Old Jun 05, 2013, 03:40 PM
CG Photo is online now
Find More Posts by CG Photo
Wedding Photographer
CG Photo's Avatar
United States, CA, Fresno
Joined Feb 2013
Question
Futaba R6208SB receiver programming
I have a Futaba R6208SB and 8FG 14 channel transmitter . I have the sbus cable going from my receiver to the naza. This is carrying 7 channels from the transmitter to the Naza and the receiver has an 8th connection that I can use for gear. I want more channels to control camera gear.
Is it possible to program this receiver to deliver the first 7 channels to the sbus and reassign 7 of the outputs to higher channels so I can use those outputs (1-7) in addition to the sbus? It would be really nice to have 7 outputs in addition to the sbus output going to the Naza.
It looks like it can be done with two hubs but I would rather not use hubs if I don't have to. I also see the R6303SB receiver has three open outputs in addition to the sbus and that may be a solution if I can't reassign the channels on the R6208SB. Three gear channels would be enough for now but I may want to add more gear later and getting all 14 channels would be perfect (7 on sbus and 7 regular outputs).
CG Photo is online now Find More Posts by CG Photo
Old Jun 19, 2013, 01:02 AM
Ezdrone.com is offline
Find More Posts by Ezdrone.com
United States, CA, San Diego
Joined Jun 2013
+1 to this question. Just tried to update my 8fg to super using 5.0 update and I got error (code:01). Now I'm stuck with a single remote with no gimbal control and an AP shoot scheduled in 2 days.
FML!!!
Another question to caveot yours.
Can you bind 2 recievers to one 8FG Super? I have a R6108SB now not being used and already setup for gimbal control. It would be great if I could utilize that option to get my shoot done, just until I in break my second remote.
Ezdrone.com is offline Find More Posts by Ezdrone.com
Old Jun 19, 2013, 01:13 AM
CG Photo's Avatar
Joined Feb 2013
I called Futaba tech support, then said you can't run more than 8 channels unless all the additional channels are on the sbus. The Naza must be on the first 7 channels and the receiver outputs also must be on the first 8 channels leaving only one open channel.
Another solution they said was to not use the sbus connector for the Naza. Connected the first 7 channels between the receiver and the Naza using servo cables. Then use the sbus output to connect to a decoder(s). Doing this will allow the receiver to receive and use all 14 channels.
You can bind more than one receiver to a transmitter.
Old May 10, 2014, 05:14 PM
hawaiiphantom is offline
Find More Posts by hawaiiphantom
Joined Apr 2014
A bit of a late response i know,...but I'm currently trying to accomplish the same settings and found this in the Futaba manual. Looks Promising!
hawaiiphantom is offline Find More Posts by hawaiiphantom
Sold Futaba R6208SB Receivers glegee Aircraft - General - Radio Equipment (FS/W) 1 May 13, 2013 06:54 AM
Sold Futaba 8FG Transmitter w/ R6208SB Receiver, R6014HS Receiver. WTR-7 Wireless Trainer voidunknown Aircraft - General - Radio Equipment (FS/W) 1 Jan 02, 2013 12:36 PM
Sold Futaba 8FG Super (T8FGS) Radio, R6208SB & R6008HS Receivers - NEW - $400/ $450 gmarchlewicz Aircraft - General - Radio Equipment (FS/W) 1 Apr 01, 2012 10:33 PM
For Sale Futaba 8FG Super (T8FGS) Radio, R6208SB & R6008HS Receivers - NEW - $500 gmarchlewicz Aircraft - General - Radio Equipment (FS/W) 0 Mar 23, 2012 12:27 AM
For Sale Futaba R6208SB Receiver - Brand New VEGAS_RC_ACE Aircraft - General - Radio Equipment (FS/W) 2 Oct 02, 2011 05:13 PM
