Covering Foam Wings With Ordinary Brown Paper
by Steve Kerrey.
The method is *roughly* as follows - there is still plenty of room for experimentation.  Feel
free to try any variations, and let everyone know what works and what doesn't work.  Sharing
information is what the Net is all about.
If you haven't tried this before, it might be worth practising on a spare wing core.  Anyone
who cuts their own wings will probably have several 'spare' cores lying around :-)
You will need:
-    Brown paper, obviously.  The most common paper is the brown stuff for wrapping
     parcels, you can find it at your local post office or newsagent.  It usually has a shiny
     side and a matt side, the matt side should be the one in contact with the foam.
-    A large bottle of glue (PVA, also known as white glue or Elmers), thinned down with
     water.  1 part glue to 1 part water is a good start, make it thinner if you live in a hot
     climate.  It is very useful to add a splash of food colouring as well, to help show any
     bits you miss (ever tried to see white glue on white foam?) and to ensure an even
     coverage.  Put it in a small bucket such as a margarine container.
-    A brush for the glue, whether it is disposable or not is up to you.  Use whatever size
     you feel comfortable with.
-    A decent pair of scissors.  Buy your own pair to avoid domestic arguments :-)
-    A _sharp_ knife.  This is important, fit a new blade in your scalpel.
-    Lots of newspaper on the workbench and floor, it can get messy :-)
Add the LE and TE to the wing, but do not hang any ailerons yet.  Make sure the wing is
clean and smooth, and the paper free of wrinkles (iron it if necessary).  Cut a piece of paper
large enough to cover the wing, with an overlap all the way around.  Give the wing a coat
of the thinned glue mixture, and lay the paper on the wing (matt side down).  Brush another
coat of glue on to the paper, then trim around the edges.  If you are covering the wing in two
pieces, repeat for the other surface immediately.  Covering the wing in one piece is
preferable, although a little trickier when brushing glue on both sides.  Rounded tips can be
negotiated by cutting a series of slits into the paper with that nice new scalpel blade, when
the whole thing is dry you can sand down any ridges caused by overlaps.  Brown paper sands
nicely if you keep the strokes smooth and even.
To save precious ounces, wait for five minutes (depending on the local temperature) then
scrape 90% of the glue off again using your Amex Gold Card :-)  This is very messy unless
you can catch the excess glue in the bucket again (good luck) but will result in a light, strong
airframe.  If weight is not critical (sport slope soarer), you could probably skip this step.  The
glue adds both strength and weight, use your discretion.
PVA contracts as it dries, as does brown paper.  The wing will almost certainly warp unless
it is pinned down while drying.  For a flat-bottom wing this is easy, don't forget to use a few
strips of scrap balsa to elevate it from the building board so the air can get underneath.  For
symmetrical airfoils, put a length of timber (ie. broom handle) under the LE and another
under the TE to keep them parallel.  Put a strip of sticky tape on the timber first, otherwise
you will glue the wing to it!  A thin wedge under the TE will add washout if appropriate.
When dry, sand the wing smooth and check for warps.  You can then cover it with film if
you want, but a spray can of acrylic paint from the local hardware store is just as good and
a lot cheaper.  PSS models in particular benefit from this technique, as it is quick to build and
cheap to repair.
Covering fuselages is pretty much the same, work with a series of panels rather than covering
the entire fuz in one step (unless you are a six-armed paperhanger).  To avoid warping the
fuselage, work on both sides together.
Many other variations have been tried, including the use of scrap fan-feed computer paper
instead of the brown stuff.  It works fine, and most offices throw mountains of it away on a
daily basis.  In January, it is not uncommon to find brightly coloured models with Christmas
wrapping paper on their wings!
One of the members of my former club (BATS) built a PSS Airacobra completely out of
foam and scraps of plywood.  The wings were covered with computer paper, and the fuz was
covered with 2" wide strips of masking tape!  Unless you stood right next to the model, you
couldn't tell the difference.  It flew well, looked good in the air, and was dirt cheap to build
from the local DIY store.
Steve Kerrey
metaphor(at)enterprise.net
Old Nov 23, 2011, 02:34 AM
FATIMANIGERIA is offline
Find More Posts by FATIMANIGERIA
FATIMANIGERIA's Avatar
Joined Nov 2011
Hi my comrads i fatima from somalia, altoh i am of niger blood my home country. I take internest in these rc tings, i teech my kids. Tehy very very excited, make me happy man.
I follow tis tutor care fully. But no good! There warps and aircraft unbalanced. Bit blud too, i teech my boy too be better wit knife in future. But oh no 1 side is bigger than other! I dont no were i going wrong. Should i start from begin? Any better guide? My english not good! Any body know better guide?
Help?
Your friend
fatima
FATIMANIGERIA is offline Find More Posts by FATIMANIGERIA
Old Feb 08, 2014, 01:04 PM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Links to Method?
Your explanation is pretty good, but since this is a well known and widely used method to cover soft foam board, it would be a good idea to add a few dozen links to video and other discussions about the procedures. What do you think?
Tsavah is offline Find More Posts by Tsavah
Latest blog entry: Center of Gravity - Airplanes
Old Feb 08, 2014, 03:15 PM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Since the original post is almost 18 years old I suspect there weren't many videos available online at the time. But if you want to add some links feel free .
Steve
slipstick is online now Find More Posts by slipstick
Old Feb 08, 2014, 04:29 PM
infernisidem is offline
Find More Posts by infernisidem
Joined Jan 2014
there is a guy that made a foam cub from scratch and shows you later in the video how to cover it with the glue and brown paper method
infernisidem is offline Find More Posts by infernisidem
Old Feb 10, 2014, 01:51 PM
Tsavah is offline
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Masking Paper Skin
I have been watching a guy on Youtube that uses the thin, cheap painter's masking paper that is normally sold on a roll in the warehouse hardware and lumber stores. The choices I saw were 6", or 12" wide rolls, so I got a 6" to try out. I think he is a science teacher since he makes the videos in a class room with lab tables. He talks about making RC airplanes out of foam and covering the foam with lightweight brown paper. The wings look to be a hot wire cut-out airfoil since they are solid foam and flex. He talks about how it is important to paper cover both sides of the wings at the same time, or it is likely the wing will come out warped once the thinned white glue has cured.
He has been able to apply thinned white glue (PVA, like Elmers) on the foam using a brush, apply the paper skin, smooth out the wrinkles, apply a bit of thinned glue on the outside if needed, using as little glue as practical, and hanging the wing up to dry using a T pin stuck in the corner of the foam with some string. The key being both sides of the wing need to dry out at the same time. He has commented some of his smaller, thinner wing cores would warp as the glue dried, but once dried out, were flat and straight. Interesting process, and I suppose it would be possible to steam the paper and glue off if necessary. Would be an interesting experiment if a wing, stabilizer, or rudder came out a bit warped.
Old Jun 09, 2014, 04:22 AM
cuica is offline
Find More Posts by cuica
Joined Jun 2014
I've used this method very successfully on wings and fin / tailplane for a medium sized slope soarer and it worked perfectly.
No warps, even on the smaller parts.
I think the key is to let it all dry at the same time. If you try to pin the pieces down to hold them straight you'll have problems.
cuica is offline Find More Posts by cuica
Discussion Building a foam P38 with a knife and emery paper kensp Foamies (Kits) 58 Nov 22, 2007 09:30 PM
Covering Twinstar with Brown Paper Method Steven DiStasio Foamies (Kits) 2 Jan 08, 2002 07:11 AM
Article How to vacuum bag foam wings with balsa skins Ralph Weaver Electric Plane Talk 0 May 01, 1997 12:00 AM
