Old May 25, 2013, 05:11 PM
TX79 is offline
Find More Posts by TX79
United States, NY, Cohoes
Joined Oct 2010
Question
Spektrum DX7 Battery Replacement
Where do I get a replacement battery for my DX7 radio. It's not holding its charge the way it used to. Spektrum doesn't make them any more (Ni-MH AA 1500mAh 9.6v). Should I try Hobby King? I know everybody is going to say go LiPo but I want to be able to use the plug as it is for charging, and I don't want to get into making a lot of modifications. Radio still works great.
TX79 is offline Find More Posts by TX79
Old May 25, 2013, 06:26 PM
starzak is offline
Find More Posts by starzak
Tye
starzak's Avatar
Chacotoma, NM
Joined Jan 2004
Radical R/C.
starzak is offline Find More Posts by starzak
Old May 25, 2013, 06:50 PM
t.edwards is offline
Find More Posts by t.edwards
Joined Aug 2005
I've been buying these. The packs built from 2,000ma Eneloops work great.
http://www.hangtimes.com/txpacks.html
t.edwards is offline Find More Posts by t.edwards
Old May 27, 2013, 02:06 PM
JettaManDan is offline
Find More Posts by JettaManDan
Crazy Foamie Builder
JettaManDan's Avatar
United States, MD, Lexington Park
Joined Jan 2010
i know you want to still use the charge port but i really recommend going lipo....you can get a pack from valuehobby.com for it that is a 2600 mah pack..and it already has a JST pigtail on it..so all you do is remove the battery cover and hook up your lipo charger to it..literally that pack will last you so long it is incredible...I charged my radio pack like once a month with flying every weekend...i highly recommend it...
Dan
JettaManDan is offline Find More Posts by JettaManDan
Old May 27, 2013, 08:16 PM
Marion is offline
Find More Posts by Marion
Marion
USA, NC, Hillsborough
Joined Oct 2003
Marion is offline Find More Posts by Marion
Old May 28, 2013, 05:36 AM
Ken Myers is online now
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
2000mAh Sanyo Eneloops are a great way to go for transmitter batteries. You can still use the standard 'wall wart' charger, and no hassles about charging LiPos. I get my packs from NoBS Batteries, as mentioned earlier in this thread.
Ken Myers is online now Find More Posts by Ken Myers
Old May 29, 2013, 01:34 PM
swimmer is offline
Find More Posts by swimmer
AMA 1042906
swimmer's Avatar
United States, KS, Derby
Joined Mar 2008
Dan
Been trying to decide on a battery replacement for my DX7. Took your advice and ordered the 2600mah lipo from valuehobby.com today. Do you full charge your transmitter battery or stop at 11 volts or so as I don't know the ability of the DX7 to handle a full charged lipo? Basically the reason I'm going with a lipo is that I like the idea of infrequent charging.
swimmer is offline Find More Posts by swimmer
Old May 29, 2013, 01:47 PM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
some have had great success with Lipo.. My old JR 72mhz ran on Lipo for more than 3yrs before I sold it off and never missed a beat.
Then when I got my DX7, I did the same thing, and after 6 month or so, I started having mysterious crashes about once every 10 or so flights (total lost of link during takeoff). Had to send it in to Horizon for repair. I also notice my DX7 would run pretty hot at the top of the air vents... (coincidence...maybe...maybe not) BTW - Horizon swapped out the rf deck and I haven't had a crash since.
To each his own, but I'll never use a full 12.6 Lipo on an unmodified Tx.
Listen to the others and use eneloops. I did and haven't looked back. On a full charge I fly 6 hrs+ and still only down to about ~10.5v. I'm sure I can easily get another 6+hrs or more. I fly thermal planes sometimes and can be out for a long long time.
DX7 replacement batteries using Sanyo Eneloops (2 min 57 sec)
rcalldaylong is offline Find More Posts by rcalldaylong
Old May 29, 2013, 01:51 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
http://www.youtube.com/watch?v=KkOOEt0asMk
Eight 1.5v enerloops equals 12 volts. What is the difference? If there is an internal voltage regulator in the DX7 it may be creating the heat you describe so stopping the lipo charge at 12v should give consistant performance as the enerloops. Am I missing something here (just asking and glad all is ok with your DX7 now)?
Your RF board replacement is interesting. I had to have mine replaced, crashes just as you described with total loss of control, also sometime back and have always used the stock nimh pack. Searching reveals Horizon has replaced a lot of RF boards in DX7's exhibiting the same issues as yours and mine. By the way, my DX7 was about a year old when I started having the problem and again using the stock nimh battery only. Since that $70.00 RF board replacement, plus shipping, I have had no more problems.
Old May 29, 2013, 02:00 PM
Joined Dec 2007
Originally Posted by swimmer View Post
I do see an issue when charging to full charge, 12.6v, but what if the lipo battery is charged to only 11 volts?
Your RF board replacement is interesting. I had to have mine replaced, crashes just as you described, also sometime back and always used the stock nimh pack. If you do a search like I did you will find Horizon has replaced many RF boards in DX7's. It appears to be a widespread problem with these transmitters.
at 11v the Lipo is practically empty...which would defeat the purpose in the first place.
Old May 29, 2013, 04:17 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
I would think with the low amp rating of a transmitter that even at 11v there would be plenty of flight time comparable to nimh batteries. The only way for me to determine what is best for me is to try. Obviously there are many opinions. Will do more research as I won't risk my aircraft or transmitter.
Thanks.
Old May 29, 2013, 05:23 PM
Joined Dec 2007
Thanks.
@11v you have less than 10% left in the tank
http://www.rcgroups.com/forums/attac...mentid=3842605
Seriously, go eneloops...you won't regret it. Eneloops will get you close to 1000 charges if not more.
Old May 29, 2013, 05:34 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
If you want a more modern battery without the slightly higher voltage of the LiPo batteries you can use a 3s LiFePO4 pack. They work great and working voltage is 9.9v.
LSD AA's are certainly good too and can be charged with the stock charger.
Old May 29, 2013, 09:08 PM
johnfly1234 is offline
Find More Posts by johnfly1234
United States, KS, Arkansas City
Joined Oct 2012
+1 on the life po4 !!!!!!!! I have been using them for about 3 yrs. now and have allmost changed my whole fleet to life. Just have to take off the battery cover door and plug in the balance wires not a big deal and no fear of burning anything down or having it puff from being fully charged and getting too hot !!
johnfly1234 is offline Find More Posts by johnfly1234
Old May 29, 2013, 09:23 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Will consider the life P04 battery.
Sold Spektrum DX7s DX8 2000 MAh NiMH battery - $16 Shipped CONUS parkflyer215 Aircraft - General - Radio Equipment (FS/W) 0 Apr 20, 2013 05:31 PM
Sold FOR SALE: Spektrum DX7 Transmitter w/LiFe battery superjon Aircraft - General - Radio Equipment (FS/W) 2 Apr 10, 2013 06:23 PM
Question Two DX7 battery replacement questions Bombay Radios 8 Apr 06, 2013 08:51 AM
Help! Issues with Replacement Battery for Spektrum DX7 Rob Knox Batteries and Chargers 10 Feb 01, 2013 08:33 PM
Wanted Spektrum DX7 replacement battery jetboy11914 Aircraft - Electric - Batteries & Chargers (FS/W) 7 Sep 13, 2011 11:17 PM
