Video Aerial Systems BluBeam Ultra
A few improvements to a classic from IBCrazy
Additional filtering for the popular BluBeam fpv antenna
Video Aerial Systems' BluBeam antenna has become a household name in the fpv world. Available in both the 3-lobe Airscrew and 5-lobe Mad Mushroom design, the BluBeam Ultra takes it a step further by incorporating a balun in the line, designed to reduce signal creep down the shield of the antenna cable and into the receiver. The lobes of the aerial and hub are dipped in a rubber coating to increase durability.
The BluBeam Ultra is available in 1.2-1.3GHz and 5.8GHz, and available in right-hand circular polarization (RHCP) only.
Link to product.
BluBeam Antennas overview (2 min 39 sec)
Old Jun 05, 2013, 01:28 PM
Wrice4 is offline
Find More Posts by Wrice4
Blacked out 350z - Texas
Wrice4's Avatar
Joined Nov 2012
I actually have the ultras and love them.
Wrice4 is offline Find More Posts by Wrice4
Old Jun 05, 2013, 04:13 PM
MercMan007 is offline
Find More Posts by MercMan007
SR 120,T28D Trojan,F4U Corsair
MercMan007's Avatar
Charlotte, NC
Joined May 2010
Me WANT!
MercMan007 is offline Find More Posts by MercMan007
Old Jun 06, 2013, 12:28 PM
WBFlyer is offline
Find More Posts by WBFlyer
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
Can't seem to find the pricing to order?
WBFlyer is offline Find More Posts by WBFlyer
Old Jun 06, 2013, 12:31 PM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
Here, try this google search. Theres lots of reputable dealers selling them as well.
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old Jun 06, 2013, 01:16 PM
Wrice4 is offline
Wrice4's Avatar
Joined Nov 2012
Readymaderc.com
Old Jun 06, 2013, 10:57 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Thanks for the review, Matt. I see you got the early revisions and not the newer ones. The new ones are blue (we had issues with VOC's on the rubber compound so we went with black for the initial production run) and have a more substantial nylon lock over the feed in the center to prevent breakage. The cloverleaf is also now an Airscrew antenna. Just a small improvement. Not much, but a small one.
To turn a cloverleaf into an airscrew, just bend the lobes down 22 degrees so the angle off the top and the angle at the base are the same. This ONLY works on the Ultra line. It does not work with a regular cloverleaf (trade secret).
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jun 07, 2013, 09:30 AM
BoeingSWTech is offline
Find More Posts by BoeingSWTech
BoeingSWTech's Avatar
United States, WA, Mt Vernon
Joined Apr 2013
Bluebeam Antenna on the F550
Hello all, I am new to the whole multirotor adventure. I purchased a DJI F550 from a member of this forum and I have flown the unit about 8 times and no crashes. Now I would like to venture in to the FPV realm and I have a question about antenna placement.
My current setup:
-Futaba RX
-NAZA with GPS
-Aeroxcraft Landing Gear
-Aeroxcraft Gimbal - With Metal Gear Servos (Turnigy)
-Stock DJI 2212 Motors
-GoPro Hero 3
-10.5 Carbon Fiber Balanced Props
What I will be adding:
-ImmersionRC 5.8Ghz 600mw Audio/Video Transmitter.
-Fatshark attitude SD Goggles
-5.8 GHz Bluebeam Ultra Antenna Set (RHCP) (IBCrazy)
Questions:
1. What is the best placement for the Bluebeam Antenna on the F550? Concerns, interference with DJI GPS antenna and other forms of interference.
BoeingSWTech is offline Find More Posts by BoeingSWTech
Old Jun 07, 2013, 09:48 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I would mount it upside down on the Helicopter (make sure you have landing gear so you don't land on it). This way you can't get it tangled in the props and if you do come in for a crushing touchdown, the antenna might bend, but you can just bend it back.
Old Jun 07, 2013, 09:57 AM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Yep, I had the early one. Unfortunately, I didn't tighten it down well after removing it and it fell over into the blades of my quad! Ill be ordering a new one soon.
Administrator
Old Jun 27, 2013, 11:21 AM
Strangely_Calm is offline
Find More Posts by Strangely_Calm
Eyes on the Prize
Strangely_Calm's Avatar
Australia, WA, Swan View
Joined Oct 2012
WebDr, Alex,
Can you explain the main difference between a Skew Planar wheel/ Cloverleaf combo vs the BluBeam Ultra?
I'm using Immersion RC gear at the moment, but looking to upgrade slowly to bigger and better systems. Taken your advice from the "How to be successful in fpv" videos mate.
P.S. was good to see you blow the competition away in the Woggle course haha!
Strangely_Calm is offline Find More Posts by Strangely_Calm
Old Jun 28, 2013, 09:57 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The Ultras simply have higher axial ratio. This comes in handy in places where the ground has high mineral content (such as in the mountains around where I live) and also helps when flying proximity. Multirotor pilots will see the largest benefit. For 5.8Ghz, the difference is substantial. For 2.4 and 1.3GHz, the difference is less substantial.
-Alex
Old Jun 28, 2013, 11:07 AM
Wrice4 is offline
Wrice4's Avatar
Joined Nov 2012
-Alex
When I upgraded to the bluebeams ultras I noticed a difference. Very happy with them
On my quad. I use 1.3.
Old Jun 28, 2013, 09:24 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^At the Pecan patch we had a pilot out 5.5 miles and somebody was picking up his video on the Mad Mushroom. I could hardly believe it. 5.5 miles is ridiculous for omni antennas but the Ultras did it on 600mW.
-Alex
Old Jul 11, 2013, 10:13 PM
raamedicva is offline
Find More Posts by raamedicva
Hanover, VA
United States, VA, Mechanicsville
Joined Oct 2007
Blue beam SPW
Alex,
I ordered the new Blue Beam Ultra to replace the Blue Beam that got mangled in my quad's prop. Is there going to be any issue with using the BBU CL with the BB SPW?
raamedicva is offline Find More Posts by raamedicva
For Sale Mikrokopter Droidworx PhotoHigher Aerial Video System jacksonjackson Aircraft - Electric - Multirotor (FS/W) 0 Apr 22, 2013 01:49 PM
Sold Cinestar 8 Aerial Video System - $5000 NickAnderson Aircraft - Electric - Multirotor (FS/W) 1 Mar 30, 2013 10:08 PM
Video Instruction Video List for DJI Aerial Photography Helicopter Systems DJI INNOVATIONS Aerial Photography 0 Mar 01, 2013 05:43 AM
For Sale REDUCED! NEW BNF 2man FPV PROl Aerial Video System - Lights/GPS/3axis camera mount/e wac Aircraft - Electric - Multirotor (FS/W) 1 Jan 15, 2013 08:48 PM
New Product BluBeam antenna system from Video Aerial Systems IBCrazy FPV Talk 122 May 17, 2011 09:41 AM
