Old May 30, 2013, 05:20 AM
CK_1 is offline
Find More Posts by CK_1
Joined May 2013
Martinez board / Open source brushless gimbal HELP THREAD
Hi folks, since people are starting to flood the Open Source Brushless Gimbal thread with questions that have been answered in it noumerous times, I feel setting up a thread with solutions is necessary.
You can safely connect 2S, 3S and 4S batteries to the board.
Hardware: When you connect your board (on WINDOWS) the OS will automatically install a FTDI-UART device which is using a COM port. Make sure this COM port has a port number lower than 10, because otherwise the tweaking tool may not be able to access it.
Check your IMU (small gyro board) for proper orientation. If the software version on the controller board is lower than V49A_r161, the components (chips) on it must face DOWN. On the board there are two small icons indicating the X and Y axises. On firmware (FW) releases before V49A_r161 X MUST FACE FOWARD.
Edit: As of V49A_r161 the devs have solidly implemented the ability to define the IMU/sensor board orientation in the controller software according to several user reports.
Flashing Firmware
Remember, this is open source alpha software, people developing it are folks like you and me who do this for fun and passion, putting their unpaid spare time in it. So dont complain!
You need the Arduino software to write the FW to the EEPROM of the board:
http://arduino.cc/en/Main/Software
If the versions of the firmware have major changes you might want to consider performing an EEPROM Clear (erasing the EEPROM before writing the new FW version).
To find new firmware versions, go here:
https://code.google.com/p/brushless-...downloads/list
To see the changes from the previous version, click on the Filename or "Summary & Labels" next to the release.
The full release changelog can be found here: https://code.google.com/p/brushless-gimbal/source/list
After downloading and extracting the firmware, you get a folder something like this; BruGi_049A_r45 containing a folder "_BruGi" (BRUshless GImbal).
This contains a load of files, most importantly an ino file which is a "sketch" for the arduino software.
Open the ino file from arduino, select the right type of board and the proper COM port from the Tools menu. You can get a hint which board type it might be by checking the CPU on the board. Mine says MEGA328P, so I just used the "Arduino Pro or Pro mini, (5V, 16 MHz) w/ ATmega328)".
If you receive errors when compiling and sending the sketch, you have most likely
a) picked the wrong board
b) picked the wrong COM port
c) have a corrupted firmware download (has happened a few times it seems).
d) Arduino says avrdude: stk500_getsync (): not in sync: resp = 0x00
this does not mean that you have broken device. It's most likely a driver problem with the FTDI device (arduino usb interface) driver.
Windows will per default install the newest driver (2.8.28), which doesnt seem to work for everybody.
The driver needs to be changed manually for both the USB device and the FTDI (can be seen under device properties), the 2.8.24 version can be downloaded here.
Here is an excellent post by jy0933 describing the procedure in minute detail.
Or try using Windows XP if you still have a machine running it.
Ok, now, having flashed the new firmware, it's time for tweaking.
Many people have asked "Where is the BLTool.EXE?" for versions >V48?
Inside the (example) BruGi_049A_r45 folder, inside its GUI folder there is a file ending in *.TCL (example: bl-tool2_049.tcl). TCL is an interpreter language meaning you can use a program to "execute" said file.
A good one on Windows is ActiveTCL: http://www.activestate.com/activetcl/downloads
After installing activeTCL, just double click on the *.tcl file and the Tool will open.
Tweaking the gimbal. PID TUNING
There are tons of different boards, gimbals, motors and cameras out there. Infinite combinations. Yours is but one.
Added:
There are countless different setups for different motors and different cameras and different gimbal dimensions, YOU CAN NOT EXPECT NEW FIRMWARE TO WORK ON YOUR GIMBAL/CAMERA COMBO RIGHT AFTER FLASHING. EVAR!
(Unless you are flashing a specific manufacturer supplied firmware with specific PID values included in the firmware file, but that's not what we're talking about here.)
Having said that, what you should do is EEPROM CLEAR, then flash new firmware and start tweaking.
Tweaking procedure:
1. The IMU (small gyro board) must be mounted correctly on the tray with the camera, the camera must be in the tray of the gimbal.
The camera tray must be hanging freely and able to move the camera. DO NOT HAVE THE CAMERA TRAY SITTING ON A DESK AND EXPECT IT TO LEVEL. That does not make any sense for what you're trying to achieve anyway, now does it!?
