Old Jan 20, 2004, 03:00 AM
Bob
Bob
Guest
n/a Posts
trimming a flying wing.
I have recently got a small EPP wing, and having a few difficulties.
It is similar to the zagi style of wing, but smaller.
It is powered by a speed 280, with a 5x4.2 and is approx 32"
The flying weight it comes out at is 220g, which is in the correct range of
200-250g.
I have set it up so the COG is exactly where recommended, but in the flying,
to maintain level flight at full throttle I need to have a lot of up (3/4 of
available). Whenever I try and give airleron input, as it starts turning,
the higher wing stalls, then drops.
Basically, I can only fly in a straight line.
Any wing guru's experienced something like this, and is it a balance
problem?
Don Hatten
Don Hatten
Guest
n/a Posts
Re: trimming a flying wing.
Do you have some reflex in the elevons? You should have some, how much
depends on what the kit maker recommends as a starting point. Also, you
shouldn't need too much control throw, maybe 1/2" max with more up than
down..
"Bob" <bNOoONb@not.pilbara.net.au> wrote in message
news:buhrbp$akn$1@mws-stat-syd.cdn.telstra.com.au...
of
> 200-250g.
flying,
of
> problem?
W4JLE
W4JLE
Guest
n/a Posts
How do you have the mixing set up on the transmitter?
of
> 200-250g.
flying,
of
> problem?
Dr1Driver
Dr1Driver
Guest
n/a Posts
>problem?
Flying wings normally need the ailerons kicked up in a "reflex" attitude. No
idea how much to tell you on that plane, sorry. Experiment...
Dr.1 Driver
"There's a Hun in the sun!"
Bob
Bob
Guest
n/a Posts
Ok,
I have approx 1" up and 1" down of control throws, I am flying with approx
3/4 up ALL the time to maintain level flight.
I am thinking that there is some sort of balance problem. I was hoping
someone may have experienced a similar problem, and help with determining if
it is a balance either being too far f/w or back to how it actually
performs.
I guess that I will take some small weights with me and go and try and find
out what the problems are!
Bob in Aus
"Don Hatten" <hattend@starband.net> wrote in message
news:vl%Ob.19307$UY.1361337527@twister2.starband.n et...
> down..
> of
> > 200-250g.
> flying,
(3/4
> of
turning,
> > problem?
Bob
Bob
Guest
n/a Posts
standard Elevon mixing, (JR652 Tx)
"W4JLE" <w4jle(remove to reply)@pbtcomm.net> wrote in message
news:bui567$783d$1@news3.infoave.net...
Maarten
Maarten
Guest
n/a Posts
Normally it need a max of 1/32" up to maintain altitude.
So you hav to move your COG backwards. If it is 3/4" up then put it back
about 1/2 ".
Then in smaller steps. Do not try to turn yet in this trimming round. Just
straight lines trying to keep altitude.
Next to this you need speed to maintain altitude.Go full power and when
launching it make sure that it has enough speed (do not thow it upwards but
in a straight horizontal line.)
Succes,
Maarten
news:buib5i$m7r$1@mws-stat-syd.cdn.telstra.com.au...
> Ok,
if
> performs.
find
> Bob in Aus
> > down..
range
> > of
> > > 200-250g.
> > flying,
> (3/4
> > of
> turning,
> > > problem?
Six_O'Clock_High
Six_O'Clock_High
Guest
n/a Posts
Bob,
The "reflex" is normally seen as the elevons being viewed as UP when in the
center of their travel.
Here is a way you should be able to begin to fix your problem. With the Tx
and Rx ON (and motor disconnected!), move the elevator stick to the location
you need to hold to get it straight and level with the plane on a table.
Then while holding that elevator, turn off the RX. That should leave the
elevons in the UP mode you need. Measure the distance from the table to the
top edge of each elevon with the wing secured to the table by heavy (5
pound) weights. Then turn the RX and TX on for a moment making sure the
elevator trim is in the center. Unscrew the servo wheels and move them
until the top edge of the elevon is at the same distance above the table you
measured earlier. Reinstall the screws and turn on the RX and TX to check
that you still have equal travel in both directions on both surfaces because
you may need to make an engineering change or two to the entire control
system - that is no fun, but it should not be a stopper.Go test fly it and
see if it is better or worse.
> Ok,
if
> performs.
find
> Bob in Aus
> > down..
range
> > of
> > > 200-250g.
> > flying,
> (3/4
> > of
> turning,
> > > problem?
Bob
Bob
Guest
n/a Posts
I have just managed to find someone else who has a couple of these wings and
recommended a similar thing.
I will take a few small weights with me and do some experiments and see how
it flies....
Thanks for the advice, I will let you know how it goes...
Bob in Aus
"Maarten" <mmg_brouwers@hotmail.com> wrote in message
news:buicq2$118$1@news4.tilbu1.nb.home.nl...
> about 1/2 ".
but
> Succes,
> Maarten
> > Ok,
approx
determining
> if
> > performs.
> find
> > Bob in Aus
much
you
than
> > > down..
> range
> > > of
> > > > 200-250g.
> > > flying,
> > (3/4
> > > of
> > turning,
> > > > problem?
Old Jan 20, 2004, 06:01 PM
David
David
Guest
n/a Posts
I am only a beginner, but wonder if the motor has a lot of downthrust? And so
you have to use up elevator to keep it level???
David
> 200-250g.
> problem?
Old Jan 21, 2004, 03:00 AM
N9M
N9M
Guest
n/a Posts
Bob,
Your CG should be at 15% - 19% of MAC. I fly my wings at 17% of MAC.
