Old Jun 10, 2013, 06:07 AM
NUTSgoWEEE is offline
Find More Posts by NUTSgoWEEE
United States, AK, Fairbanks
Joined Jun 2013
ESC circuit design questions with simonk firmware on Atmega8
Hey all,
I am throwing together a ESC design on a board that will integrate into a quad frame better. The design is based on the Blueseries HK/Mystery boards which a (partially accurate) schematic is found here:
I have 4 main questions:
1) D1 which is connected to pin 24 - does anyone know what this is? Just a regular diode, zener? Based on a few other designs it seems like it might be a zener used for VREF but there aren't any on the HK boards. Anyone know if this part is necessary or have a hint where to find a part for it?
2) The voltage divider on pin 25 (R20, R21 and C7) looks like it's used for the low voltage cutoff on the battery which the simonk firmware gets rid of - does anyone know if this is true and if I can leave these parts off?
3) Back emf filtering capacitors - (C10-C12), I read that these should be removed when flashing a Blueseries board for better response so I am planning on leaving them out. Is this true?
4) The filtering capacitor C8 on the SIGNAL_IN line, anyone know this value? What is the max PWM or PPM frequency on the SIGNAL_IN line? Then I can calculate this myself.
Thanks a bunch, if you have any info that would be awesome. Also, once I get a decent design working this will all be open source
NUTSgoWEEE is offline Find More Posts by NUTSgoWEEE
Old Jun 10, 2013, 06:48 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I would recommend asking the moderators to move your thread to the --
RCGroups DIY Electronics forum
(If you click on 'Report', top right of your post, there is an option there to ask for it to be moved).
Although you may get the answers here in the Power Systems forum, they are more likely to be interested in expanding on your thread, plus they may even have something similar in their forum.
Plus Welcome to RCGroups, I hope you have success with the project.
eflightray is online now Find More Posts by eflightray
Old Jun 10, 2013, 05:24 PM
Joined Jun 2013
Sorry about that, thanks for the tip!
Old Jun 11, 2013, 10:18 AM
Joined Jun 2013
So from more and more reading it looks that D1 is used for temperature monitoring and overtemp protection which is not used in simonk firmware so I plan to leave pin 24 floating in this prototype and hope it works.
I'm also learning a lot more about the FET stages and may redesign later to increase efficiency but for now I think I have a PCB ready to send to fab
Old Jun 11, 2013, 10:43 AM
m056678 is offline
Find More Posts by m056678
United States, MA, Hanscom AFB
Joined Aug 2011
I have been researching something similar for the past couple of days (integrating an ESC into a multi-wii board). Do you have the files that this schematic is from? Would you be willing to post them?
m056678 is offline Find More Posts by m056678
Old Jun 12, 2013, 04:30 AM
Joined Jun 2013
I'm not sure what files you mean, all I have is the schematic above which I got from here:
http://wii-esc.googlecode.com/svn/doc/Schematics/
There are some resistor values that are not correct on the one I posted above and I am not sure on the others in that link. Other than reading about simonk's firmware and learning BLDC control theory, that's really all I have been going off of.
Once I have something verified working I will gladly share my PCB layout files but I have to order boards for prototyping which takes a while.
Old Jun 12, 2013, 05:01 AM
fantasy1988 is offline
Find More Posts by fantasy1988
Joined Oct 2012
This schematic should not use , because FET very hot , you should use ir2101 with shematic mystery 40a
fantasy1988 is offline Find More Posts by fantasy1988
Old Jun 12, 2013, 06:42 AM
GordonTarling is offline
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
Nuts - rather than leaving an unused pin just floating, better to tie it to Vcc or ground via a resistor - more predictable that way.
GordonTarling is offline Find More Posts by GordonTarling
Old Jun 14, 2013, 05:59 AM
mckeemj is offline
Find More Posts by mckeemj
Joined May 2013
As the AtMega8 has built-in pull-up resistors, it is perfectly acceptable to leave the pins unconnected and enable the pull-up. Then no external resistor is required. That also has the small safety advantage that, should the pin ever be incorrectly programmed as an output, it will not short to one of the power rails.
Martin Jay McKe
mckeemj is offline Find More Posts by mckeemj
Old Jul 13, 2013, 01:40 AM
Joined Jun 2013
Well with a ton of help from Simon, I put together a layout, ordered parts and PCBs and it works!
I re-assigned a lot of the pins on the ATmega for an easier 2-layer layout so with some help, I made a new .inc file and Simon sent me the compiled hex file.
Hopefully this weekend I will be able to upload my eagle schematic.
I'm in the process of another layout now to fit my quad build better.
To answer a few of my own questions in the OP:
1.) The symbol on the schematic is actually meant to be a thermistor - I left this part out and did not define a temperature pin in the .inc file because it's not necessary.
2.) The voltage divider is meant for the low voltage cut-off. I also left these parts off and assignments out of the .inc file because there is no low voltage shut-down. Instead I tied the pin high per Simon's recommendation.
3.) The back EMF filter capacitors on the sense lines should be removed. Simon also recommended different resistor values be used for a better signal.
4.) I used the ICP input on the ATmega for the speed signal because it has internal filtering already. Simon did recommend putting a large resistor to ground here. I will get the schematics up soon with all the values.
fantasy1988 - I didn't want to use FET drivers here because I only need a 20A design for now. In the future I would like to make a 40A design for 6S battery which will definitely require drivers.
Old Jul 14, 2013, 04:51 AM
MGeo is online now
Find More Posts by MGeo
MGeo's Avatar
New York
Joined Nov 2003
Great progress! Did this mean you used the schematic of post #1? If not, could you post an export of your schematic?
George
MGeo is online now Find More Posts by MGeo
Old Jul 17, 2013, 07:57 AM
Joined Jun 2013
Yes - the schematic from the first post is pretty similar to what I used, here is my Eagle schematic - sorry I haven't had time to clean it up but all the values are parts should be on there.
If you have any questions about the design I should be able to help. The firmware that's loaded onto the chip is also in the folder below. Also available supported here:
https://github.com/sim-/tgy/commit/1...d105a69d535084
Also here are the Eagle schematic and board files. The board needs a lot of adjustments - mainly the holes for power and motor outputs are too small. The FETs can also be placed a lot closer together. I'm also learning to use polygon's better so forgive me on the mess - it was easiest at the time to make paths I could add solder to for extra current capacity.
https://drive.google.com/folderview?...TA&usp=sharing
Old Apr 10, 2014, 01:36 AM
mihun70 is offline
Find More Posts by mihun70
Joined Mar 2014
Hy!i want to make something similar but with a DIP version of Atmega8.i will design the hardware but i'm fool at programing...All the .inc files use the ADC6 and ADC7ports of atmega...
I want to design using Nfets,ir2101 drivers and DIP version of atmega 8.Can somwone suport me with an modificated compiled hex?thx!
mihun70 is offline Find More Posts by mihun70
New Product New Maytech Eagle-Multi Series ESCs with SimonK firmware Garret H Multirotor Electronics 1 Sep 18, 2014 12:36 AM
For Sale Hobbyking f30a esc flashed with simonk firmware Diazapamjam Aircraft - Electric - Multirotor (FS/W) 7 Aug 04, 2013 02:57 PM
For Sale HK F30a esc with Simonk firmware Diazapamjam Aircraft - Electric - Multirotor (FS/W) 4 Apr 13, 2013 05:18 PM
Discussion difference between normal esc and esc with simonk firmware AliB Multirotor Talk 3 Jul 26, 2012 11:50 AM
