Homemade 4-transistor speed control
I have put the schematics and photos of an inexpensive and lightweight DC motor speed controller with 4 transistors and power fet to:
http://lennokki.innoplaza.net |
Hello Bruce,
I see you have very interesting and advanced ESC circuit and PPM decoder on your page http://homepages.paradise.net.nz/bha...ectronics.html That is how I would make them if I were sharp enough with microcontrollers... Regards, - Juha - |
Added to this brushed controller designs compilation:
http://www.rcgroups.com/forums/showthread.php?t=190829 Vriendelijke groeten Ron• diy motor building tips & tricks • diy brushless motor discussion group • Drive Calculator download & discussion group • int. E fly-in & diy outrunner meet, Aug.26 2007, Nijmegen, the Netherlands |
USA, ME, Ellsworth
Joined May 2008
Juha,
You might find the DIY (Do It Yourself) forum here interesting and a good place to find the answer to your question: http://www.rcgroups.com/diy-electronics-199/ In fact, I'm sure the people over there would find your project interesting and they could also provide you with an interesting discussion about it. You might want to post the same thing there. Jack |
Joined Jul 2009
i build the controller but an getting direct power to the motor even when switching the power off please help dd south africa |
Hi DD!
Your power fet obviously keeps conducting when it is not supposed to. Check: - Mosfet polarity. If source and drain are reversed it will conduct all the time. - Mosfet gate voltage? If it has zero volts, it should not conduct. If 2 ... 5 volts it should conduct and power up the motor. |
PCB is heaviest part of the circuit
Sure, unnecessary parts are left out..!
Leaving the heaviest part out of the circuit - the circuit board. This cuts the circuit weight to less than half. This is of course desirable for featherweight flying models. The electricity does not mind the missing PCB. It flows directly from one component contact to another quite as well as with the PC board acting as intermediary. If the weight of the circuit is not critical using a PC board will of course make the circuit more rugged. |
| Thread Tools | |
| will the mini twin from speedwing.net work with a 4 amp speed control? | I FO nut | Foamies (Kits) | 2 | May 27, 2003 03:22 AM |
| Speed control for 4 or 5 servos | Tbkahuna | Parkflyers | 5 | Jan 11, 2002 11:40 PM |
| speed control for speed 400 4.8v motors | Andy Fox | Power Systems | 5 | Jan 11, 2002 05:41 PM |
| Hooking up a Jeti Brushless Speed Control to a Jeti Pashor 15/4 motor. HELP!!! | Rob R | Power Systems | 3 | Jan 10, 2002 06:37 PM |
| New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 | Joe Pierson | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 06, 2001 01:48 AM |