2. Connect the board to a 2S, 3S or 4S battery. Note: Some people have experienced the need for different PID values with different battery types (as in: PIDs using a 3S battery differ from PIDs using a 4S battery with the same controller board).
3. Connect to USB
4. Connect the Tweaking tool (TCL file or executable)
5. Tweak away as follows:
Focus on Roll first, then pitch (or vice versa, just ONE AT A TIME!)
Set maxPWM and PID all to zero on both Pitch and Roll.
Starting with roll, increase your maxPWM to the point where the roll arm starts moving, then lower it a bit. Then increase P and I gradually until you get some oscillation in the arm. Now increase D (and lower/raise P, and I) to dampen the oscillation.
Repeat the procedure for pitch.
If you find the values get lost after you disconnect USB, remember to click SAVE TO FLASH.
On older versions of the GUI software you had to click SAVE to submit the changed values to "RAM" (actually being applied for active use that moment), then when happy with them click "SAVE TO FLASH" to write them to EEPROM so they'll survive the power cycle.
On newer versions, when manually entering values numerically, you still have to SAVE to apply while they are being auto-applied when using the sliders.
End of Addition. Old text below, with some identical info...
DO EXPERIMENT!
A good procedure is said to start by setting PWM to zero and then increase it on the first axis to work on. Increase PWM to a value that your motors have just enough power to move your camera. Then increase P until there is slight vibration/oscillation and then try to remove it by playing with I and D (and P).
NOTE: Values from V48 and lower will not work on V49! There has been a change in the way to read the gyro data, so new settings are needed!
Also do not use your fingers to offset the camera and have it rebalance to check your levelling, move the setup to check if the cam stays in balance.
If you have any solutions to old or new problems, please feel free to add them stating what FW they apply to! Thanks!
Remote control Pitch
As more and more vendors are selling Martinez based boards "ready to fly" more and more people are wondering why they cannot pitch down more than ca. 30 when remotely controlling pitch.
This is because the standard RC pitch limits on the firmware are defaulted to -30/30 degrees.
All you have to do to fix this (or rather, set new values, as it's not broken) is to use the GUI/TCL-Tool as explained above and change the RC-Min and RC-Max values.
Note that the pitch neutral/level is the average value of RC-Min and RC-Max, NOT ZERO. So if you set RC-Min (pitch down) to -90 and RC-Max to 30, RC-pitch neutral will be -30. This would have to be compensated by the offset value to achieve 0 at level, 30 for full pitch up and 90 for full pitch down.
HTH!
TROUBLESHOOTING
Ok, so you have done everything right so far, and you can somehow get one axis to work but not the other, no matter what you try?
Check your wiring and solder points. Many of the gimbals are from "the workbench of the world" and detailed quality is sometimes not where we'd like it to be.
A hot spot here is the connection of the wires to the IMU. Because of the setup, a lot of bending can happen here and if the solder points are not good, fraying (and then shorting) can occur. I had this happen to myself, and after 2 weeks of trying to get the gimbal to work I happened to find frayed cabling and once i replaced the IMU, everything worked fine after like 5 minutes of tweaking.
Grab a multimeter and crossexamine the connections to be sure.
If you ever experience the IMU (usually green) or cotroller board (usually blue) LEDs turning off or changing intensity, this strongly points to a wiring/soldering/electrical issue with your board(s). The board has resistors for voltage regulation (both the controller and the IMU need constant 5V), so the LEDs should always stay on and bright (not the Rx/Tx [red/yellow] ones of course).
Below are the reference board/component layout schematics by martinez found here (german forum).
Thanks mark_q for the wiring pic.
CK_1 is offline Find More Posts by CK_1
Old May 30, 2013, 01:02 PM
David Bott is offline
Find More Posts by David Bott
United States, NY, Rochester
Joined Jul 2012
Just a quick note that I have to give you Kudo's for this. Hope it works out as a sudo-wiki.
Adding to this...
When you post for help...PLEASE include...
Gimbal Type
Open Source Board Version
Open Source Firmware Version Number (Very Important as currently the only thing even close in them is the ver number itself.)
Motor Type
Battery Type (Yes, 3S and 4S can make a difference in power.)
