Old Jun 04, 2013, 07:00 PM
twiglet123 is offline
Find More Posts by twiglet123
Joined Jan 2010
Ballast tank questions
Hello boys and girls, next step on my build a sub plan is to make the ballast tank.
It's going to be a pressurized tank that fills from a windscreen washer pump.
The pump will fill the tank pressurizing the air inside it then to release the water a valve will simply be opened allowing the water to be forced out by the built up air pressure.
I plan to build the tank from a strong piece of pvc drain pipe with two lexan endcaps held in place by threaded rods as per the masterpiece done on ms paint below.
just a few questions before pushing forward.
First, does the method of sealing this look like it will work or are there any obvious holes in this plan I haven't foreseen?
Next will the rubber be enough or would it be better to have some sort of epoxy for sealing too also any tips on the kind of rubber to use?
Are there any rough recommended sizes of ballast tank for different sizes of submarines out there?
Also I've spotted a potential issue pictured below, if the sub dives at a particular angle and I open the valve when the outlet pipe isn't covered by the water i can see the tank just emptying the pressurized air but leaving the water inside it with no way to get the submarine back up to surface, are there any standard ways of getting around this?
Any suggestions, recommendations or advice much appreciated
All the best
Twig
twiglet123 is offline Find More Posts by twiglet123
Old Jun 04, 2013, 08:35 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
perhaps use a weighted tube end inside the tank like the airplane fuel "clunk tanks"?
derk is offline Find More Posts by derk
Old Jun 05, 2013, 05:35 AM
Subsonic Mike is offline
Find More Posts by Subsonic Mike
Doing things differently
Subsonic Mike's Avatar
UK, England
Joined Sep 2009
Hello
I am using the same method of sealing the WTC on my sub, so you should be fine.
One suggestion though is to only have 3 or 4 threaded rods, 7 seems overkill and a pain to undo to access the insides.
Michael
Subsonic Mike is offline Find More Posts by Subsonic Mike
Old Jun 05, 2013, 07:41 AM
Joined Jan 2010
Thank you man, you don't have any photos lying around of your tank do you for refference?
Also what rubber did you use to seal it?
Old Jun 05, 2013, 08:15 AM
UK, England
Joined Sep 2009
The WTC isn't finished yet but in we (me and my dad) more or less copied the design from Norbert Bruggen's book. We also asked at submarine meetings on how to design a cylinder.
I will have to get back to you on the rubber and pictures because i'm going out soon.
You might want to think about getting the book, its quite old but very very detailed and just a great book.
book link
Michel
Old Jun 05, 2013, 10:03 AM
POLARISDAVE is offline
Find More Posts by POLARISDAVE
polarisdave
saskatoon
Joined Apr 2008
Blood pressure cuff
I use a blood pressure cuff under the wtc inside the hull and a water pump from subworks mounted inside the WTC. I pump water in to dive and run the motor back wards to pump water out to surface. as a back up I have a 2nd cuff mounted below the deck and a air pump in the WTC to inflate the cuff in the event that pumping water out wont surface the sub. I will testing it next weekend and I hope to have a video of it.
POLARISDAVE is offline Find More Posts by POLARISDAVE
New Product Air Hogs Dive Master 3" 3 Channel Remote Control Submarine NEW w/ Ballast Tank Ricomon Submarines 172 Mar 29, 2016 06:04 PM
Question Water pump for sealed ballast tank; Bogdan.Manole Submarines 7 Feb 06, 2015 07:09 AM
Discussion Simple ballast tank ideas? twiglet123 Submarines 7 May 24, 2013 05:47 PM
Question Is it possible to build a sub with out a pump and ballast tanks?? addictedtoplanes Submarines 7 Feb 07, 2013 11:00 PM
Piston type ballast tank question CarreraGTSCS Submarines 21 Oct 29, 2005 02:06 AM
