05:40 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
Reserved: Balancing
Reserved: Balancing
JussiH is offline
JussiH's Avatar
Joined May 2007
Setup and Tuning
VectorDD profile attached for Basecam 2.0 b3 in silent mode:'
Here is link to silent profile for 2.04 FW by Teramax:
http://www.rcgroups.com/forums/showp...1&postcount=83
Old Jun 12, 2013, 06:26 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Great info so far. Once I get mine in stock I'll post some pics and test flight videos as well.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jun 13, 2013, 12:35 AM
beamen is offline
Find More Posts by beamen
Joined Sep 2011
Great. Thanks
BTW, a guide on how to do the first power up/config would be good as well.
I got it all put together, but now I don't know what to do Do I have to do a calibration? I would really appreciate a quick start guide of some sort so I can get this thing running. There are plenty of tuning manuals/videos, so I just need the basic steps to get it running the first time.
I powered it on before I went to work and the pitch did a complete 360 so I had to turn it off so the wire to the IMU didn't get damaged. Why did it do that?
beamen is offline Find More Posts by beamen
Old Jun 13, 2013, 05:13 AM
beamen is offline
Joined Sep 2011
BTW, some improvements you should do with the kit.
You should include:
*Velcro strip
*Power leads with a JST plug (probably the most used plug on this type of device).
*Regular nuts. The one's included have nylon in the top, which can't be screwed on properly on the rubber dampeners (you need to much pressure and the rubber dampeners just twist). I had to use 3 washers per dampener on my setup to secure the dampeners to the frame.
*Heat shrink
*M3x6 Thumb screws for the roll motor (easier to adjust - it's really tight back there - hard to loosen/secure the bolts).
You should also cut the cables to the correct length, or solder them on the motors (would be better).
Other than that it was nice. Quality piece of kit.
Old Jun 13, 2013, 05:34 AM
JussiH is offline
JussiH's Avatar
Joined May 2007
Thanks..
All good points....
The Velcro should have been included - was it not? Send me an email and I will send the missing velcro to you.
For the nuts, we can include some standard A3 stainless nuts - you do have a point about the locknuts and the rubber standoffs.
Wire: Yes, we are working on it - and will include a JST wire in the future (as soon as we get them)
Heatshrink will also be included with the motors for coming batches. For the wires we are gonna stick with the current standard length, since some people might need longer wires for their own desigs. On that note we will also offer longer IMU wires for DIY purposes.
Thumb screws - that is actually a very good idea, and we will begin looking for some right away.
For your problem with the Gimbal turning pitch all over, it might be an initialization issue or calibration issue. Your pitch motor might need to be reversed too. Anyway - I am working all day today, but I will post more info on SW setup tonight when I am home again.
I have seen this happening before with all new setups, but it seems to go away once the IMU is calibrated.
You should include:
*Velcro strip
*Heat shrink
Old Jun 13, 2013, 06:08 AM
beamen is offline
Joined Sep 2011
Originally Posted by JussiH View Post
Thanks..
All good points....
Thanks Jussi. Nope, not included, but luckily I had some laying around. No need to send me anything, but great customer service (hence the reason I waited for your gimbal) + the nicely designed gimbal obviously.
Glad I could help with my suggestions.
Looking forward to the guide!
Old Jun 13, 2013, 06:38 AM
teramax is offline
Find More Posts by teramax
sorry, my english is bad
teramax's Avatar
Austria, Wien, Vienna
Joined Apr 2011
Great. Thanks
First calibration of the IMU is better made befor mounting it on the gimbal.
The first startup it is always a good idea to not plug in the motors, just plug in the board, connect to computer and watch in GUI how the sensor behaves ;-)
Than itīs time to import settings http://www.rcgroups.com/forums/showa...6&d=1371079150
teramax is offline Find More Posts by teramax
Old Jun 13, 2013, 07:02 AM
beamen is offline
Joined Sep 2011
Thanks buddy!! That helped a lot! I will give it a shot when I get home
Old Jun 13, 2013, 10:19 AM
Askyvision is offline
Find More Posts by Askyvision
Albuquerque USA
United States, NM, Albuquerque
Joined Dec 2012
Can you write a mini tutorial for the calibration process please.
Like -> lay it flat-> click calibrate-> click write? Please it confuse about the calibration. Which I never did calibrate on my. I think is time to do so with the new gimbal
Askyvision is offline Find More Posts by Askyvision
Old Jun 13, 2013, 10:21 AM
Albuquerque USA
Joined Dec 2012
Thanks..
All good points....
Jusshi how do we balance this? I got the tilt to balance but the roll keep drop on to either side left and right thanks I'm ready to put it in the air
Old Jun 13, 2013, 10:49 AM
JussiH is offline
JussiH's Avatar
Joined May 2007
Loosen the 2 M3 button heads that mount the motor to the roll bar, then you can slide it left and right.
For the pitch, you just slightly loosen the 5 M2 capscrews that holds the cam cage - then the whole tray can slide 8 mm up/down and forward/backward, which is more than enough. For a Gopro3 Black you will be around 2 mm up and 1mm backwards for pitch to have perfect balance. Then it becomes easier to balance roll.
When the balance is correct, you just tighten the screws and you are done.
Another tip is to make sure the axises can move freely during balancing. Wires that is getting in the way, can screw with the balancing. If you secure the wires on the center of the roll bar, it will make your life easier and they wont mess with the balance and get in the way of the gimbals ability to move freely.
I am gonna make a video showing how to do this, but it wont be today or tomorrow as I have a job to do - Iīll have it done in the weekend.
Help! E-sky Lama v4 balance and setup of metal swashplate deanprince23 Beginner Training Area (Heli-Electric) 16 Apr 14, 2013 10:24 PM
Discussion 3x 1S balanced charging lead: How to setup correctly? nr1 Batteries and Chargers 3 Jan 15, 2013 01:55 PM
Discussion advice on a good quad setup for Hero3 w/gimbal TheFlyingCamera Multirotor Talk 0 Jan 11, 2013 01:16 AM
Discussion Naza gimbal setup problems crdodd Multirotor Talk 3 Jan 07, 2013 12:16 PM
Mini-HowTo Optimizing Gimbal Setup for Filming - CineStar Gimbal tabbytabb Multirotor Talk 2 Nov 29, 2011 01:00 PM