Current Settings (If needed)
All in all, remember, frustration is only part of the fun. Take pride in that you are working at the bleeding edge technology. (And helping to one day have other line their pockets with cash from all your hard testing.)
David Bott is offline Find More Posts by David Bott
Old May 31, 2013, 03:12 AM
djspeedlv is offline
Find More Posts by djspeedlv
United States, NV, Las Vegas
Joined Apr 2013
has anyone figured out how to offset the brushless gimbals.. meaning.
once the gimbal is powered and up and running the roll is off about maybe 5 degrees so its not exactly level. but it works perfectly fine and maintains it without moving at all
djspeedlv is offline Find More Posts by djspeedlv
Old May 31, 2013, 10:26 AM
muchacho92 is offline
Find More Posts by muchacho92
Joined Apr 2013
Why is my gimbal flipping when it flies? When it is in the air it is making strange movements.
muchacho92 is offline Find More Posts by muchacho92
Old May 31, 2013, 01:54 PM
CK_1 is offline
Joined May 2013
Check your gimbal balance and the proper alignment of your IMU. It may also be a I or D value that is too high from my experience.
You can edit an offset into the Firmware files, but that way it is fixed plus you need to reflash (with the offset).
@muchacho92: Depending on what version you are on, you need to tweak your PIDs. Also check your copter for vibrations. Strong vibrations on the IMU could throw off the reading.
Old May 31, 2013, 01:57 PM
Michiel van Son is offline
Find More Posts by Michiel van Son
Zenmusement
Michiel van Son's Avatar
Belgium, Vlaams Gewest, Gent
Joined Dec 2012
I want to be able to tilt my gopro with a slider on my transmitter, but I think I have a faulty martinez controller board.
I have connected a signal cable from my receiver (futaba) to the A1 pin (which should be RC pitch control), but when I move the slider the gimbal rolls instead of pitches... I tried connecting the signal cable to A2, but that doesn't do anything...
What am I doing wrong? Can you please send me a picture of the setup for controlling the pitch control?
thanks very much.
Michiel van Son is offline Find More Posts by Michiel van Son
Old May 31, 2013, 02:17 PM
Wheems is offline
Find More Posts by Wheems
United States, OR, Damascus
Joined Feb 2013
my bL tool opens and is on com2 it reads it but all the adjustments stay gray I cant figure out why?
team rebel beholder
firmware flashed to 049
3s batt
Wheems is offline Find More Posts by Wheems
Old May 31, 2013, 05:09 PM
CK_1 is offline
Joined May 2013
thanks very much.
You can redefine the A1 / A2 in the definitions.h file that comes with the Firmware (do it in arduino).
Look for
Code:
//RC Pins
#define RC_PIN_ROLL A1
#define RC_PIN_PITCH A2
and swap them (to RC_PIN_ROLL A2/RC_PIN_PITCH A1 respectively), then reflash and reenter your working PID settings (hook it up to A1 of course). Just read this specific question in the german forum, didnt try myself. HTH.
@Wheems: Which V49A_rXX tool version are you using? I've had trouble connecting peoperly with the r40 tool, but the r34 tool works well and talks to firmware versions r40 and r45 properly as well.
PLEASE PEOPLE PROVIDE YOUR FIRMWARE VERSIONS! Be as specific as possible or the possible solutions multiply by powers.
Old May 31, 2013, 09:22 PM
lklansingkiter is offline
Find More Posts by lklansingkiter
United States, MI, Haslett
Joined Mar 2010
I am really confused about how to use the active state tcldevkit. It put a ton of crap on my computer and I have no idea what of the many applications it put on my computer to use to open the bltool2 049. Also this is a 21 day trial do we always need this now to open the GUI for version 49. I guess I need a step by step instruction. I have tried opening the bltool2 049 with the tclapp and it did nothing.
lklansingkiter is offline Find More Posts by lklansingkiter
Old Jun 01, 2013, 03:11 AM
Zenmusement
Joined Dec 2012
Look for
Code:
//RC Pins
Hi,
thanks for your response!
Problem now is that I can't get to connect to the GUI, it always gets stuck on reading values...
