Old Jan 20, 2004, 07:18 AM
Houston, Tx.
Joined Jan 2003
Can you charge the individual cells from the center tap or is it just for checking voltage.
Seem like one good solution is using a plug-in pcb board for pack construction that allows you to unplug to charge cells individually.
I'm sure this has already been mentioned. I think someone already sell something like this.
Bill Bergman is offline Find More Posts by Bill Bergman
Old Jan 20, 2004, 07:39 AM
Fly For Fun
United States, FL, Spring Hill
Joined Apr 2002
Can individual cells (in a Li Po pack say 3S2P Tanic) be monitored while charging is taking place?
funflyrc is offline Find More Posts by funflyrc
Old Jan 20, 2004, 08:52 AM
Alphabandaid
Marshfield, Wisconsin, United States
Joined May 2003
Like the grill idea.
Actually, I've been using Lipos since they came out a year ago, ballooned one pack when I charged it aon nicad setting.
Other than that, I have very little time and experience with nicads or hydrides since I got into electric abotut the same time.
I like the grill idea for charging, and will go and get one this week. After reviewing the video, the flame seem to dictate a cover of some sort, more than the open pyrex dish I use.
Also, a fire extinguisher, and smoke alarm in area of the charger would be good idea, and dedcated lipoly charger to avoid picking the wrong setting.
Stuka/Alphabandaid
aplphabandaid is offline Find More Posts by aplphabandaid
Old Jan 20, 2004, 08:55 AM
Does anyone hear a cat?
headless's Avatar
Tallahassee, FL
Joined Sep 2003
Bill, yes, taps on packs allow you to not only check the voltage but also to charge each cell individually, allowing you to balance the pack whenever you choose. I have 2 TANIC packs with JST plugs embedded into the pack that allow balancing of each of the 3 cells. All TANIC packs sold nowadays have the option of taps being included on the packs.
funflyrc, not from what i have heard. The tanic taps, for example, all share the same ground wire, thus if you hook up any 2 taps or even the main charge lead and one of the taps, you will short the pack out and fry it. The taps are specifically made to check cell voltage and balance them out. Every few cycles i check each of the 3 cells in my 3s packs and make sure they are within .1v of eachother. If they are not, i charge each one separately until they are completely charged, thus are balanced.
I have a tp860 pack here that was damaged in a crash yesterday; nasty sickly sweet smell, no fire though. I think only 1 of the cells is damaged, perhaps 2. Anyone have input on WTH i should do with this pack? It's sitting in a big concrete area inside a fireproof container right now and has been for a day. No visible puffing of the cell but i can smell that nasty sweet smell and i'm just about sure one of those cells is FUBARed.... i am not comfortable trying to solder a lipo cell but i don't want to throw away all 3 cells if only 1 or 2 is fried...
headless is offline Find More Posts by headless
Old Jan 20, 2004, 09:02 AM
Houston, Tx.
Joined Jan 2003
Is there a diagram anywhere to show how to wire in chargeable taps?
Old Jan 20, 2004, 10:20 AM
WJ Birmingham's Avatar
St. Louis Metro
Joined Apr 2003
Davensocal;
Not having read all of the replies since I posted last...
Would you please check (using another pack), your speed controller, and ensure it's cutting off at 3V/Cell?
WJ
WJ Birmingham is offline Find More Posts by WJ Birmingham
Old Jan 20, 2004, 11:02 AM
Pittsburgh, PA
Joined Jan 2002
Headless,
To deliver a coup de grace to a bad Lipo immerse in some salty water for a day or two. This will render it impotent.
-Mike
FlyByMike is offline Find More Posts by FlyByMike
Old Jan 20, 2004, 11:10 AM
PittsLover
houfek's Avatar
Ohio
Joined Jul 2003
"immerse in some salty water for a day or two. This will render it impotent."
Jeez.......I'm staying out of the salt water !!
8*)
houfek is offline Find More Posts by houfek
Old Jan 20, 2004, 11:14 AM
Houston, Tx.
Joined Jan 2003
Hofek, your on a roll. Your kill'n me!
Old Jan 20, 2004, 11:22 AM
PittsLover
houfek's Avatar
Ohio
Joined Jul 2003
Bill......
You belong to too many threads.....
Old Jan 20, 2004, 11:34 AM
Houston, Tx.
Joined Jan 2003
and eveywhere I go ther you are.
Old Jan 20, 2004, 12:02 PM
headless's Avatar
Tallahassee, FL
Joined Sep 2003
does the cell have to be punctured for the saltwater to work on it?
Old Jan 20, 2004, 12:08 PM
Houston, Tx.
Joined Jan 2003
I think it discharges from the tabs
Old Jan 20, 2004, 12:19 PM
Walled Lake, MI, USA
Joined Feb 2000
There have been two salt water immersion scenarios discussed in the past:
The first is to immerse an unpunctured cell in salt water, which results in discharge through the tabs due to the salt water's conductivity.
The second is to puncture the cell with a non-metallic object after it has been discharged, and soak in salt water to neutralize the cell's electrolyte. This second scenario is not really necessary, and should probably be discouraged as someone might only get it part right and poke a hole in an undischarged cell with a metallic object, creating an instant dead short and major fireworks display. The goal should be the safest possible discharge before disposal of a bad cell.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Jan 20, 2004, 12:21 PM
headless's Avatar
Tallahassee, FL
Joined Sep 2003
Thanks Dave, i knew i had heard multiple scenarios involving saltwater but didn't remember the exact reasoning behind each one.
If only 1 or 2 of the cells in this pack are actually damaged can i send the pack to thunder power to get it re-created with replacement cells?
Daryl
Another LiPo fire....sorry no pics… ProudTexan Batteries and Chargers 8 Oct 30, 2005 12:25 PM
Another lipo+fire story :eek: mj147 Batteries and Chargers 0 Oct 09, 2005 08:15 PM
Another LIPO fire . gjestico Batteries and Chargers 10 May 11, 2005 11:33 AM
Another LiPO Fire Report. Very Sad. Mr.RC-CAM Batteries and Chargers 215 Dec 12, 2004 09:41 PM
Another Lipo Fire -- Etech cells Pat Daily Batteries and Chargers 39 Mar 15, 2004 07:41 PM
