Old May 30, 2013, 11:22 AM
quad007 is online now
Find More Posts by quad007
DOLLA DOLLA BILL YALL
quad007's Avatar
United States, FL, Orlando
Joined Oct 2012
Alert
Graves RC
I brought my plane into Graves RC in Orlando, Florida to get a motor. They suggested a motor, prop and ESC combo and it was not cheap. I ended up buying a Micro Dan motor.
The motor is not powerful enough and the prop should be bigger! The problem is the prop cannot be any bigger on this plane or it will not fit. So I have about 1:2 thrust to weight ratio which is absolutely crap.
I call up Graves and guess what. They won't take the motor back! They recommended the WRONG motor for this plane and won't refund the $65 motor or even exchange it. They don't know what they are talking about, don't take any advice from them.
quad007 is online now Find More Posts by quad007
Old May 30, 2013, 11:24 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Well, that sucks.
Maybe if you post what plane you have, what parts you bought maybe I can help.
Joe 1320 is offline Find More Posts by Joe 1320
Old May 30, 2013, 11:45 AM
lectroglide is online now
Find More Posts by lectroglide
lectroglide's Avatar
United States, WA, Puyallup
Joined Aug 2006
haven't had much experience with graves but haven't had any problems either however some outfits get real funky with returning things, next time try headsupRC.BTW microdan are good motors , which one did ya get and did ya read the spex b4 you bought it? I exclusvley use the MD 2505 2900KV on the 30 span "wingthing2" and get some good speeds, a bit pricy yes, you get what ya pay for
lectroglide is online now Find More Posts by lectroglide
Old May 30, 2013, 12:33 PM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Look up what plane you have, and look up the manufacturer's specifications for the suggested motor. Do those specs match the specs from the motor you bought?
And the way you wrote it, I am not absolutely clear. Did you buy the MicroDan because that is what they recommended; or did you buy the MicroDan because what they recommended was too expensive?
Many [if not most] retailers do not take back used products, but sometimes you can deal with the manufacturer directly for replacements or upgrades.
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old May 30, 2013, 12:55 PM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Which Dan? I may be interested!
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old May 30, 2013, 01:54 PM
quad007's Avatar
Joined Oct 2012
It is a 1800kv micro Dan. I have a zebro 38 wing.
Old May 30, 2013, 01:56 PM
quad007's Avatar
Joined Oct 2012
I bought exactly what Mark in GravesRC recommended. He refused to exchange or take it back.
Old May 30, 2013, 02:21 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Is it this motor?
http://www.gravesrc.com/MicroDAN_250...505-1845kv.htm
Here is the rest of them in case that wasn't the right one.
http://www.gravesrc.com/SearchResult...21&Search.y=19
What prop are you trying to run?
Old May 30, 2013, 02:27 PM
Greenland
Joined Mar 2012
Sorry, KV too high for me, but the Dan's are fantastic. Someone will buy it.
Old May 30, 2013, 07:19 PM
quad007's Avatar
Joined Oct 2012
Originally Posted by Joe 1320 View Post
Is it this motor?
needs to be smaller than or equal to 8 inches.
Old May 30, 2013, 07:50 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
On my combat wing that size, a 7x5 prop using a 1400 KV motor yields decent results on 3s. Not a speed demon, but on a wing it works well for my FPV......so your 1800ish KV motor should be stronger yet.
Another option is to spin a 6x5.5 prop on 4s. Those are the two recommended setups on that motor. All depends on what your goals are. If going for FPV, I would tend to use the 7x5 on 3s.
Old May 31, 2013, 12:47 AM
quad007's Avatar
Joined Oct 2012
Maybe it's supposed to be 1800kv but he gave me a 1200kv motor
Old May 31, 2013, 03:43 AM
Greenland
Joined Mar 2012
Wow, now I'm interested. 2510?
Old Jun 04, 2013, 06:47 PM
LowlyElevated is online now
Find More Posts by LowlyElevated
pǝʇɹǝʌuᴉ sɐʍ I ǝsnɐɔǝq
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
Graves doesn't do warranty service. you have to do that through the manufacturer.
Graves will tend to recommend expensive stuff, they sell high quality stuff and not crap.
I find it hard to believe that it is a problem with the motor, I would lean more towards your existing setup. if you are running on the wrong voltage you will not have a good experience. if you are on 2s, try a 3s. if you are on 3s, try a 4s.
LowlyElevated is online now Find More Posts by LowlyElevated
Old Jun 04, 2013, 08:27 PM
gregory.da is offline
Find More Posts by gregory.da
ProBro, 3D
gregory.da's Avatar
United States, FL, The Villages
Joined Jul 2008
Here's the specs. for it.
This motor is a 1845Kv version built for the APC 7x5 & 6x5.5 prop running on 3s or 4s Lipo.
7 Turns, 22AWG, DLRK, Star, 14 magnet poles
How do you know it's 1200kv? Did you measure rpms and voltage with a fully charged pack and no prop? MicroDan are known for power and reliability. If you are still having a problem after trying different prop/4s setups, I'd call Dan at gobrushless.com and talk to him. He's a great guy, who knows his motors, and will help you find the right motor/wind combination for what you are trying to achieve. If there is a mechanical problem with your microDan motor he will make it right.
gregory.da is offline Find More Posts by gregory.da
Discussion Tyco RC Grave Digger Truck Help Grave Digger Fan Off-road Cars 13 Jul 06, 2014 07:46 AM
Yippee! freewing f16 TV airframe only $129 @ graves rc(build thread) guitaramp68 Foamy EDFs 30 Jan 17, 2010 09:21 PM
Discussion graves rc.com RULES!!! guitaramp68 Vendor Talk 2 Aug 15, 2009 02:05 AM
Careful! Graves RC.com majflyer Vendor Talk 4 Mar 10, 2009 08:57 AM
Yippee! Graves RC Trex Heaven and other stuff Happymcc Vendor Talk 2 Aug 21, 2007 08:40 AM