If I try to upload the 49r40 firmware with arduino it says avrdude: stk500_getsync(): not in sync: resp=0x00
I have the atmega328 5v, 16mhz arduino pro board selected and I am on com port 2 using windows 8
Is there a way to check the current firmware on the board? I don't know because I got it with a brushless gimbal...
thanks
Old Jun 01, 2013, 08:06 AM
CK_1 is offline
Joined May 2013
Hi,
thanks
This error usually occurs with mismatching FTDI device and COM drivers. If you check your device drivers it will read driver version 2.8.28.
You will need to replace them using the 2.8.24 drivers.
The older drivers can be found here: http://www.ftdichip.com/Drivers/VCP.htm
You need to manually "update" the drivers for both device and COM port to this version, unzip it and then select "pick driver from a list" to avoid windows automatically selecting the .28 again.
The only way to check the firmware is to connect. You have likely not ever connected yet.
Old Jun 01, 2013, 08:21 AM
CK_1 is offline
Joined May 2013
I dont know what YOU installed, but when I simply install ActiveTCL, there is no 21 trial or anything (I'm not using a devkit[??]). Then I simply doubleclick on the *.tcl file and get my tool interface. Very straight foward. I dont open ActiveTCL as a standalone software at all. There's also a commandline tcl Interpreter for Windows somewhere but it's not as easy as installing ActiveTCL and doubleclicking the *.tcl file.
The devs dont bother to compile a tool, because it's more work with no gain. It's open source. If you dont want to research, learn and tinker, you pay a much higher price and get a manual. It's not that hard, I only bought my first quadcopter 3 weeks ago.
Old Jun 02, 2013, 12:10 AM
Bilox is offline
Find More Posts by Bilox
Registered Crasher
Bilox's Avatar
Melbourne, Australia
Joined Jul 2008
EDIT: Fixed, I tried it on another computer and its fine?
Hi Guys,
Awesome work being done here!
Can someone please help me?
I am getting a complie error before trying to load the file into my board. (see attached)
Here is where I am at...
- I have opened the 49 BruGi.ino file in Arduino 1.0.5
- The computer is happy with the board on COM 9 (XP)
- I have selected the right board (Arduino Pro or Pro Mini (5V 16MHz) W/ATmega 328
- I have down loaded the file again just incase..
I also have the GUI working great just says I have old firmware
I'm not shre why Arduino.h is missing? Do I need to find it somewhere else?
I have played with Arduio software a little in the past but never come up with an error like this before?
Thanks in advance. Cheers!
Bilox is offline Find More Posts by Bilox
Old Jun 02, 2013, 12:40 AM
hchoohaa11 is offline
Find More Posts by hchoohaa11
hchoohaa11's Avatar
United States, CA, Yorba Linda
Joined Jun 2013
Hey guys,
I've been working with this Martinez board for 3 days now and I can't figure out my problem. I'm currently running BruGi_049A_r45 firmware on my board. I have THIS gimbal running the two iPower GMB2208 brushless motors. Running the board with it's own 3s battery. When I connect the roll axis motor to the Martinez board, everything works perfectly like it should. When I go to connect the pitch axis motor, my gimbal starts vibrating and it makes the whole gimbal unresponsive. If I unplug the pitch axis motor, the gimbal returns to normal and my roll axis motor works perfectly. I'm wondering if my motor for the pitch axis is bad or am I doing something wrong. I've tried tons of different settings in the GUI, but nothing fixes the pitch axis. Any help is appreciated.
-Josh
hchoohaa11 is offline Find More Posts by hchoohaa11
Old Jun 02, 2013, 02:01 AM
Joined Apr 2013
The gimbal is still flippen when it goes in the air. I use it with a 3s battery and firmware version 049. Is it maybe possible that i can reduce the strange movements when it flies with tuning or is this a vibration issue?
Discussion Open Source Brushless Gimbal edge0xc Multirotor Electronics 3073 Dec 11, 2015 03:16 PM
Idea Open Source Gopro Brushless Gimbal icais Multirotor Talk 16 Mar 28, 2014 12:07 PM
Discussion Next Gen Open Source Direct Drive Gimbal Control Board Tom Frisch Multirotor Talk 2 May 16, 2013 02:27 PM
Sold open source brushless gimbal controller jy0933 Aircraft - Electric - Multirotor (FS/W) 57 Mar 26, 2013 07:02 PM
Sold [closed] open source brushless gimbal controller jy0933 Aircraft - Electric - Multirotor (FS/W) 16 Feb 26, 2013 09:19 AM