To calculate where 17% MAC is on your wing, go here:
http://www.palosrc.com/instructors/cg.htm
Where it says, "Enter %MAC Balance Point:" type in "17". This
calculator will tell you how far back from the tip of the leading edge
at the root your CG should be.
Feel free to email me direct to ask questions.
Jeff
Old Jan 21, 2004, 06:03 PM
A.T.
A.T.
Guest
n/a Posts
Most "wings" will set up nicely if the aiklerons follow the bottom airfoil
rather so as the wing takes on a "S" shape when viewed along the top of the
wing. i.e. 1 to 2% reflex.
For in depth info on thrust lines etc refer to =
http://homepages.ihug.co.nz/~atong/
and scroll down to =
"Flying Wings (inc Delta), Flapping Wings or Ornithopter. [see also Gliders
below.]"
Flying wings
Advanced Propulsion Home Page - JLN Labs
Airfoil Design for Tailless Airplanes 1
Andy MacDonalds Flying Wing page.
Airfoils for Flying Wings and Tailless Airplanes ***
Correx Deltas - good plans & video.
Flying Wings - Trimming
Flying Wing Models - Basic design
Foam Wing Construction
Mugi Correx Combat Flying Wing
Theoretical Flying wings
TWITT- The Wing is the Thing
Flying Wings : An Anthology
Birdworks - inc the RC Gull
Flapping Wings - Ornithopter
Bionics and Evolutiontechnique
CyBird (- with movies etc)
Flapping Flight Links
Flapping Flight - Ornithopters
Multiwinglets_Rueckstromtaschen
Ornithopters
ParkHawk
Robofalcon - Intercept technology
Truefly - Flying by flapping wings
The Flutterby
1900 Clark BiWing Ornithopter
Advanced Propulsion - JLN Labs
See aklso =
"Foam Wings, Warbirds, Foam Cutting Bows, Coroplast, PVC & SPAD. [see also
Gliders below.]"
regards
Alan T.
Alan's Hobby, Model & RC Links
of
> 200-250g.
flying,
of
> problem?
N9M
N9M
Guest
n/a Posts
I have found that at least on the flying wings I design, build and fly
that in a pusher prop configuration, about 4 degrees of downthrust
works great for me.
Flying wings sold on the market today require around 5 to 10 degrees
of reflex in the elevons to fly properly. That is if the CG is around
17% MAC.
Jeff
Old Jan 22, 2004, 06:01 PM
Bob in Aus
Bob in Aus
Guest
n/a Posts
"N9M" <northropn9m@yahoo.com> wrote in message
news:dc67c867.0401201632.696e34c6@posting.google.c om...
> Bob,
> Jeff
I ran the numbers thru the calculator on the web page and they came up
surprisingly at 135mm from the Le at chord.
The instructions come at 155mm, and from what others are saying, I am NOSE
heavy.
I am thinking something is not right somewhere..... I have added some
weight to the motor, and moved the COG back approx 10-15 mm but yet, have
not had a chance to test fly and see if this is going in the right
direction.
Below URL is the actual model, and the image showing instructions on the
page is almost readable.
http://www.modelflight.com.au/rc_mod...le_280_epp.htm
I even asked people at the shop about this, and they are saying MOVE COG
BACK!. I just wanna get it to fly! Once I get it flying, It means 3 minutes
to the park to have a fly rather than 30 minutes to the flying field, or 2
hours to my 10Acre property to fly!
I will put together a summary when I get this thing sorted out and actually
flying!
Bob in Aus.
Old Jan 25, 2004, 03:00 AM
Bob in Aus
Bob in Aus
Guest
n/a Posts
Jeff,
I have actually discussed this with the LHS where I purchased it, and the
recommendation was to MOVE IT BACK!
We discussed a lot of things, such as power etc, and when I said I was
getting over 4 oz of static thrust, he seemed surprised, as his is about 3
oz with the standard motor. (it pays to break in an electric motor!).
I will be test flying it again tomorrow afternoon and see what happens.
If all else fails, I will be talking to another person at the LHS who has
flown several of these wings and a lot of others as well.
news:dc67c867.0401230652.7082da7f@posting.google.c om...
> Bob,
> I check the website with the instructions for your wing. Keep the CG
> as the instructions say...155 mm.
> If the wing is stalling in the turns, if it requires significant
> elevon deflection just to fly level and the CG is set according to the
> instructions, it sounds like it is flying very slow. My wings require
> almost 3/4 of full deflection just before stall speed.
> I wonder if your battery is delievering enough power to the motor. I
> wonder if the wing is so slow that it is flying just above stall
> speed.
> Jeff
> "Bob in Aus" <bREMOVEoMEb@norcom.net.au.remove.me> wrote in message
news:<400fddbf$0$4259$c30e37c6@lon-reader.news.telstra.net>...
> > > Bob,
> > > Jeff
NOSE
> > heavy.
have
> > direction.
minutes
2
actually
> > flying!
> > Bob in Aus.
Take a look at this 24 inch flying wing Acer Electric Plane Talk 2 Sep 10, 2001 02:29 PM
I think my downthrust is set wrong on my Electric Flying wing, help! e-sailpilot86 Beginner Training Area (Aircraft-Electric) 2 Aug 08, 2001 01:54 AM
Check this out!! GWS powered epp flying wing!! slowflyer Parkflyers 4 Jul 23, 2001 09:29 AM
Flying wing pylon racer... Redster High Performance 13 Jun 14, 2001 07:39 AM
