This thread is privately moderated by Pauluk1, who may elect to delete unwanted replies.
Old Nov 06, 2013, 06:40 AM
Pauluk1 is offline
Find More Posts by Pauluk1
I never crash,my copter does
Pauluk1's Avatar
United Kingdom, Wales, Cardiff
Joined May 2012
Finally got a transmitter with more channels.
Tried it out on my tricopter will try the 650 next and hope to control the gimbal
tilt with it.
Pauluk1 is offline Find More Posts by Pauluk1
Old Nov 15, 2013, 11:51 AM
dynam is offline
Find More Posts by dynam
United States, TN, Nashville
Joined Feb 2012
build list:
tarot 650 frame http://www.goodluckbuy.com/tarot-fol...uadcopter.html
sunny sky v2814-11 KV700 motors http://www.buddyrc.com/sunnysky-v281...ess-motor.html
FC KK2
ESC: 4X SimonK HobbyKing F30A 30A Brushless ESC
http://www.ebay.com/itm/321192776318...84.m1439.l2649
Zippy 4s 5000mah battery
what pro size would you guys recommend I was going to use these 11x5.5 props
let me know what you guys think and about this list and any suggestion would be GREATLY APPRECIATED. Let me know any additional parts that I will need. thanks guys
dynam is offline Find More Posts by dynam
Old Nov 15, 2013, 01:03 PM
Pauluk1 is offline
Pauluk1's Avatar
Joined May 2012
The build list looks ok.
11x5.5 props will work but you might want to look at 12x5 or larger for extended flight times.
Old Nov 16, 2013, 09:28 AM
Torque66 is offline
Find More Posts by Torque66
Noob
Torque66's Avatar
Canada, ON, Toronto
Joined Dec 2011
I received my gemfan 1147 props the other week.... comparing them to the 1245 props can't see how the 12's push more air especially since they're much more flexible... i prefer the 11's over the 12's now.... roughly the same flight times as well.
Here is my fleet.....
Torque66 is offline Find More Posts by Torque66
Old Nov 16, 2013, 09:29 AM
Torque66 is offline
Noob
Torque66's Avatar
Canada, ON, Toronto
Joined Dec 2011
So how is the new Tx working out?
Old Nov 16, 2013, 10:03 AM
Pauluk1 is offline
Pauluk1's Avatar
Joined May 2012
Working great got the timers setup to only start counting down after the throttle goes above 10%,for the price its amazing.
Still havent hooked it up to the gimbals yet,weathers been too bad here to fly.
Nice fleet you have there.
Interesting that your 11" props are giving you the same flight time.
I will have to try those 13x4.5 turnigy wooden props i bought.
As a side project because the weather sucks im building a mini H quad with some carbon fiber tubes and
some plywood.
Old Nov 18, 2013, 05:27 PM
raymondkerr is offline
Find More Posts by raymondkerr
Joined Jan 2013
Just built up my 650 today. I notice that my motors don't line up with the holes on the carbon plates. At best I'll only get 2 out of 4 screws in for each motor. They are turnigy rebadged pro flight uk 1100kv 2830/11 motors. There are 8 holes on the motor plates but not much room left to drill any more holes, not sure at the stage what to do. Didn't really want to change my motors at this point, are there any adapters/mounts you can buy?
Raymond
raymondkerr is offline Find More Posts by raymondkerr
Old Nov 19, 2013, 04:16 AM
Pauluk1 is offline
Pauluk1's Avatar
Joined May 2012
Raymond
Not sure about adapters but mine are the same only using 2 screws had no problems at all with it.
Old Nov 19, 2013, 07:45 AM
Joined Jan 2013
Hi Paul, i'll have a closer look tonight and see if i can get them to fit. I wouldnt have thought 2 screws would have been secure enough, but i could always threadlock them and regularly check before flying.
Cheers
Raymond
Old Nov 19, 2013, 12:46 PM
Koo is offline
Koo
Find More Posts by Koo
Koo
A semi-advanced FPV newbie
Koo's Avatar
United States, OH, Oxford
Joined Mar 2012
I have couple questions about the fy650. We are planning on building a multi to carry a Sony nex and a brushless gimbal. The motors we are using will be rctimer 5010 360kv with either 15" or 16" props. We will use 2* 4s 5000mah in parallel and the total weight of everything (if using a fy810 hexa) would be over 4.5kg.
The motors are super efficient (+10g/W) when lifting less 600grams. So here is what we are planning on doing.
Use fy650 and make it into a x8 (motors on the bottom and on the top of the arms). Would this frame be able to handle about 4kg weight or should we get fy690s and convert it into a quad and then into a x8?
I've seen couple people using this frame as x8 on youtube but very hard to find info. So how easy would converting this into x8 be?
Koo is offline Find More Posts by Koo
Old Dec 13, 2013, 03:25 PM
Torque66 is offline
Noob
Torque66's Avatar
Canada, ON, Toronto
Joined Dec 2011
Woooooot...the thread die?
Old Dec 14, 2013, 03:28 AM
Pauluk1 is offline
Pauluk1's Avatar
Joined May 2012
No still going,for some reason my notifications have stopped.
Koo have a look at this thread:
http://www.rcgroups.com/forums/showthread.php?t=2025307
He is using the same frame in x8 config carrying a sony nex camera
Old Dec 14, 2013, 03:29 AM
Pauluk1 is offline
Pauluk1's Avatar
Joined May 2012
I need to swap recievers over on my 650 to use the taranis,also i have just purchased a naza lite,not sure that was a good idea after all the flyaway horror stories i have read recently.
Old Dec 16, 2013, 04:03 AM
Pauluk1 is offline
Pauluk1's Avatar
Joined May 2012
New goodies arrived in the post today,after reading all the flyaway horror stories i hope ive made the right decision
Old Dec 17, 2013, 01:51 AM
Torque66 is offline
Noob
Torque66's Avatar
Canada, ON, Toronto
Joined Dec 2011
Hey Paul happy holidays... been -12C here for the last few weeks.... sucks large.
Yeah.... i've seen a few new 650 build threads... they seem rather doofus to me tho.... extreme low kv motors and big props on an x-frame is just problematic when it comes to props in view imo.
Someone needs to make a 650 H-frame.... then that would interest me.
Naza... have a pair myself and oh the horror stories... well i've logged many hours without a problem using 5.8/2.4 and 1.3/433 gear.
Naza is great for fly'n via the gimbal camera tho... tilt panning whilst flying is awesome.
Build Log Tarot iRon Man 1000 Octocopter Build Askyvision Multirotor Talk 1525 Jan 19, 2016 07:44 AM
Discussion Motorchoice for Tarot Iron Man 650 libbelibbe Multirotor Talk 5 Nov 06, 2015 03:18 AM
Sold Tarot Folding CARBON QUAD Copter frame Kit Iron man 650 Carbon landing skids kevinlib Aircraft - Electric - Multirotor (FS/W) 3 May 07, 2014 03:53 PM
Discussion Tarot IRON MAN 650 Folding vs XAircraft clone x650 Randulf Multirotor Talk 6 Mar 21, 2014 03:15 AM
News Tarot iRon Man 1000 Octocopter Build Terry Multirotor Talk 0 Mar 06, 2013 08:17 AM
